v8jim
Sept 12, 2021 19:34:31 GMT
Max sig pic size: 80px
Sept 13, 2021 11:10:43 GMT
They don't make 'em like they used too ...
Sept 13, 2021 11:17:19 GMT
Damn! That's going to save so much aggravation.
vulgalour
Club RR Member Number: 146
1954 Austin Somerset MX5 swap vulgalour
@vulgalour
Club Retro Rides Member 146
Sept 13, 2021 11:33:22 GMT
Well that's just saved you a whole world of time and grief. The interior looks very salvagable and some leather conditioner on everything leather and leather looking, applied copiously and regularly, should bring back the spring and prevent them from degrading. You'll be able to use the leather conditioner on the vinyl looking bits since it'll be leathercloth. I'm not sure if the seat facings will be leather or leathercloth on these, it's probably leathercloth on the back and sides of the seats. Water getting in is probably the windscreen seal, that's one of the things I was warned about when looking for one. A cover will keep the weather out well enough until you can get a new seal. Poofing a bit of talcum powder around the interior will show up water ingress paths pretty quickly and help you trace it.
Looking forward to your adventures with this one and seeing what Lady V8Jim does to put her mark on it.
v8jim
Sept 13, 2021 12:34:44 GMT
Vulgalour - yes the seats are saveable, the leather is mostly intact but sadly there are a few holes. We’ve been doing some research into proper leather restoration techniques and that’s going to be a winter project we can do in the house. The sides and bases are leather cloth but I didn’t realise you can use conditioner on them, I will definitely be giving that a try.
vulgalour
@vulgalour
Sept 13, 2021 17:46:02 GMT
I only know because we gave it a go on the Lanchester. You don't get the same dramatic result as on leather but it certainly makes them a lot less brittle and crackly. It was the only way we could have got the old fabric to fit the new door cards without it all breaking up. Also, if you're dismantling the door cards to redo them, you can iron the leathercloth once moisturised to take some of the creases out, just make sure you use a teatowel between the cloth and the iron and set the iron low so you don't risk burning the surface. Take it slow too, and it's surprisingly compliant.
v8jim
Sept 13, 2021 19:20:03 GMT
I only know because we gave it a go on the Lanchester. You don't get the same dramatic result as on leather but it certainly makes them a lot less brittle and crackly. It was the only way we could have got the old fabric to fit the new door cards without it all breaking up. Also, if you're dismantling the door cards to redo them, you can iron the leathercloth once moisturised to take some of the creases out, just make sure you use a teatowel between the cloth and the iron and set the iron low so you don't risk burning the surface. Take it slow too, and it's surprisingly compliant. Top tips 👍🏻
v8jim
Oct 25, 2022 20:43:06 GMT
Well a whole year went past with no progress at all because of diy and building projects one of which was a workshop to put the car in Oh and I bought a donor car And got my engine crane out of dad’s garage ready to crack on and start pulling both cars apart
brc76
Oct 26, 2022 12:37:40 GMT
I don't know how I missed this earlier, but I'm following
v8jim
Oct 26, 2022 19:26:02 GMT
qwerty
Club RR Member Number: 52
1954 Austin Somerset MX5 swap qwerty
@qwerty
Club Retro Rides Member 52
Oct 26, 2022 20:17:22 GMT
What a fantastic project. With the MX5 running gear it'll be much nicer to drive long distance!
Tom
Oct 26, 2022 21:07:52 GMT
Wants a nice mgb engine box and axle
CaptainSlog
Club RR Member Number: 180
1954 Austin Somerset MX5 swap CaptainSlog
@captainslog
Club Retro Rides Member 180
I was going to suggest something with a transaxle to solve the gearbox issues but I see you are going the MX5 route - good luck with it, I look forward to following the build.
dazee
Oct 27, 2022 11:06:34 GMT
Good to see yet another oldie being rescued and updated. Will be following with interest.
Oct 27, 2022 20:14:41 GMT
I'm watching.
v8jim
Oct 27, 2022 20:20:18 GMT
v8jim
Oct 29, 2022 21:33:47 GMT
Put the Austin engine in the MX5 and sell it on. You've just invented the MGB. :-)
