Davenger
It's only metal
Club RR Member Number: 140
Those of you who attended the gathering may have seen this run. And hopefully got some pictures or video of it. Anyway, this is how I did it. Take 1 cheap RC TVR Tuscan bought on ebay for 99p Remove body and stare at what's left Rip out engine and gearbox Buy plumbing tube from Wilko and build a housing for 2 C6-5 Estes rocket motors Then shove it into the space where the electric motor was, making sure they point ever so slightly upwards to keep the back on the ground Next, turn your attention to the blocked off vents that are moulded into the shell, cutting them out and fitting ducting to channel air Trim off the excess Then cut holes in the back for the motors to stick out Eliminate the massive slack in the axle left by the removal of the gearbox by making plastic washers Add strengthening behind the rocket motors to stop them firing into the car and blowing it up You are now ready to roll. The original plan was to use the power that used to run the motor, however 6 volts wasn't enough, so I had to borrow a 12 volt battery from the lovely folks at Area 52 I'll post pics of the aftermath later
Last Edit: Sept 21, 2010 20:01:00 GMT by Davenger
Well mental, cool too need vids of it in action
Davenger
It's only metal
Hoping that somebody filmed it running at the gathering. I was busy trying to keep it in a straight line, and failing. I know why I couldn't steer it though. The steering turned, but the tyres got ripped straight off the rims and it kept going un-altered. It lives to run again, so I can figure out whay it veered to the left Not going to clean it, it looks cool
Great stuff. I just heard it and saw the smoke.
Davenger
It's only metal
It left 2 little scorch marks on the track ;D
It was great for the first 20 feet. I laughed hard at the dodging camera fella, who's name I forget.
More next year?
Lewis
Davenger
It's only metal
Hopefully mate. And hopefully in a straight line.
Take the 6V, attach a relay that switches a 12V supply (small 12V you get out of car remote fobs maybe?) attach to rocket motors. Push forward on the RC control, fwoosh On a related note, where did you get the rockets from?
Davenger
It's only metal
That may well be on the cards. Got the rocket motors from a local model shop.
skinnylew
Club RR Member Number: 11
did lol with the camera guy diving for cover!!
Davenger
It's only metal
Yeah, poor curse word. Good reflexes though ;D
Davenger
It's only metal
Sept 21, 2010 20:05:08 GMT
Finally got pics from BodieandDoyle, and they tell a very interesting tale. The calm before the storm Very interesting behaviour from the car And there it was, gone Have to give some serious thought to the redesign. I thought the front had lifted, but that middle pic tells a different story
Nathan
Sept 22, 2010 13:31:32 GMT
Would the going off to the left not be caused by the Rockets not being exactly central?
I think the Amount of thrust + the weight of the car + the size will always give you steering issues, it looked to be just bouncing off any small inperfection on the track, I would of thought It may be better to use a larger model car like a Tamiya Saloon etc, but increase the amount of Rockets.
jonw
Can open a Mouse with a File
Sept 22, 2010 14:30:24 GMT
AWSOME.... I need one of those... I wonder where my RC car is?? I have (of had) a rear steer corolla somewhere.... could be fun!!! Rockets and rear steer....
I think a bit of re-aligning of the motors is needed.... either that or more weight!!
Looks fun though!!!!
Suzuki SV650R The good Triumph T20 The Bad BMW G650GS The Ugly Matchless G12CSR The Smokey Toyota Hybrid One pint or Two?
Ingredients of this post Spam Drunken Rambling of author Bad spelling Drunken ramblings of inner voices Occasional pointless comments Vile beef trimming they won't even use in stock cubes
Fungus
Sept 22, 2010 16:07:24 GMT
That must stink now with all that sulpher (?) left on it :L i thing my rocket had the same engines, the smell was terrible
Davenger
It's only metal
Sept 22, 2010 17:33:16 GMT
One step ahead of you guys. I was planning WMA MK2 as soon as I got back from the gathering. I'd already figured the motors were misaligned and that the next car would need full suspension. The track was pretty lumpy so I',m not surprised it took off. However, the front end does appear to be pointing down, implying that my aerodynamics may have worked a bit to keep the front down. Just not enough for 2 rocket motors. I've already sourced a donor vehicle and the rockets I will be putting in it. These bad boys have twiche the thrust and burn for twice as long. They're the most powerful disposable motors I've been able to find, can't be faffed with re-usable ones www.modelrockets.co.uk/shop/product_info.php?manufacturers_id=11&products_id=117
Sept 24, 2010 15:46:19 GMT
Not sure you need the vent in the front, its there for airflow through the rad on the TVR.
Davenger
It's only metal
Sept 24, 2010 22:11:56 GMT
Not sure you need the vent in the front, its there for airflow through the rad on the TVR. I was using it to channel air like an aerofoil in an attempt to keep the front end down. With limited success ;D
Sept 26, 2010 19:09:31 GMT
this takes me back. a mate of mine worked in a warehouse where they were throwing out a pallet and a half of old estes model rocket kits and spare engines, we took the lot and needless to say had a lot of fun sticking them to everything we could think of. this included me on a bike with about 20 attatched to the seat post, me on a skateboard with as many as we could fit on the tail and lots of model cars and other junk... we did build a few into actual rockets too. good times... your tvr looks sweet, would be awesome if you can get it to steer too.
Davenger
It's only metal
Sept 26, 2010 19:43:24 GMT
I'm gonna try to get it to go in a straight line, just so I can say it works. I've got the next project car on it's way to me. A 4wd tarmac car. I'll be stripping out the motor and gearbox and the diffs and shafts and fitting a suitable retro body shell to it
