The Doctor
Club RR Member Number: 48
2,5" custom coilover kit?The Doctor
@thedoctor
Club Retro Rides Member 48
for my Chaser i'm searching for a 2,5" coilover system, just like the stuff Rallydesign sells for Ford Escort struts, but that's 2". I used those on my Corolla and they work perfect, but the Chaser uses thicker struts and i NEED more lower on that car! There's a company in the US selling those type of kits for the type of strut i use, but they are made out of alluminium, hard to weld and (imho..) WAY overpriced. Help me to fix my nose up stance!
30psi
Nov 19, 2009 12:08:20 GMT
I thought most conversion kits are 2.5". Your right to avoid the aluminium ones, I've seen these for sale for Hondas and they're not welded to the tube, but have grub screws or something (can't remember). Would be interesting if they slipped if you had removed the original cup.
1962 Ford Thunderbird 6.4L
1981 Datsun Bluebird SSS CA18DET
1981 Datsun Bluebird SSS SR20DE
Nov 19, 2009 12:18:27 GMT
2.25" are the most common aren't they? I'm struggling to find 2.5" springs that aren't double the price of 2.25.
I have the alloy collars and the grub screws are only to stop them rattling/spinning,they sit on steel collars so they can't go anywhere (well mine do at least)
Nov 19, 2009 14:53:27 GMT
HK Phooey is right - 2.25" is the most common size of coliover by a long way. The 1.9" and 2.5" are less commonly used and therefore more expensive generally.
The Doctor
@thedoctor
Nov 20, 2009 10:36:24 GMT
hmm, I need to measure my struts again then! ;D i'm going to pick up a spare set of struts on tuesday, so then i'll measure it again and order the correct sleeves! btw.. I don't want the ones with the little screw in, because I found out that they don't give me the lowness what I want + they are a little bit on the illegal side for our MOT: ;D
Last Edit: Nov 20, 2009 10:44:59 GMT by The Doctor
Nov 20, 2009 12:38:23 GMT
You probably do need 2.5 springs,i'm just saying 2.25 are a more common application. Rally design have 60mm srings for sale too if they're any better?
2,5" custom coilover kit?Robinxr4i
@robinxr4i
Club Retro Rides Member 143
Nov 20, 2009 12:38:47 GMT
Got my 2.5" spring from....... www.merlinmotorsport.co.uk/.....and I got the compbrake 2.5'' kit, was really cheap but TBH the quality aint great. The result was good thou ;D
30psi
Nov 20, 2009 14:16:48 GMT
Sorry I got mixed up between 2.25 and 2.5....
