Mar 23, 2022 13:39:57 GMT
Hi Folks
I'm prepping the Cortina for a trip to Italy later in the year and want to make the interior a bit more comfortable (its currently bare metal floors) by putting in some sound deadening followed by carpet. Dynamat seems to be the "Hoover" of the car sound deadening world, but seems to be very expensive. What are the alternatives? Any recommendations and personal experiences welcome
cheers
Cortinaman
Old Fords never die they just go sideways
Mar 23, 2022 14:02:24 GMT
I've used Lead Flashing tape before with good results, and other people I know have used "Brown Bread"
Mar 23, 2022 14:38:14 GMT
I've used Noico and Silent Coat, no probs. Bear in mind what it's used for though. CLD (dynamite etc) is good for stopping panels vibrating in sympathy with road noise and speakers, but doesn't really help with road noise itself (it won't stop tyre roar or exhaust noise coming through the floor or bulkheads)
So get some CLD down, some car underlay then the carpet. CLD inside door skins, and if your speakers are in your door, replace the moisture guard with as complete a layer of CLD as possible (makes a good difference to the door speakers)
If you really want to go to town on it, have a research of MLV and CCF on the floor. BUT: this is a proper job, you have to create a sealed layer under the carpet and the MLV is tough stuff. Tecsound is worth a Google as well
Don't use flashing tape, loads of people have but quite a few of these have had 'orrible smells and even melting in high temps
goldnrust
West Midlands
Minimalist
Mar 23, 2022 20:38:39 GMT
I've used the Dodo branded sound proofing products on my Daimler and been happy with the result. As mr2fc says, I'd avoid going the repurposed building materials route, I tried it once and was unhappy with both the reduction in sound and the smell!
thanks mr2fc lots of useful info there for me to look into. Cheers goldnrust - I had seen some people suggesting using flashband and similar but I think I would rather have a proper product that doesn't melt or smell, so thanks for the pointer.
Mar 24, 2022 10:42:54 GMT
I never minded the smell tbh. My dad used to be a roofer so I grew up with the smell of bitumen etc. Quite nostalgic.
mk2cossie
Club RR Member Number: 77
Mar 24, 2022 19:13:26 GMT
To the best of my knowledge, Brown Bread was bought out by Dynamat years ago. The bootlid of the Granny is covered with Brown Bread, and still holding up. (Was also cheaper at the time than Dynamat)
The front doors on my car i used a pack from Silent Coat, which had 4 sheets of sound deadening material, 1 sheet of foam, and 1 sheet of weather proof stuff for right behind speakers. All very nicely priced and I think nicer to work with than Dynamat
Other option is a spray on material like bed liner.
Paul Y
Mar 25, 2022 10:46:38 GMT
Use Kilmat. About £50 buys you enough to do your Cortina. Worth buying the roller to make installation easier. Used it on a friends 80's C10 and the difference was night and day - already purchased for use on Woody when I get to that stage. Biggest difference came when we stuck a few panels in the doors, remember that you don't need to completely cover the surface. P.
Mar 29, 2022 20:19:20 GMT
Thanks chaps, all useful. Kilmat is looking like the favourite at the moment.
617sqn
Club RR Member Number: 176
I use Dodomat. It's British, but made in the EU. Online purchase, cheaper than Dynamat by some distance.
AG
617sqn
I use Dodomat.
