RetroMat
Column Shifting!
My hiace is currently wearing a set of 185 r14c tyres, no mention of profile. What should the profile be? 3 off the tyres are good and pretty new the 4th is a rather horrible looking remould which I would like to ditch. - i've been offered a part worn 185 75 r14c - I just wanted to check if I got this it would be the same as the others or they might be 80's or something. cheers Mat
Last Edit: Apr 8, 2009 23:13:02 GMT by RetroMat
The Doctor
Club RR Member Number: 48
if there's no mention of profile, it's an 80 profile most of the time.
So 185/80/14
if there's no mention of profile, it's an 80 profile most of the time. So 185/80/14 I agree with this statement, from personal experience
75 is prob near enough to use
75 is prob near enough to use Afraid not. You'll also fail your MOT with different profile wheels on the same axle.....
1951 Split Window Beetle - SOLD! 1965 Mercedes 230SL 1966 VW Beetle 1968 Mercedes 280SE
1972 VW 412LE Variant - SOLD! err.... 2004 Toyota Corolla
75 is prob near enough to use Afraid not. You'll also fail your MOT with different profile wheels on the same axle..... Yes they will. We run 185X14Cs and had no idea what the other number should be! ;D
RetroMat
Column Shifting!
cheers for the help all 75 is prob near enough to use Afraid not. You'll also fail your MOT with different profile wheels on the same axle..... this is exactly why i wanted to check! - When i get a chance i will head down thepart worn place. either get 2 185 75 or a single 80.
CIH
No quite right there. 185 14C (or any other full profile tyre) is actually 185/82 14. They can be mixed with 80 series tyres with no problems though. Wouldn't mix with a 75 series.
