mrbig
Semi-professional Procrastinator
Jan 26, 2022 16:39:37 GMT
I've been thinking about building a custom cruiser bike for some time now. Curved frame, decent stretch and a silly car wheel on the back. Doesn't seem to be many other such builds around, or at least I can't find pictures of one. For the sake of example, like this but much less dogshit, and pedal powered: I would probably stick with a bike wheel on the front (maybe a fat bike wheel) but I'm trying to figure out how to mount and drive a car wheel and hub on a single sided arm! Anyone got any ideas? Don't really fancy a leepu style spacer
Last Edit: Jan 26, 2022 16:40:01 GMT by mrbig
1969 German Look Beetle - in progress
adam73bgt
Club RR Member Number: 58
Jan 26, 2022 18:53:37 GMT
There seem to have been a few done with trikes, "stance trikes" I guess drivetrain is a bit easier with those as the front wheel and pedals is conventional, trying to get a chain around a wide car tyre could be tricky I'm sure I remember seeing a bike with a wide car tyre on the back but I can't remember where, might have imagined it!
Jan 26, 2022 19:18:16 GMT
This idea is not as crazy as it sounds. Keen to see more.
16grit
Jan 26, 2022 20:38:45 GMT
I've been thinking about building a custom cruiser bike for some time now. Curved frame, decent stretch and a silly car wheel on the back. Doesn't seem to be many other such builds around, or at least I can't find pictures of one. For the sake of example, like this but much less dogshit, and pedal powered: I would probably stick with a bike wheel on the front (maybe a fat bike wheel) but I'm trying to figure out how to mount and drive a car wheel and hub on a single sided arm! Anyone got any ideas? Don't really fancy a leepu style spacer For some inspiration maybe take a look at a swingarm from a Honda RVF400 NC35 bike, or something off a Ducati like an S4R...
Jan 26, 2022 21:43:06 GMT
I recall a scrapheap challenge had an episode making bikes, and the team who used car wheels found very strange behaviour in the transition from vertical to leaning over as the tyre profile has square edges compared to a bike tyre.
Jan 26, 2022 21:52:00 GMT
this is mine from a few years ago car rims with heavy duty spokes
Jan 26, 2022 22:21:46 GMT
I recall a scrapheap challenge had an episode making bikes, and the team who used car wheels found very strange behaviour in the transition from vertical to leaning over as the tyre profile has square edges compared to a bike tyre. Using car wheels doesn't necessarily have to mean using car tyres though.
Jan 27, 2022 10:20:34 GMT
Jan 27, 2022 17:39:04 GMT
Just from a weight point of view, I'd think a car wheel would make a pedal system very hard to get moving, and even harder to stop when you do? Think flywheel
mrbig
For some inspiration maybe take a look at a swingarm from a Honda RVF400 NC35 bike, or something off a Ducati like an S4R... Interesting. Hadn't thought of going that route. Chain size and pitch is going to need some consideration though!
mrbig
this is mine from a few years ago car rims with heavy duty spokes That looks really good. Did you use the 'flat' halves of two car wheels welded together? How did you figure out where to drill the holes for the spoke?
mrbig
Just from a weight point of view, I'd think a car wheel would make a pedal system very hard to get moving, and even harder to stop when you do? Think flywheel Compared to the rider, the weight would be minimal anyway I'll fully aware it will ride/handle like curse word. I just need a fun project for this year. The beetle resto has ground down my mental health and its just become a chore. I can't find an aircooled 2-stroke bike project I can afford, so I need to find something to do that I will actually enjoy getting my hands dirty with again.
Jan 28, 2022 11:04:19 GMT
Just from a weight point of view, I'd think a car wheel would make a pedal system very hard to get moving, and even harder to stop when you do? Think flywheel Compared to the rider, the weight would be minimal anyway Hi, Not necessarily, Or why does lightening a flywheel have such an effect on the same weight of vehicle? However I take your point of the project helping with your frame of mind, press on. Colin
Jan 28, 2022 11:22:47 GMT
Absolutely, what colnerov said Whatever gets you through the day Stick with it 👍
Jan 28, 2022 12:44:16 GMT
this is mine from a few years ago car rims with heavy duty spokes That looks really good. Did you use the 'flat' halves of two car wheels welded together? How did you figure out where to drill the holes for the spoke? the spokes took many hours of thinking, calculating and a few attempts with a pair of dividers but well worth it to get the finished look
Jan 28, 2022 13:04:21 GMT
How about a Citroen 2CV suspension arm & hub, maybe 2CV wheel fitted also...
Jan 28, 2022 13:50:57 GMT
How about a Citroen 2CV suspension arm & hub, maybe 2CV wheel fitted also... I'd been thinking along the same lines, but moped stuff because lighter(maybe....)
wu11ie
There's a few on YouTube
fredje8v
96 Daihatsu Atrai
Take a look at some sidecar builds, lot of times they will use a car wheel at the back (or at least a car tire)
93fxdl
Enter your message here...
Jan 30, 2022 20:11:33 GMT
I believe you could do with an easy win project, how about a psh bike restoration, then try fitting one of those bolt on engines, start to scratch the 2 stroke pitch, maybe then try a fat tyre conversion or maybe strapping another engine or two, give yourself a home built twin or triple or even a four, been having nasty thoughts about a micro square four If your head is in a bad place do not be too afraid or proud to seek professional help Ttfn Glenn
