qwerty
Club RR Member Number: 52
So for years I have really wanted an Aircooled Beetle. For one reason or another its never really happened. One of the Bugs that I've always lusted after is my friends and MOT testers Dads Bug. He built it in the early 00's and then used it up until '11 when it was parked in the garage and left. Tom and his Dad have now moved on to American stuff and Harleys. So they finally decided to let it go. I went and viewed it and there was a little more rust than I expected. So then I freaked out for a few days. Before my wife, brother and a couple of mates told me to stop being a fanny and just buy it! So I did, and I got what I think is a smoking deal. Picked it up today Then it got dropped into the workshop So what I've got/think I've got: Back Dated 1973 Beetle Pre '67 Wings Split screen Style Deck lid Smoothed Dash Re-sprayed Rover Nightfire Red D ring Steering wheel Blade Bumpers (currently unfitted) Retrimmed interior EMPI 5s on Adaptors Beam adjusters Red Shocks 1600 Barrels and Pistons on 1300 Kadron K300. I'm pretty chuffed to say the least. Plan is to sort the rust out that it has, go through the running gear and get it reliable. After that I have quite a few things I wanna do. Narrowed beam, wheel change, engine swap etc etc.
Last Edit: Dec 27, 2020 9:56:23 GMT by qwerty
shin2chin
Like mine but much better! What do you need to weld?
qwerty
So first thing I did was to strip out all the interior: Lets get digging at that rust Got to say it is no where near as bad as I was expecting. The Heater channels seem decent. The battery tray is solid, the passenger side floor pan is decent enough. The not so good bits are the drivers side floor pan and the rear corners. Tomorrow I'm going to hit them with the grinder and see how much worse it gets, then I can decide on how best to tackle it.
qwerty
Like mine but much better! What do you need to weld? Interior corners where everything meets the rear wheel arches and some on the floor pan. I've been really enjoying your thread. Tom
Congratulations - what an awesome bug! (although I am a bit biased as I love air cooled VWs)
The rust doesn't look that bad, I've seen a lot worse. Doesn't look like too much work to have that beauty back on the road. Looking forward to regular updates on your progress.
Currently driving a 1972 BMW 1602 as my daily. Don't ask about previous cars - there have been way too many and I stopped counting at 160!
Great start you got there. Very cool.
Congratulations I am very pleased for you. I restored a 63, and owned a restored 59 in my past. Beetles are pretty special. And actually incredibly well catered for. disasterbus will probably know where to point you to as well, and craigrk will be along at some point. I will be following this build.
THTS ALL VERY EASY AND CHEAP TO FIX HAPPY FOR YE I HAVE A 78
HAVEN TO REDO THE OTHER PERSONS MESS
qwerty
Thanks for the replies everyone.
I'm hoping to not have to get into a proper body off resto at the moment, but I dare say that will happen in a couple of years.
The frame head bottom panel has been previously patched and although its solid its untidy so eventually I would like to flip the pan, replace that and then properly strip the whole thing and repaint it.
Tom
Last Edit: Dec 5, 2020 8:37:57 GMT by qwerty
Nice project, I've always fancied a beetle myself. Bookmarked!
qwerty
So after fixing my Polo this morning I thought I better get on with the Beetle a bit. Its at this point I've realised that I'm really bad at taking photo's of progress. So first thing I did was hoover all the floor pan out, which exposed a few more holes in the driver side. I'm definitely swaying more and more to just replacing this entire side: I then gave the passenger side a good wire brushing. Really happy with how solid it is. So I gave it a good coat of Kurust: Then I decided to tackle the rusty corners and start to see what I was dealing with. This is where I could have done with taking a load of pictures to get peoples opinions and I didn't! So here is one side after I dug out a load of filler and hit it with the knotted wheel. I have then cut some more of it out. Pretty much along those lines. There has obviously been some MOT over patching going on. So I need to cut that out. The body mount panel is solid. So i'm not sure whether to buy the whole inner arch panel and just use the bottom bit of it. It'll save some fabrication, but in reality I'm not going to use much of it. The other side I didn't get any photo's of the inside, but got these from the inner arch: So the inner arch is holed and there is a hole in the body mount panel. It has also holed down in the bottom left corner of the body mount panel. I'm not sure whether its worth replacing the whole panel, or just patch repairing from behind and then patching the inner arch over the top of it so it still remains double skinned. What are peoples thoughts? When I say patch repair I don't mean MOT over patching, but proper cut the rust out and let it some fresh steel. All in all I think its faaaaar better than it could have been. I had visions of me hitting it with the wire wheel and losing most of the rear crossmember, inner arches and heater channels!
hopeso
Patch and repair is the quickest way of getting the car back on the road. Less chance of getting it distorted too.
qwerty
Last Edit: Dec 5, 2020 18:39:10 GMT by qwerty
HERES THE ONES YOU WANThttps://www.heritagepartscentre.com/uk/111801201ad-rear-crossmember-left.html
Last Edit: Dec 5, 2020 18:50:04 GMT by shielsy68
Looks like a good project. I would say the wheels are one of the best parts of it - I'd be keeping them!
qwerty
Excellent cheers! Do you think Heritage is the best place to buy from? There's quite some lead time on some of the panels I've been looking at. I've also been on Machine 7, any other suggestions of people to check out? Cheers Tom
