dan91
Jan 29, 2023 18:23:42 GMT
Firstly, feel free to delete if this already exists, I had a brief look but I'm lazy and didn't see anything! For people like me, who have all the intentions of creating a build thread but never get around to doing it/never get around to keeping it updated this thread is for you! Short post about what you've been upto, Car related ideally As for me, got next week off work prior to starting a new job so figured it's time to get the MX5 ready for summer.. dragged it out of the garage, first time it's seen the sun since i think August? I pulled the engine out back in August for a bit of 'quick' maintenance, ended up converting it from auto to manual and refreshing the engine. Also had a garage clearout.. scary how much Mk1 MX5 stuff i've hoarded. So what about you guys/girls?
Jan 29, 2023 18:33:19 GMT
Doing what I do for a job but at home lol. £500 p/h sort of makes up for it though lol.
dan91
Jan 29, 2023 18:36:28 GMT
Doing what I do for a job but at home lol. £500 p/h sort of makes up for it though lol. Looking good, shame you're so far away as i have a 1.8 MX5 Engine I'm planning to rebuild over summer and wouldn't mind the block/head properly done.
ems1
Club RR Member Number: 5
Jan 29, 2023 19:25:35 GMT
Removed the Prop and Cardan Shaft from the Manta so I can send them off to get reconditioned and balanced. Hopefully this will sort out the vibration that gets bad around 2500 rpm onwards.
1985 Manta GT/E 16v 2001 VW T4 Caravelle
Last Edit: Jan 30, 2023 7:10:16 GMT by ChasR
adam73bgt
Club RR Member Number: 58
Yesterday I got my daily Crossfire back on the road after a full rear suspension/subframe rebuild and swapping out the cheapy ta technix lowering springs for Eibachs Went and put some fuel in it, then kerbed the hell out of one of the front wheels when I got back as I misjudged how wide it is 🙃
dan91
Jan 30, 2023 17:57:43 GMT
So first day off i decided to start putting the MX5 back together, first job was to fit the Clutch pedal/master cylinder as i converted it from Auto to manual a few months ago.. fiddly with the dash in.. and i had a Mk2 Dash i wanted to retrofit into it at some point.... So I'm an idiot, rather than putting stuff back on, the cars now even further apart. But the magical 3'rd pedal is now present. Promised the girlfriend we'd do something non car related tomorrow.. more fool me. So plan for later this week is work out the wiring differences between the 2 dashes, make a loom and get it fitted hopefully
dan91
Little bit more progress on the 5 today, this week off is going quicker than expected unfortunately.. I may start an actual build thread, but for now ill dump stuff here. Stripped the MK1 & MK2 Dash down, got the wiring looms off, and started separating/de-looming the parts i'll need from the MK2 loom. I also had an idea.. MK1s are known for the ECU sitting in the passenger footwell getting damaged by water etc.. they're not the most watertight classic cars. So the MK2 Dash had a passenger airbag which may have got responsibility disposed of during some bonfire night festivities. I have a space, I'm going to relocate the ECU up there in the dry. Few pictures.
dan91
Also worth noting although this exists: forum.miata.net/vb/showthread.php?t=668273Not all the colours are correct, so ill have to do some digging for RHD wiring looms for the right year etc. It's mostly right and helpful though!
Not retro but just for completeness I finished the engine off. Looks like a new one....because it is...almost. Did 100 miles from new before the radiator was damaged during a minor crash and it overheated. Stripped, cleaned and checked it over, then built back up with new gaskets etc.
dan91
Final update from my week off, nowhere near as much progress as id planned, isn't that always the way.. Also decided to get it how i want it i need to spend more time and ive accepted it wont be done this summer, so the man logic plan is to now take longer, get everything how i would like it over summer when its nicer to work on it.. and buy another convertible, likely another mx5, to enjoy over summer.. So she's tucked back in the garage for now.. awaiting motivation/funds/time I also found some yen under the carpet! Depending on if this thread gets used/keeps going ill update in here when i do something next, alternatively ill start a build thread eventually.
M9T engine is getting picked up tomorrow evening. Onto the next one then, anybody want a nice 180-195bhp depending on induction RWD 2 litre Duratec? LOL.
Mar 21, 2023 17:06:17 GMT
Brought it out of hibernation
Mar 21, 2023 17:50:11 GMT
M9T engine is getting picked up tomorrow evening. Onto the next one then, anybody want a nice 180-195bhp depending on induction RWD 2 litre Duratec? LOL. been looking duratecs for mgb swap i didn’t realise what sort of power they made!!!
Mar 21, 2023 19:00:30 GMT
M9T engine is getting picked up tomorrow evening. Onto the next one then, anybody want a nice 180-195bhp depending on induction RWD 2 litre Duratec? LOL. been looking duratecs for mgb swap i didn’t realise what sort of power they made!!! Pound per hp they're about as cheap as NA tuning gets upto 210hp or so, and NC MX5 gearboxes make RWD conversions much easier. The only real drawback is they're quite tall.
Mar 21, 2023 21:21:45 GMT
been looking duratecs for mgb swap i didn’t realise what sort of power they made!!! Pound per hp they're about as cheap as NA tuning gets upto 210hp or so, and NC MX5 gearboxes make RWD conversions much easier. The only real drawback is they're quite tall. frontline developments drop the 2.5 version in their cars so must fit frontlinedevelopments.com/vehicle/mg-le50/
Mar 21, 2023 22:32:33 GMT
Yeah, the 2.0 is a fair bit shorter than a 2.5 too.
Roach
Mar 22, 2023 17:27:14 GMT
Put a new flasher relay in my daily so now it’s got indicators again. Also polished and ceramic coated this 2022 911 GTS for one of my customers.
Last Edit: Mar 22, 2023 17:27:30 GMT by Roach
Mar 22, 2023 17:51:47 GMT
Selling this recently I focused on sealing the leaking sunroof on the Off road Landy and bodging the front grill. This followed searching for the next project on social media,
