Hello everyone As the thread tittle suggests: What is the difference between Volvo 740 and 940? I am really strugling to see what the diffrence between the two is besides the grill and headlights, anyone here who can help pointing them out? I always fancied the 740 but now I'm no so sure why i ruled out the 940.. 740 940
Cosmetically, that's about it. There's a bit more rake on the rear of the saloon (not the estate). Dashboards are a bit different and there are a few minor mechanical refinements, but there's not a lot different on them at all. Not enough to warrant a name change really, just a very minor facelift.
Specialist Bodyshop & Fabrication Classic, Retro, Prestige & Custom Small Repairs to Concours Restorations Mechanical Work Vintage to Modern
Aug 22, 2019 10:07:49 GMT
940 is 1cm wider and up to 7cm longer. The 940 is also somewhat heavier, (think lardy extra adult).
Aug 22, 2019 11:11:59 GMT
Aug 22, 2019 12:28:09 GMT
The last year or two of the 740's actually have the same front end as the 940. As said, it's almost just a name change, but there are other revisions and engine & gearbox changes throughout the years. If you want a turbo model, you'd find it easier to get a 940.
1988 740 Turbo, 1998 V90, 1991 Eunos Roadster.
Aug 22, 2019 12:41:18 GMT
The last year or two of the 740's actually have the same front end as the 940. As said, it's almost just a name change, but there are other revisions and engine & gearbox changes throughout the years. If you want a turbo model, you'd find it easier to get a 940. Thanks, that explains alot..
fogey
Aug 22, 2019 13:19:39 GMT
200
Aug 22, 2019 17:37:40 GMT
Can be converted into something really special That's a 240 isn't it?
Aug 22, 2019 18:03:58 GMT
Other differences - how many remain on UK roads: 740 - 1,245 940 - 1,743 760 - 208 960 - 951 Unfortunately I have been unable to locate UK sales figures of any model to generate a percentage of surviving cars. If you are interested in the 700 / 900 series I'd suggest the 760 / 960 would be the one to have. Also, being on the continent, if you have deep pockets you'd be able to source the handsome 780 Bertone Coupé;
Last Edit: Aug 22, 2019 18:25:38 GMT by MkX
tofufi
South West
Aug 22, 2019 18:30:55 GMT
The last year or two of the 740's actually have the same front end as the 940. As said, it's almost just a name change, but there are other revisions and engine & gearbox changes throughout the years. If you want a turbo model, you'd find it easier to get a 940. Actually, the 740 facelift cars have headlights and grilles which look almost the same but aren't interchangeable. Late 760 bits, I believe, are the same as 940s - certainly different to 740s. I have a late 700, and there are not too many differences between it and an early 940. Volvo liked to change parts which can lead to frustration as parts can look identical but be subtly different. I've done 30k+ in my estate, it's a diesel and averages more than 45mpg on long runs. Just go careful... mine's so good my brother (not a car person) ended up with one too... His one has more than 280k miles on it and still going far better than the E46 BMW it replaced Edit: Forgot to mention, there seems to be a lot of variation on spec in the UK. Mine has climate control, cruise control, cupholders in the armrest, locking diff, but all these options tend to be rare in the UK. Most have a fair spec for the age including heated seats with lumbar adjustment, and heated electric mirrors.
Last Edit: Aug 22, 2019 18:37:15 GMT by tofufi
Aug 22, 2019 19:45:42 GMT
wasnt the 940 also galvanized so it wouldnt rust unlike the 740?
2001 vauxhall corsa 1972 VW Beetle 1986 Ford Capri Laser1999 BMW E36 323i Touring 1991 Volvo 940 estate 2002 Mazda 323f 2.0 sport 2016 Mercedes Sprinter 1999 nissan almera 1.4 1995 lexus gs300 1995 lexus ls400 1975 bmw 1602 fiat punto 2003 ford fiesta something else...
The 940 had IRS whereas the 740 was blessed with a solid axle.
tofufi
South West
wasnt the 940 also galvanized so it wouldnt rust unlike the 740? Certainly later, if not all 740s were galvanised. That said, any 30 year old car is likely to have a few bits which could need welding, galvanised body or not.
tofufi
South West
The 940 had IRS whereas the 740 was blessed with a solid axle. 940 (and 740/760) estates have the solid axle. Not sure about saloons, but 760 saloons definitely have IRS. The 900 series IRS was different to the 760 IRS rear end
Aug 23, 2019 15:21:40 GMT
I really would like a 740 estate when i at some point get rid of my fiat panda Here if they are old enough, gets really cheap in road taxes. they do however have to be 35 years old before that happens. Saw on the street the other day, and that boxy shape really is looking good these days!
Aug 23, 2019 15:48:54 GMT
that boxy shape really is looking good these days! I already like them back in their days. When they came out they looked very american-ish, like Cadillacs of that time or such.
steveg
Aug 23, 2019 17:35:02 GMT
Early 940s were virtually the same as late 740's but the newer you get the more safety/emission stuff you get. There was a facelift in around 93 which introduced airbags and associated mods to seats and mountings and then in 95 some wiring changes were made, the main one was that they went from two fuel pumps to a single in tank one. One thing you could get as a 740 was the 16 valve engined model. It depends on what you are looking for really. One thing to bare in mind is that although they have survived well they do still go rusty.
Aug 23, 2019 22:36:03 GMT
Yup, they do like to rust! My now dead 740 on 151,000 miles had rotten chassis rails that needed attention before its 18th birthday. However, it burned down (I suspect due to a known electrical issue on the earlier 740s), so of course, it could be fixed. Given the prices of the 740s I'd consider a W124. They're a nicer drive, look a little classier, with easier parts availability and IME better dealers which is handy for dealer-only spares ;trim for example. I liked my 740s, but they were a bit meh to drive. Yes, you can drift them and tune them, but other cars will get you there and with better results for less cash now .
MrSpeedy
East Midlands
www.vintagediesels.co.uk
Aug 25, 2019 10:31:10 GMT
I've been driving this for nearly a year now. It's a '96 960. As a car it's done all asked from it. Including towing a car on a trailer. The 3.0 straight 6 is lovely and smooth and the transmission more so. The interior is like a gentleman's club and it's a comfy old barge. Just not very exciting, although it will go well if you plant your right foot in the carpet (whilst watching the fuel gauge drop! 😆)
