Sept 3, 2010 11:23:57 GMT
? I don't know if we are misunderstanding each other, the solder joints are inside the relay, and are (almost) always the problem.
Tell you what, if you can't find a replacement easily, post me the relay and I'll fix it.
berendd
Sept 5, 2010 12:47:21 GMT
found one on the bay of e for 20 euro's, nos
but how do you open the relay?
Sept 5, 2010 14:29:12 GMT
The blue cover clips over the bottom bit where the pins are, you can normally persuade it to pop off with a pen-knife.
berendd
Sept 5, 2010 19:31:19 GMT
I've taken the cover off (with mitsuba on), then I checked all the connections on the green plate and they were all ok. Only inside the relay something had come loose, so decided it was best to look for a new one. Also didn't see a possibility to open the relay as it was all in one piece.
Sept 5, 2010 21:16:04 GMT
Ah well, at least 20 euros is a cheap fix
The Doctor
Club RR Member Number: 48
Sept 6, 2010 13:10:53 GMT
show it to me this arvo berend, i'll be in the barn also, and i've got my soldering iron there maybe i can fix it in the mean while.
berendd
Thomas resoldered the joint last night, but it didn't work, allthough the joints weren't too good the problem lays inside the relays.
berendd
Sept 17, 2010 8:04:30 GMT
recieved a new main relay in the mail yesterday and fitted it.. turned the key and it didn't start... I noticed the fuel pump wasn't spinning/working.. is there a separate fuel pump relay on these? Oh btw Thomas, we pushed it inside and then it was locked in P with the keys still in it got a spare key in the ford.. so will drop that off shortly.
berendd
Sept 17, 2010 12:26:08 GMT
berendd
Sept 20, 2010 21:37:56 GMT
soldered the NEW relay..... and problem is fixed!
one happy customer!!!
Jun 28, 2014 23:35:31 GMT
Hi does anybody know where the red civic sport is or who knows the owner? I'm very interested in buying it and would pay a good price 07885989984
Kind regards
