generallee
Just a quick one.. Do VW 4 studs fit BMW 4 studs? I know the actual studs fit, but will the offset be all to cock? A friend of mine is selling some wheels off his Golf, I currently run an E30, and Ms Generallee is wondering what I would like for my birthday... ...see where this is going? Anyway, some tidbits for your trouble:
rob0r
East of England
Club RR Member Number: 104
VW/BMW rim question.rob0r
@rob0r
Club Retro Rides Member 104
They bolt on, but VW rims in general have higher offsets so they may look a bit odd on an E30.
E30 320i 3.5 - E23 730 - E3 3.0si - E21 316 M42 - E32 750i ETC
ZXRob
all depends what the wheels are at the end of the day. Are they factory VW wheels if so then yes the offsets will be higher but if they arent they may well be the same or lower
generallee
They are BBS type (OEM I think) cross spoke jobbies. I might just get round there and try them on to see if they look daft or not. Thanks
VW Corrado G60 BBS wheels on my old E30. The rears had to be spaced out almost 25mm and the fronts were spaced 17mm if I remember correctly.
generallee
^^^^^^ That looks the business! Just had him on the blower, apparently they are indeed corrado ones he is running.
*scuttles off to ebay to look for spacers and longer studs*
