Paul
Jul 27, 2020 21:47:15 GMT
Evening all, Thinking about swapping out the wheezy, ancient engine in my Twingo for a modern unit. I've seen a few 1.6 K4M engines swapped in which will more than double the bhp, which sounds like a lot of fun. I toyed with the 172 but the one person who did one had to make almost everything from scratch, whilst the 1.8s are veeery pricey now. Thing is, I've never attempted an engine swap before. I'm reasonable with a set of spanners and am willing to tool up appropriately, but I fear I'll end up all at sea pretty quickly. Currently considering buying a whole car as a donor, because the K4M lump has been around for years and I'll probably need the improved braking and gearbox anyway - but fabricating engine mounts and wiring looms seems pretty daunting. I think I may have to learn French as the few videos that exist are not from these shores. Any guides pointing me in the right direction or just general words of encouragement greatly appreciated! Le pics as inspiration of course
mk2cossie
Club RR Member Number: 77
Jul 27, 2020 21:55:41 GMT
I seem to recall the K4M is in Clio and Megane of the era? Not a bad little engine, although possibly as much of a squeeze in a Twingo as the 172/182 engine is.
How about trying to get hold of the 1.7 injection lump from a Renault 5?
Paul
I seem to recall the K4M is in Clio and Megane of the era? Not a bad little engine, although possibly as much of a squeeze in a Twingo as the 172/182 engine is. How about trying to get hold of the 1.7 injection lump from a Renault 5? Yup, although I’m having a lot of luck with Scenics too...all variations I think that may be a big ask, and 1.6 Renaults are going on FB for scrap money. Besides, if these cheese eating surrender monkeys can do it I reckon I could have a stab.
Last Edit: Jul 28, 2020 6:19:37 GMT by Paul
goldnrust
West Midlands
Minimalist
I'm afraid I don't have any Renault specific advice or experience, but I had done an engine swap, and helped friends with theirs also, so have some general thoughts that might be helpful. In general I'd say it's perfectly possible with some normal tools by someone who's mechanically competent and has the right attitude. I will add to that, that a welder and some basic fabrication skills makes things so much easier. You will also need an engine crane. In my head there's several stages to an engine swap. Firstly there's the 'Will it fit?' question. To an extent any engine will fit in any car, but most of us don't want to be chopping the body shell up to make the engine fit really. Skipping through that video, it looks like the engine fits in that space ok. Next you've got to mount the engine in place. If you're lucky and doing a same brand engine swap then there's a chance you can mix and match engine mounts from different models and it will bolt in. I know, for example, there's various VAG group stuff where you can do this. But for most engine swaps that will mean fabricating some engine mounts and that means having the right welding/fabricating skills, or being able to call in some favours. When I did my 13b rotary engine swap into my Mx5 about 10 years ago, I couldn't weld, but was able to get one of my Dad's colleagues who was a professional fabricator to do it for me. He did a great job, but I will say the process of having to do all the measuring and drawing out, then deliver the engineless car to him to have the mounts welded up, then get the car back and fit the engine, then take parts back to be modified, and so on, was slow and frustrating. If I had been able to weld and could have done it on my driveway with the ability to drop the engine into place and lift it back out to check it's all lining up as I go, it would have been much easier. Scanning that video, it looks to me like they've welded up some new engine mounts, so probably not a bolt in type swap. So really you either need a mate who's gonna be happy to spend some days helping you, or you're going to have (or learn) those welding skills. Now in YouTube/SEMA world, thats the engine swap done. In the real world, you've only just begun. But it's not necessarily that difficult. You now just need to work through each of the engines systems, working out how you're going to join the new engine to the car. So driveshafts, gear shifter, cooling system, fuel system, wiring, etc. Some of this may be simple, like the engine mounts you might find that you can use driveshafts from either the new engine, your original car or can find another model from the manufacturers range that has the combination of dimensions you require. Or you might find that you need to have custom ones made up, which can add cost and complexity to a swap. How you do the wiring is up to you, you see various solutions from the long winded and expensive route of stripping the original loom back removing the wires you don't want, adding new wires you do want and hooking it all up to an aftermarket ECU for a factory like install, through to just tucking the old loom out of the way and putting an entire second loom and factory ECU that matches the new engine and having that zipped up under the dashboard. Either way you will need a plan to make it work, and if that included using the stock ECU from the new engine, it means knowing about any issues with immobilisers/check engine lights/etc. It's all possible, lots of people on here have done successful engine swaps, and often the only way to learn is to jump in and go for it. You have to expect that it's going to take 3x longer than you estimate (and probably cost 3x as much) and that there will be challenges along the way. But if you're up for the challenge go for it
Paul
That's a really useful post goldnrust - thanks! Have always wanted to learn how to weld - like you I spy the freshly painted engine mounts in the vid. I work in a school so I'm hoping that a French teacher might help translate. I also happen to know a happy welder in hairymel who takes payment in cheap whiskey and cheese. I'm hoping the simplicity of the Twingo will help a lot with cutting back electrics - No PS or airbags for instance - but I imagine any newer engine will have an immobiliser to defeat.
mk2cossie
Jul 28, 2020 16:29:34 GMT
Also, if the bellhousing pattern matches and you can retain the Twingo gearbox, thats driveahafts, clutch and shifter mechanism ticked off the list to start with
Jul 28, 2020 17:18:11 GMT
are there any English language forums you could read a similar build thread on?
In the VAG world a 1.8t into a mk2 golf swap has been fully documented on a few different forums, you can even read the parts lists on one I've seen.
But, that conversation is very very common, maybe not the same with your car?
Paul
Jul 28, 2020 18:05:15 GMT
Also, if the bellhousing pattern matches and you can retain the Twingo gearbox, thats driveahafts, clutch and shifter mechanism ticked off the list to start with Thanks for the heads up... I've got my eye on an early Scenic with the 1.6 K4M as a donor. Reading that they will be fitted with a JB3 gearbox, whereas the Twingo will have the JB1...some conflicting information on whether the JB3 and 1 bellhousings are the same although most of the internet suggests the only difference is in gear ratios. By this logic I should be able to use the Scenic box but the Twingo driveshafts...wondering if I could pilfer the brakes off the Scenic too as they're bound to be better than that dinky solid discs on the Twingo. This could well be one potential problem overcome... I'm off to join a Clio forum to confirm.
Paul
Jul 28, 2020 18:35:00 GMT
are there any English language forums you could read a similar build thread on? In the VAG world a 1.8t into a mk2 golf swap has been fully documented on a few different forums, you can even read the parts lists on one I've seen. But, that conversation is very very common, maybe not the same with your car? I cut my teeth on the VAG scene and even had an ABF 2.0 16v Mk2 Golf once upon a time...I was working on a Mk1 ABF conversion that was tragically cut short by a burny burny fire incident I don't like to speak of. I've been hammering Google translate recently but only come up with occasional very short videos...but very little written down. I'm going to keep looking though as I know these cars are common, cheap and have a good following overseas so there must be info out there.
