Apr 13, 2020 23:04:10 GMT
I always use the goggles like you used to have in the science lab at school. No way for anything to bounce up into your eyes.
Had splinters took out a few times after many years of being a surface grinder. Work was never too hot on PPE.
Phil H
Club RR Member Number: 133
I always use the goggles like you used to have in the science lab at school. No way for anything to bounce up into your eyes. Had splinters took out a few times after many years of being a surface grinder. Work was never too hot on PPE. I’ve got 3 or 4 pairs of those dotted around the place as I’m a sod for putting them on fit a job on the bench, walking back to the main job/car, taking them off...well, it’s the same as all sockets migrating from the drawer to the same point under a car..
goldnrust
West Midlands
Minimalist
Apr 14, 2020 18:20:22 GMT
Another vote for the school type googles when using a die grinder, or even just normal grinding in more confined spaces. Being able to see the chap at A&E digging around in the surface of my eye, to remove the stray grinder spark that had lodged itself just on the edge of my pupil, was a little unsettling!
I also recommend a narrow belt sander/power file, but also I've gone one step further and stopped caring quite so much about tidying up welds, especially where it's not really visible. I've spent far too long over the years cleaning up welds that are out of sight underneath cars! Life's too short, haha.
I'm enjoying watching this come together, looks like when the inlet manifold is sorted then the bulk of the hardworking will be done?
Last Edit: Apr 14, 2020 18:21:35 GMT by goldnrust
Phil H
Apr 14, 2020 19:52:04 GMT
Having had a detached retina luckily re-attached (albeit with blurry vision in that eye) I take no chances when it comes to eye protection nowadays. Should anything happen to the good eye, I’m stuffed.
Certainly focuses the mind - no more “I’ll just grind that little bit off again” or “just one more hole to drill”. It may take another couple of minutes to do a 20 second job, but it’s a lot quicker than a wait in A&E or walking because you can’t drive any more..
Apr 16, 2020 16:16:51 GMT
I'm glad to see you're progressing, with regards to your eye if you think you've got something in it sort it.
I've been there myself... 3 times!
moglite
Club RR Member Number: 144
Apr 16, 2020 19:33:16 GMT
I'm glad to see you're progressing, with regards to your eye if you think you've got something in it sort it. I've been there myself... 3 times Thanks - no my eyes are 100% at the moment, and hopefully will stay that way.
Apr 16, 2020 20:37:15 GMT
Apr 16, 2020 20:38:29 GMT
Apr 16, 2020 20:39:01 GMT
Hmm can’t make the links work :-(
lesgrandepotatoDon't paste directly, use the add image button under full reply mode. But also your sizing is huge, so under BBC tab change max width to 60% or so.
Last Edit: Apr 17, 2020 4:44:33 GMT by varelse
moglite
lesgrandepotatoI see you are an imgur user - like me. From the imgur website, just copy the BBcode Then paste it into your reply on RetroRides Why don't you start your own thread ? The world needs more home brew supercharger threads
Apr 17, 2020 11:00:53 GMT
Moglite. Will do :-)
moglite
Apr 18, 2020 20:39:41 GMT
Busy afternoon in the garage. The shorter belt turned up, so a proper tensioning of the belt, pretty happy with the belt line Can't put off the inlet manifold any longer. Stainless wire in the MiG and a new belt on the linisher and we are good to go. Set up a simple jig on the work bend to get the starting point of the head flanges, nice'n'square. Mock up the horizontal piece, over size, and then it is easy to measure the excess and trim down to suit. I like to use aluminium tape to hold things in place - as sticky as, and doesn't catch fire. Lots of welding and some grinding of the welds back, and this is where I'm at. The blow off valve is positioned to be as far away from the exhaust manifold as practical. It might have been neater if the horizontal section was a smidge lower. But that was as tight as I could cut the mandrel bends, and also I wanted the inlet as far from the exhaust manifold as possible to keep the charge temperatures down. A view from the other side. I really wasn't looking forward to welding the 10mm stainless flanges to the 1.5mm thick piping, but it was fairly easy to weld. But dealing with the distortion was a pain. Looks messy, as I got bored dressing the welds, and as that is 12 pieces, it'll take me a while. But I can see it is going to come up quite well. All the welding is done now, bar a barb for the pressure gauge. Also I guess I need to add a 2nd barb for the rocker breather. But that'll do for now.
Apr 19, 2020 12:13:13 GMT
Doesn't the rocker breather need to go before the supercharger or you'll pressurise the crank case.
And if the blow off valve operates it'll spill fuel/air mix as this is a draw-through set up isn't it.
Not trying to trip you up, just save some pain.
moglite
Apr 19, 2020 22:18:37 GMT
Doesn't the rocker breather need to go before the supercharger or you'll pressurise the crank case. And if the blow off valve operates it'll spill fuel/air mix as this is a draw-through set up isn't it. Not trying to trip you up, just save some pain. A good point on the breather. My servo kit has a one way valve, maybe I need something like that. I was reluctant to put oil mist before the supercharger, who knows what that will do to the seals. The blow off valve should only operate if there is a miss-fire, I'm hoping that doesn't too often. Not tripped up at all - all good points - appreciated.
Apr 20, 2020 10:11:47 GMT
The blow off valve is similar to what used to be known as an air box saver in the early days of LPG, just a rubber that will come unseated on the event of a back fire.
moglite
Apr 20, 2020 11:04:27 GMT
melle
South West
It'll come out in the wash.
Apr 20, 2020 16:59:27 GMT
The thread title makes me smile every time I see it! Great project.
vanpeebles
I am eastbound in pursuit of a white Lamborghini, this is not a recording.
How long before running?
moglite
How long before running? No time soon alas, things like radiator and exhaust are going to be tricky to sort quickly under lockdown. I've also got the bodywork to finish on the car. But I'm still making progress with the loose ends. Working on the boost gauge currently
