I’m in for this, just getting going with a Shorrock install on an A series That's a rare beast! what condition is the supercharger in? Well... it spins freely, and I’m assured it’s good. The chap I bought it from used it as a spare for his speedway bike... seems to have all the mini manifolds so I’m sorting out mounting and an inlet manifold.
moglite
Club RR Member Number: 144
Feb 18, 2020 21:34:47 GMT
So I want to simplify the wiring and nonsense in the engine bay. Adjustable ignition will help with the supercharger install, so I'm going with an early suggestion of going with NoDiz. That needs a trigger wheel for a crank position sensor. If I were going this again, I'd get a trigger wheel cut to spec, as this was tricky. Plan A was a generic trigger wheel, and part it off in the lathe to get a 145mm diameter hole in the centre, Boudica would have been proud of this, it even looked dangerous to me, so I hung a big curtain, and stood well back. But my little lathe struggled to part off 5mm steel. So before that got flung into orbit I tried something else. With a good groove to act as a marker, I thought a jigsaw might work well - it didn't I didn't have a 145mm holesaw, and nothing close was available easily - plan C was therefore a non-starter. Plan D was my newly purchased Lidl plasma cutter. I tried a smaller hole using a plywood template to get my eye, and settings dialed in. Just as well I had a practice, as the first attempt was a pigs ear. But the second attempt would clean up tidy enough. Cleaned up and tacked onto the back of the bottom pulley. I'll add more weld later when I'm 100% it will work. Here it is in place, with the engine set to TDC I believe NoDiz needs the missing tooth on the trigger wheel 90 before TDC. There are a couple of handy looking bolts on the engine, that look ideal to take a sensor bracket. That should be an easy fab job. Then I can spin the engine over, and check it does its job. Thanks for looking
Feb 18, 2020 22:52:31 GMT
Do you need to worry about that pulley being out of balance?
moglite
Feb 18, 2020 23:07:27 GMT
Do you need to worry about that pulley being out of balance? Yes I do. I plan to get it balanced - I've found a place close to my work - fingers crossed they'll sort me out.
I mean, it wasn't that I didn't have faith in your ability to clean up the plasma cut edge... But Looks like there's a few handy bolts to mount a sensor bracket on.
moglite
Feb 21, 2020 12:36:05 GMT
The stainless mandrel bends finally turned up. So lets mock up the inlet manifold Some of the runs will be shortened to "tighten" it all up a little, but I didn't want to start cutting stuff to size just yet. Here it is roughly suspended in place. And a couple of other views Do you think that will work okay ? Well once the racer tape is replaced by welds, and the cardboard by stainless The boss on the top is for a Shorrock style relief valve, which I'll probably get set to about 14PSI I'll also need a barb for a pressure gauge, but that is easy. Am I full steam ahead with this design
moglite
Feb 21, 2020 16:09:02 GMT
Oh and eBay had a 5% off coupon today. So I've ordered the NoDiz kit and the blow-off valve. Hopefully that should be the last of the big ticket spending.
mat88
Yorkshire and The Humber
Feb 21, 2020 17:01:51 GMT
I can't help with anything on this as superchargers are like black magic to me haha. I'm a turbo person much simpler lol.i do have a mate who is in the early stages of getting stuff together to supercharge his V8 so some of this may well be interesting to him. Especially with the pulleys and the maths. Il point him this way.
My question is what are the Chinese lathes like. Do you have any links to were to get them from. I'm not expecting commercial quality but are they"good enough" for home projects
Cheers
Feb 21, 2020 17:58:39 GMT
That dump valve - won't it be dumping rather combustible fuel/ air mix into a hot area?
Can you pipe it onto the floor maybe?
moglite
Feb 21, 2020 23:05:31 GMT
I can't help with anything on this as superchargers are like black magic to me haha. I'm a turbo person much simpler lol.i do have a mate who is in the early stages of getting stuff together to supercharge his V8 so some of this may well be interesting to him. Especially with the pulleys and the maths. Il point him this way. My question is what are the Chinese lathes like. Do you have any links to were to get them from. I'm not expecting commercial quality but are they"good enough" for home projects Cheers The Chinese lathes get a lot of love with model makers and the like. I like mine, but I spoiled it putting on a cheap toolpost - that has now broken, so I'm going back to the original. I'm pushing mine too hard with 6-7" pieces of steel, but for smaller stuff or softer materials, it isn't bad. I didn't want a project lathe, and fully variable speed and working straight of a 13Amp plug made it a winner for me. I got mine via these people Amadeal but on their eBay shop as I had a voucher and a bunch of Nectar points to cash in. Hope it helps
moglite
Feb 21, 2020 23:10:00 GMT
That dump valve - won't it be dumping rather combustible fuel/ air mix into a hot area? Can you pipe it onto the floor maybe? I did wonder about that. Hopefully it'll never vent... but if it does...... Putting it where I have, it might vent out of the louvres I've put in the bonnet if I'm lucky. The whole passenger side of the engine is iffy due to the exhaust manifold. If I routed it to the ground, would I not be making a trap for petrol to condense and drain into Tricky one
lebowski
Hillman Avenger, Clan Clover
Is a dump valve required? Isn't the carb/throttle on the supercharger inlet?
mat88
I can't help with anything on this as superchargers are like black magic to me haha. I'm a turbo person much simpler lol.i do have a mate who is in the early stages of getting stuff together to supercharge his V8 so some of this may well be interesting to him. Especially with the pulleys and the maths. Il point him this way. My question is what are the Chinese lathes like. Do you have any links to were to get them from. I'm not expecting commercial quality but are they"good enough" for home projects Cheers The Chinese lathes get a lot of love with model makers and the like. I like mine, but I spoiled it putting on a cheap toolpost - that has now broken, so I'm going back to the original. I'm pushing mine too hard with 6-7" pieces of steel, but for smaller stuff or softer materials, it isn't bad. I didn't want a project lathe, and fully variable speed and working straight of a 13Amp plug made it a winner for me. I got mine via these people Amadeal but on their eBay shop as I had a voucher and a bunch of Nectar points to cash in. Hope it helps Thanks. Yeah I saw those one eBay wondered if it was the same ones.. I do a bit with models/RC stuff too and had seen them before. I'm not expecting to be turning down foot thick billet tool steel with it. It was more just for little jobs (I've had to modify an alternator pulley for my v8 and this would have been perfect).. Il keep an eye open for the special offers on eBay and see what pops up. Cheers and good luck with the project!
The Chinese lathes get a lot of love with model makers and the like. I like mine, but I spoiled it putting on a cheap toolpost - that has now broken, so I'm going back to the original. I'm pushing mine too hard with 6-7" pieces of steel, but for smaller stuff or softer materials, it isn't bad. I didn't want a project lathe, and fully variable speed and working straight of a 13Amp plug made it a winner for me. I got mine via these people Amadeal but on their eBay shop as I had a voucher and a bunch of Nectar points to cash in. Hope it helps Thanks. Yeah I saw those one eBay wondered if it was the same ones.. I do a bit with models/RC stuff too and had seen them before. I'm not expecting to be turning down foot thick billet tool steel with it. It was more just for little jobs (I've had to modify an alternator pulley for my v8 and this would have been perfect).. Il keep an eye open for the special offers on eBay and see what pops up. Cheers and good luck with the project! You could try here too - unsure how they compare on price www.warco.co.uk/12-metal-lathes
moglite
Feb 23, 2020 15:02:03 GMT
Is a dump valve required? Isn't the carb/throttle on the supercharger inlet? I don't think it is a dump valve in the fast'n'furious tutbo style. More like a device to protect the supercharger from a mis-fire or anything else unplanned.
Feb 23, 2020 16:00:06 GMT
It’s not a dump valve per se, it’s a backfire control valve. Presumably to vent the pressure from the inlet manifold when its all gone south. I’m not sure you can set the pressure on them? I assume you bought it from Oldspeed?
moglite
Feb 23, 2020 18:15:34 GMT
It’s not a dump valve per se, it’s a backfire control valve. Presumably to vent the pressure from the inlet manifold when its all gone south. I’m not sure you can set the pressure on them? I assume you bought it from Oldspeed? Very true - but I bought mine from Danbury Hydraulics via eBay They are setting it to 14-15psi for me
Feb 24, 2020 19:00:01 GMT
Guess it being calibrated to the boost makes sense. 7psi spiking on gear shift, will be quite different to 11psi spiking
moglite
Not too much progress on this, as that annoying thing called work got in the way. The NoDiz turned up, and has been stashed away safely. But I found a little time to make the crank sensor bracket. Take a hunk of old box, and cut out a section. Bolt on the roughly hewn bracket and use a pilot drill to check the placement. I cut the bracket to a more appealing shape, and added some holes for detail. To get the clearance close, I welded on a boss. Slotted holes allow some fine adjustment. Bolted in place - looks like it will do the job Thanks for looking
