Apr 11, 2021 20:34:26 GMT
Last Edit: Apr 11, 2021 21:15:38 GMT by chris74
Apr 11, 2021 20:42:41 GMT
Tungsten grey and turbine alloys, I'm in.
Good work, the Bodykits on these used to be great at hiding rot,same as most hot hatches of that era.
Awesome work, love a 80s/90s hot hatch!
Last Edit: Apr 12, 2021 8:25:06 GMT by felix2566
Norman
Great quality work, you’ll have it finished in no time. Will be watching with interest, Norman
Apr 12, 2021 11:07:05 GMT
Epic work, can’t wait to see it finished. Keep up the great work.
gazzam
Apr 12, 2021 17:49:25 GMT
chris74 said: Crikey, I didn’t think it looked that bad. Top job of making repair pieces. Good to see someone not afraid of cutting a car. Well done.
Last Edit: Apr 12, 2021 17:52:23 GMT by gazzam
Apr 13, 2021 11:25:32 GMT
Neat! Always had a bit of a soft spot for a 5. Had the opportunity to pick up a lesser engined version for £120 or so but ended up passing for a reason I can't remember.
Are they typical of French car soncstruction by being made up of lots and lots of multi-layered pressings of paper thin steel? I've worked on a fair few 90s Peugeots that all seem to be made that way, and my BX is as well. Not sure if it extends to Renault as well..
Apr 25, 2021 18:33:08 GMT
Neat! Always had a bit of a soft spot for a 5. Had the opportunity to pick up a lesser engined version for £120 or so but ended up passing for a reason I can't remember. Are they typical of French car soncstruction by being made up of lots and lots of multi-layered pressings of paper thin steel? I've worked on a fair few 90s Peugeots that all seem to be made that way, and my BX is as well. Not sure if it extends to Renault as well.. Ha ha, yeah they are made in exactly the same way, multi layers of paper thin steel! an absolute nightmare to weld, especially when you have never used a welder before! but getting there with the welding now......i think!! Thanks for reading the post.
Apr 25, 2021 18:44:51 GMT
With those wheels it already looked awesome!
Looks like you caught it as late as you’d want to, the frilly bits were still enough to use as patterns, looking forward to seeing this progress
Apr 25, 2021 19:15:55 GMT
rickygolf83
Mk2 Golf 8v & 16v, VR6, Nova Antibes, Mk4 1.8t & mk4 Gt Tdi 130
Some amount of fabrication work so far man 👏
Bookmarked 👌
Impressive work, I'm subbing to this thread.
Apr 26, 2021 16:04:03 GMT
Hi, Some impressive welding and fabrication work here, This is the sort of thread I love to follow, Please keep the updates coming, Nigel
Last Edit: Apr 26, 2021 16:04:44 GMT by Alpina99: Misspelling,
Apr 26, 2021 16:15:03 GMT
Great to see this being brought back from the brink. Can't quite believe you're a complete amateur to this welding malarkey as your work looks pretty professional to my untrained eye!
If at first you don't succeed........ ....Don't try skydiving!
Apr 26, 2021 16:21:36 GMT
Hehehehehe
Norman
Apr 26, 2021 17:30:45 GMT
Your making a grand job of that, good fabrication of some complex repair panel shapes. Good to hear you are nearly finished the welding. All the best, Norman
Apr 27, 2021 14:26:03 GMT
Hi, Some impressive welding and fabrication work here, This is the sort of thread I love to follow, Please keep the updates coming, Nigel Thanks Nigel, appreciate your aking the time to comment.
Apr 27, 2021 14:47:59 GMT
Great to see this being brought back from the brink. Can't quite believe you're a complete amateur to this welding malarkey as your work looks pretty professional to my untrained eye! Thanks Adam, I am teaching myself to weld as I go along, plenty of you tube vids (@fitzees Fabrications & Trevs Blog) two great sources of info. I have had my fair share of blow throughs and am now considering going over my earlier work as I'm now not happy with it I'm sure once the epoxy paint is on, no one will know!!
Apr 27, 2021 14:49:32 GMT
Hehehehehe Ive never looked at this like that......some people's minds are one track!!
