Russ
Apr 14, 2011 15:08:09 GMT
I've got to replace the rear shock absorbers on my mk4 Escort and i can't get the damn top nuts off The haynes manuals says to put an allen key to hold shocker rod, then use a swan neck spanner to uno the nut, which i have tried, but the nuts are nylock and do up soooo tight, the allen key holes have rounded off . So i tried jamming a bigger allen key into the hole but the same thing happens. So i'm now thinking of other ways to get them nuts off. I can't grind them off as they sit in like a 'dish', so the grinder can't get to them easily. I also thought about cutting through the shocker rod and pushing it up into the car but i'm not sure if that'll work? Here are the offening nuts... Any ideas?
Seth
Apr 14, 2011 15:21:09 GMT
Drill it? Not got that far to open that hole up until you break through to the thread.
Apr 14, 2011 15:22:55 GMT
stilsons/mole grips on the damper strut and blowtorch the nyloc, it won't put up much fight after a bit of heat...
best bet with these is an impact gun to do the initial loosening jolt that's needed. (but not something that lots of people have access to obv.)
Or as there is a lot of thread poking through the top of the nut - you could cut a groove in it for a large screwdriver to hold the strut whilst you apply the spanner again
Last Edit: Apr 14, 2011 15:24:56 GMT by jasonb360
- '80 Mk1 Vauxhall Cavalier Saloon, 3.0l 12v... in progress with some special plans ahead - '94 106 Rallye, Endurance Rally Car
EmDee
Committer of Autrocities.
Club RR Member Number: 108
Apr 14, 2011 15:27:25 GMT
Have you tried a frikkin "laser"?
Last Edit: Apr 14, 2011 15:36:38 GMT by EmDee
GavinJ
MGB 3.9 v8 Sebring
Club RR Member Number: 209
Apr 14, 2011 15:30:57 GMT
Impact gun works a treat like Jason said, you can get cheap electric ones that work off your fag lighter.... direct.tesco.com/q/R.207-4508.aspxWorth its weight in gold, brilliant for ball joint bolt etc - go buy one.
Apr 14, 2011 15:31:54 GMT
Happens alot with polos too.
Jack it up, Get some big hefty molegrip/viceclamps on the shaft from under the car to stop it turning. Then hold that (or get a helper to) and undo the top nut.
In extreme cases ive actually welded a bar to the shaft in the past to stop it turning, I.e when someone has crossthreaded a nut on, Or over torqued it..
Apr 14, 2011 16:21:12 GMT
If you've got some extra torx bits you can hammer one of those in the allen key hole, although the impact gun tends to take car of it. Don't scratch the chromed damper rod too much if you plan on reusing the dampers.
Last Edit: Apr 14, 2011 16:22:09 GMT by dude
Russ
Apr 14, 2011 17:05:20 GMT
Tried Seth's method ;D Thanks for your help guys
Apr 14, 2011 18:30:03 GMT
The other way is to put a set of these (a Stilson or pipe wrench): On the suspension piston rod or casing (whichever way is facing upwards), and then undo it! It's worked 5 times out of five. It grips it like a mutha - every tool box should have one (and they come in small sizes).
Copey
Apr 14, 2011 19:57:43 GMT
i just attacked mine with a grinder on the capri
Apr 14, 2011 20:04:34 GMT
The torx hammering method works well if you want to re-use the shock, and have an angled ring spanner, but if you like butchering then drilling works too
1989 Mini MG 1275 ~ 1987 VW Polo ~ 1989 Citroen 2CV ~ 1998 VW T4 ~ 2006 Volvo XC70
Seth
Apr 14, 2011 20:07:54 GMT
Well, wouldn't you know! I've never had a car with that kind of shock mount
