v8jim
Aug 31, 2021 21:42:27 GMT
Last Edit: Oct 28, 2022 8:12:07 GMT by v8jim
Max sig pic size: 80px
Sept 1, 2021 12:21:20 GMT
Cool. Didn't know these came with a factory sunroof. Nice touch. Hopefully some MGB gear will be adaptable to the car.
Sept 1, 2021 13:30:45 GMT
Turbocharged T-Series and an LT77 will drop in there nicely.
v8jim
Sept 1, 2021 14:31:59 GMT
Not sure what I’m going to put in yet but I hadn’t thought about a T series
Sept 1, 2021 18:21:38 GMT
Mine also has a factory rain roof, the 1800 "B' series will fit if you modify the front chassis member, A70 Hereford differential, speedo' & brakes were the usual upgrades but hard to come by now.
v8jim
Mine also has a factory rain roof, the 1800 "B' series will fit if you modify the front chassis member, A70 Hereford differential, speedo' & brakes were the usual upgrades but hard to come by now. The B series is the obvious choice and with the right gearing should make a nice car but is it too obvious?? If I find one locally at a good price I’d probably buy it but can’t help thinking perhaps I should put something more unusual in it
MiataMark
Club RR Member Number: 29
Wouldn't the obvious (not very unusual) more modern choice be MX5 engine/gearbox?
v8ian
Zetec and Type 9, gearboxes are more expensive than the engines at the moment......
Mine also has a factory rain roof, the 1800 "B' series will fit if you modify the front chassis member, A70 Hereford differential, speedo' & brakes were the usual upgrades but hard to come by now. The B series is the obvious choice and with the right gearing should make a nice car but is it too obvious?? If I find one locally at a good price I’d probably buy it but can’t help thinking perhaps I should put something more unusual in it As the T-Series block is a mildly updated B-Series it should fit just as easily. The engine and dynamo (!) mounting holes, bell housing bolt pattern etc are the same.
200bhp out of the box should be 'unusual' enough.
I admit Sherpa van bits to mate up to an LT77 are getting a tad rare though. Maybe there are other options these days. I wonder if an ZFHP22 could be persuaded to play nicely with a T-Series?
whatever you fit it's going to be very tight to the front crossmember, looks like the x member may have already been cut in the engine photo?
Will watch this with interest, both my Dad & Grandad had a selection of Somersets and Devons over the years.
If you haven't already, I'd join the Austin Counties car club. A friend has an A40 Sport and I've been to a couple of excellent rallies with him and he says the club support is excellent.
75swb
Beta Tester
Club RR Member Number: 181
1954 Austin Somerset MX5 swap 75swb
@75swb
Club Retro Rides Member 181
Sept 2, 2021 10:07:24 GMT
Love it. Now if you could just sling a peripheral ported rotary in there that'd be ideal.
vanpeebles
I am eastbound in pursuit of a white Lamborghini, this is not a recording.
Sept 2, 2021 10:31:37 GMT
I'm more worried about what the dog did to that person's trousers!
v8jim
Sept 2, 2021 18:26:04 GMT
Wouldn't the obvious (not very unusual) more modern choice be MX5 engine/gearbox? Yeah definitely a good option if you can get a whole car for sensible money or find an engine with loom and ecu This has to be near the top of the potential list as I’ve wanted to use one for a while
v8jim
Sept 2, 2021 18:29:55 GMT
Zetec and Type 9, gearboxes are more expensive than the engines at the moment...... I know I’ve already been looking at prices
v8jim
Sept 2, 2021 18:40:03 GMT
The B series is the obvious choice and with the right gearing should make a nice car but is it too obvious?? If I find one locally at a good price I’d probably buy it but can’t help thinking perhaps I should put something more unusual in it As the T-Series block is a mildly updated B-Series it should fit just as easily. The engine and dynamo (!) mounting holes, bell housing bolt pattern etc are the same. 200bhp out of the box should be 'unusual' enough.
I didn’t know that about the T series (I don’t really know anything about them) I imagine they are not the easiest of things to find these days or parts for them
v8jim
Sept 2, 2021 18:42:54 GMT
whatever you fit it's going to be very tight to the front crossmember, looks like the x member may have already been cut in the engine photo? No it’s all stock nothing has been messed with yet but notching the crossmember a bit for clearance wouldn’t be difficult
v8jim
Sept 2, 2021 19:03:06 GMT
Sept 2, 2021 19:21:40 GMT
v8jim
Sept 2, 2021 19:57:35 GMT
Last Edit: Sept 2, 2021 19:59:57 GMT by v8jim
