May 13, 2011 13:52:56 GMT IDY said:
Thing is, none of the fluis are dropping in level despite there being a huge puddle under the car. PAS, ATF. Oil, brake fluid...they're all fine.
How is the coolant level? I had Sierra with an oil leak which didn't cause the oil level to drop significantly, I did have to keep topping up the coolant which I put down to a seeping rad - turned out it was also losing coolant through the head gasket into the oil, the amount of coolant getting in to the oil was just about enough to keep the level looking right.
Interesting, the coolant light did flash this morning. It promptly went out though (I was only moving it 20ft, I'm obviously not driving it at present).
Chris
