Mar 29, 2021 15:24:03 GMT
The retest has gone exceedingly well, so much so I haven't even made it there. You have to laugh, don't you. Don't you? Pulling across the roundabout in the back ground something went pop and I lost all drive. Peeping underneath with the car running and in gear my nearside drive shaft is spinning away merrily so one assumes CV joint. I've also found out my nearside indicators have stopped working. To top it off RAC have charged me £100 for recovery because the car is SORN'd therefore illegal to drive on the road, despite all the conversations about not being able to tax it until its MOT'd and I'm on my way to a booked MOT which is legal blah blah blah. So something else to take up with someone else when I get home. Which will be around 4-5 hours I'm told. I won't lie, I'm pretty close to walking to the Toyota dealer around the corner and buying a Yaris.
Last Edit: Mar 29, 2021 21:01:48 GMT by oli8925
Project Diary1975 Viva / 1988 T25 Camper / 1989 Mini / 1991 MX5 / 1992 Mini / 1994 Saab 9000 / 1997 Saab 9000 / 2008 Saab 9-5
jmsheahan
Club RR Member Number: 121
Mar 29, 2021 16:42:37 GMT
Damn, sending a virtual pint and hoping you get sorted without too much drama.
Mar 29, 2021 17:45:26 GMT
Damn, sending a virtual pint and hoping you get sorted without too much drama. Thank you, gratefully received. Literally can't wait until I can have a proper pint again! Also can't wait to go for a long chilled drive Thankfully only the 3 hours to wait for pick up. Back on the driveway for a quick poke. Looks like the CV is the culprit. Getting the shafts out of the hub is going to be fun, and I'll need to borrow or buy a bigger torque wrench to get them back on. Can't seem to embed it so have a link - imgur.com/QtWwIsE
Last Edit: Mar 29, 2021 21:03:29 GMT by oli8925
gryphon
Club RR Member Number: 157
Bad luck! And very poor service from the RAC :/
Not sure where abouts in the UK you are, but I have two 1.6 driveshafts sitting outside the garage near Warwick that you'd be welcome to. The hub and uprights are attached, but I'm pretty sure the nearside upright has part of the lower bolt still stuck in it.
Thanks for the offer gryphon but I think I'm hopefully sorted. Are they push in shafts or bolt on? I've changed to the late 1.6/1.8 push in shafts for clearance to the exhaust.
gryphon
They're bolt ons. I also have some push ins but they're very seized to the hubs!
Mar 31, 2021 13:05:55 GMT
Ah, they won't work for me I'm afraid. Thanks for the offer anyway.
gryphon
Mar 31, 2021 14:38:15 GMT
I seem to remember us having a very similar conversation on my thread! Hadn't realised you'd swapped out the diff though - at least I'm presuming you have as the push ins were off a '91 1.6
Mar 31, 2021 22:32:21 GMT
We quite possibly did. I have a TorSen type 1 in there at the moment, ditched the VLSD a few years ago as it chattered horribly and gave me a good reason to upgrade.
Little bank holiday weekend update. My brother in law came down to visit now restrictions have been eased and very kindly brought a push in shaft out of a mk2 he broke this week. Unfortunately the outer CV on this had a bit of play and was the 32mm hub nut type, as opposed to the 29mm hub nut used on some mk1s. Seeing as I'd have to wait on delivery of a new hub nut anyway I decided it would be rude not to strip down both CVs and fit the 29mm version off the old driveshaft to the new driveshaft. And a lick of paint. Truth be told my OCD wasn't keen on having a 29mm nut one side and a 32m nut the other. Fast forward a day and both CVs stripped down, old CV seemed to be in pretty good condition, and a splash of paint later. To confirm, this was the issue that cost me a couple hundred quid. Very odd, hoping there isn't something else wrong that caused it but I can't think of anything Waiting on a pack of CV boot clamps before I pack it with grease and put it all back together. I'll buy a new 29mm hub nut anyway as the existing one was split and a bit nasty where it was improperly punched. Tomorrow I'll also attempt to resolder the flasher unit seeing as a new one is £70!
Last Edit: Apr 4, 2021 20:19:22 GMT by oli8925
60six
Did they make t25s out of really bad metal? Golf/Passat of the same age don't get anywhere near that bad. I wonder if it is a case of design - more water traps on these? no rustproofing from the factory? Still - a perfect way to improve the welding skills.
Did they make t25s out of really bad metal? Golf/Passat of the same age don't get anywhere near that bad. I wonder if it is a case of design - more water traps on these? no rustproofing from the factory? Still - a perfect way to improve the welding skills. I think it's just areas of poor/old fashioned design causing water traps. There are areas of this van that are surprisingly good and the metal seems stereotypically good and heavy, but I'm not sure if there are any significant material differences to the cars. This was sold by VW as a commercial van so maybe lesser materials were chosen to help profits, as vans had a harder and thus shorter life anyway at the time? Only a guess. Tried to get a little bit more done today of the smaller jobs on the MX5 without too much success. First a present arrived These are the Schroth E-approved harnesses I found as a result of the MOT shenanigans. They're in excess of £600 new but I thought I'd check ebay on the off chance and as luck would have it there was a pair of excellent condition FIA expired harnesses on a no-reserve auction, so I bagged them. Still need to buy the crotch straps which, new, are annoyingly only a few quid less than these harnesses were. They also seem to have sold out on DT since I last looked. My TRS set will be up in the for sale section soon if anyone's interested. Seeing as I can put these through an MOT with every confidence they'll pass I set about pulling out the drivers seat and seat belt yet again. While the harness bar is out I wanted to make a set of spacers that are needed to mount it to the seat belt towers. Up to now I've been using a pair of 6mm thick washers on each end which is fine, but a properly made spacer would look better (not that you can see it when installed but that's not the point). All was going well with an offcut of 6mm stainless plate I had lying around until it came to drilling the holes. My 7/16 cobalt bit seems to have bitten the dust. I must have absolutely abused it last time out but not remembered, so I'll need to pick up a new 12mm in Screwfix tomorrow to finish the job. I also need the bit to open up two holes in the car floor to make a 6th harness point - handily the chassis rail protectors have mountings in just the right positions so I can use one of these points each side with a spreader plate on the underside of the protector. The only other pressing matter was the lack of nearside indicators. The fact I could hear the relay going but none of the lights were working on the stalk nor the hazard switch pointed to a problem in the relay, which is known to suffer dry and cracked joints. After a bit of a fight to get it out it was clear which joint was the offender The last few solder jobs has made it clear I really need to get some better equipment, or maybe just some better tips or I need to learn how to look after them better. After yet another struggle I eventually managed to get my gas iron hot enough to use and cleaned up the tip well enough to tin, and reflowed the joint. Indicators working again and £70 saved.
mk2cossie
Club RR Member Number: 77
At least the Mazda failed next to the tented city, and near Asda! So you didn't have far to go for a refreshing beverage and comfort food
Apr 19, 2021 18:24:17 GMT
At least the Mazda failed next to the tented city, and near Asda! So you didn't have far to go for a refreshing beverage and comfort food Ah, you know it well. I was so close I was in their service entrance...they weren't best pleased. So, this sorry chapter is finally over! Last week the last few bits arrived and the driveshaft was put back together Reinstalled on the car. It went back in no problem, new hub nut and suspension arm bolts retorqued with the wheel on a ramp. While I was there I lowered the coilovers a little bit to get a F:310mm/R:320mm height from hub centre to arch top which is supposed to be the ideal height. A few weeks ago I'd packed the wheels up on planks of wood to get it level and weighted down the drivers seat so I knew how much I needed to go down by, which ranged from 3 to 13mm - does seem to sit a bit better now. Rechecked and adjusted the handbrake while I was there. Spacers for the harness bar made and painted (yes, I dropped one of them mid-paint!) And changed coolant. I flushed it out several times when I first got because it was just a rusty solution and the water pump had seized. It then got another flush a couple of years later when the thermostat housing cracked but that was 4 years or so ago now. The coolant in the header tank looked ok but once out and in a bottle it was obviously due a change I'd asked on a local retro car facebook group for MOT centre suggestions and had quite a few suggestions, but one of them was actually from the guy who'd MOT'd this for the past 4 years, and his new centre was only 2 minutes down the road from his old place. Turns out he left a little while ago because the new owners were pressuring staff into finding reasons to fail the car and earn a bit of extra work...which explains things. So the car went to him first thing Saturday, bucket seats and new harnesses refitted, and came out with a nice clean pass. And that's pretty much that for the MX5 for now, other than a few little tidyups, while I try to find somewhere for a paint job. I did a few little jobs to it on Sunday seeing as there was a bit of sun. Replaced the tape on the rear window (zip failed on the motorway sending the screen flapping about and left a whacking great split down the middle) and gave it a clean up with quick detailer, put the pedal covers back on and destickered the sides Interestingly I found the imprint of a Mazdaspeed decal in the paint on the rear quarter, just above the swage line, but Googling doesn't bring up anything meaningful. No rest for the wicked, the MX5 was immediately kicked out of its resting place and replaced with old Rodney
Apr 19, 2021 19:01:00 GMT
So, no time like the present, my list for Rodney: - Remake and replace brake hard lines front to back, and replace flexis with braided items
- Fully strip interior, replace any broken trim and try to fix rattles and creaks
- Run audio cable to and from 6 channel amp in boot, install subwoofer and sound deadening, maybe try to open up front speakers to 5.25"
- Wire in knock light
- Change carpet and maybe headlining from the grey 9000
- Investige drivers door latch; door was replaced a few years ago due to rust and I struggled to align it, causing rubbing on the door frame that now needs to be fixed. The door has since been aligned but doesn't shut nicely, and this door is now showing rust
- Replace and repaint slam panel, bonnet, hatch with Carlsson spoiler, possibly body kit and drivers door. Maybe the roof too. Might as well just do the whole car
- Renew gear linkage and install Jamsaab shortshift
- Swap interior for another, better, set of Aero seats
- Replace passenger wing with a freshly painted one I already have
- Investigate current draw causing flat batteries
- Replace exhaust mani and turbo hardware causing exhaust leak
- Replace aux belt and pulleys
- Replace steering wheel air bag causing SRS light
- Investigate ticking noise thought to be chain tensioner
- Replace turbo oil and oil cooler lines with custom made items
- Replace boot seal and investigate water ingress
- Deal with a bit of minor rot in odd places - boot seal lip and one rear door seal lip, a bit around the bonnet hinges, and anything esle I find underneather the body kit. I may end up refreshing all the underseal as I did on the MX5, along with a paint and rebush of the suspension components. OVerall though I don't want this to take forever to complete as it's supposed to be my daily.
- 3 stage machine polish as an interim before paint
Recently had the rot in the corners of the inner rear quarters repaired Remaining rot A fair bit of tidying needed A nice little sub enclosure I snagged from a friend. The system won't be anything fancy, just an old school Alpine amp driving all the speakers and old school responsive sub to produce decent quality sound. The standard system in a 9000 is awful so I'm sure anything will be a nice improvement.
May 31, 2021 23:29:19 GMT
I've not really done too much to this for a number of reasons; lack of spare time, lack of spare money, and to be honest feeling s bit overwhelmed by the task ahead and mentally drained from having just done it all on another car. To make it more manageable I'm going to break it down into a few phases. The first phase is to replace the brake lines as that's the MOT requirement, so that's brake lines, flexis and caliper rebuild, rear bumper and side skirts, de-rust the underside and underseal, replace any needed parts (fuel hoses, clamps etc), sound deaden and run audio cable to put carpet and interior back in. So far the rear interior is stripped, I need to make more storage space for the front seats and carpet to come out. It's up on axle stands with wheels off so today I had a nose around underneath. It's not too bad, a good few rust scabs though all over the place. Some bits will definitely need welding but in general unless the metal is holed or significantly weakened it will be treated rather than cut out. Everything will be treated/repaired, the full underside degreased and fresh Bilt Hamber underseal applied. One side of the quarter repair carried out by the body shop looks really nice (oddly enough the worst side) but the other side looks like there might be some bird poo hiding beneath the stone chip and the rear part of the skirt/return for the bumper mounting has been missed so I'll redo or add a bit on. In hindsight I might as well have saved my money and done it all myself but nevermind. Fuel tank strap bolts are soaking in GT85, O/S strap looks new but N/S will be replaced. Tank breather hose had split right the way through which explains the strong petrol smell. Will need sort that out before I start grinding and welding. Might choose to drop the suspension for access to the bidy, and will likely refurbish the components and replace the bushes while I'm there. Or I might need to leave it for later. Some of the nastier bits Hoping to order and awful lot of stuff in the next week or so and get really stuck in to stripping the underside back now weather's better. Meanwhile the MX5 has been performing pretty well. I've not managed to get the alignment done yet so not given it much stick in the corners and the engine doesn't seem to sing at high RPM like I remember, so may need to look into that.
Jun 27, 2021 21:29:24 GMT
A couple of updates in one... 13/6 Took the tank out over the weekend, didn't realise how much petrol I'd left in it, made it more of a challenge. A little bit grubby behind there but only another couple of rust patches to deal with Offside tank strap didn't have much life left in it. The end in particular was very weak. I've also decided I need to drop the complete rear suspension to strip back and trat the rust properly for this to be worthwhile, so that and the exhaust will be the next stage. I'm expecting it to fight me a lot. Might look at replaceing the fuel lines as well, if not available there are a few bits I'd like to brush back and treat. 27/7 This weekend was the first time I've had a chance to get under the car in a few weeks, the objective being to get the underside completely stripped ready to wash and start dealing with the rust. Thankfully the suspension didn't throw up too many issues, paying particular attention to wirebrushing the exposed threads and copius amounts of GT85 helped. The only bolts that fought me were one of the stabiliser arm mountings on the passenger side which needed a bolt/nut welding on each end to break the corrosion and turn it out, one of the ARB hangers on the passenger side which needed the nut splitting/cutting off (really odd method of providing a captive bolt in my opinion (pictured below)unfortunately the threads took a couple of small nicks so I might have to replace it anyway even if I can fix the captiveness), and one of the exhaust bolts needed mutilating but amazingly three out of the four actually came undone. So this is what it looks like currently. Exhaust heatshield, spare wheel carrier, fuel filter and fuel/brake lines, tow bar, rear bumper and skirts still to come off before I can really get stuck in. One of the problems I'm really struggling with now is space to store all the bits, this was the end of Saturday's work and I've now added the midsection and suspension hangers. Going to need the garage to do all the painting with this weather too Tow bar wiring for my reference on reassembly In MX5 news I finally got it up to Wheels in Motion to sort out the geometry. Obviously it made a big difference and I was very pleased to have my positive and confidence-inspiring car back, however it still has its issues. Before the alignment I had a really bad shake/wobble at ~100-110km/h, that's now improved significantly in terms of severity and speed range but it is still there and worse than I can accept it being. Not sure what to try first - turning the prop seeing as it's free but I doubt it will be the problem/make much difference, or have the wheels rebalanced but they were done by a decent place so hope it's not that. Since the alignment my wheels gone off centre too but this could be because I used uprated SkidNation alignement bolts but didn't tell WIM to torque them higher than standard spec. WIM may well offer to sort it but it's a 2 hour journey I don't particularly want to make. Otherwise it's still working well as a daily and I may have spent money I don't have on a couple of nice bits for the future. In T25 news my wife still can't make up her mind with it so is simultaneously talking to bodyshops whilst looking for others for sale and failing to commit to either.
Aug 16, 2021 21:55:50 GMT
OK so back on with this, I got the heat shield and the rest of the bracketry on the underside off and the skirts, please to say other than a few pathes of what I'm sure is surface corrosion there were no horror stories. Gave it all a hose down, wash with shampoo, scrub with a TFR/degreaser mix and then rinsed it down. From here I used a panel pen to mark all the areas I could notice that would require some kind of attention, even if it was just mild bubbling under the surface. Unfortunately this showed more work was needed to the driver's rear arch than I bargained for, in particular this odd penetration hole in the very top of the arch that had been undersealed over. Passenger arch Rear panel, need to tackle the awful rust around the seal lip at some point Looking at the driver's side inner sill Passenger side Back at the spare wheel well And then it was on with the angle grinder and a wire wheel. I have to admit, after this little lot I felt reasonably dejected. None of it was too surprising but seeing it in gaping holes brought it home, and there's a bit of pressure that I can't let this one come to the same fate as the grey car, or other cars that have come before it that are still waiting. This one needs to be welded up and returned to the road within good time. Before the light and the wire wheel forced me to give up for the day I stuck it into the ropey looking repair done to the offside rear skirt. I'm a bit peeved at this, considering the guy's reputation and that I paid a decent amount of money for this repair, its not to the standards I would expect. Thick underseal was used to cover holes and significant rust that remained. The external skin was also worse for wear, although no major holes it's pitted enough to need to be cut out and replaced and will take care of the inner return Offside chassis section is starting to go at the rear aswell, not sure of the best way to repair this I have the rest of the week off work although plenty I need to squeeze in, so will try to make some more progress. I had thought I'd have the welding done and the rear half freshly undersealed but fat chance of that. In other news the mrs and I recently took a trip up the country to see family so thought I'd take the MX5 and drop in to her brother who works at an MX5 place to get it on the ramps and work out this odd wobble. After many hours, a wheel balance and another alignment the wobble is still there. Strangely when looking back to front underneath the car it look by eye that the prop isn't running centrally down the tunnel suggesting the diff is off alignment. Unfortunately there is no diff alignment on these so it's likely the subframe I resprayed and put on in place of the previous due to stripped threads is bent, although really odd for the diff mounts to be bent but the subframe straight enough to bolt up and not cause any geommetry issues. Other potential culprit is the diff itself? Which needs replacing anyway so I'll start with that. While there he thought it would be a good idea to fit the Megasquirt MS3 Basic I'd bought because the deal was too good to pass up. I wasn't exactly prepared for this so the additional £200 of parts to make it fit wasn't very welcome. What was less welcome was learning that my alternator is only pumping out 12.9v and my compression is down on cyl 2 and 3, to such an extent that to those in the know it feels very underpowered and isn't responding to tuning in the way it should be. Because of this I don't think the map was finished anywhere near to the extent that was promised and to make matters worse the TPS died on the way home. It's still just about driveable because the map is based off MAP rather the throttle position but it's pretty nasty. I have a new TPS (now E36 1.8 IIRC) arriving on Tuesday which will hopefully get me back to a position where it's driveable and I can start fine tuning the map (or perhaps TunerStudio is better placed). In other other news, the T25 is booked into the body shop for February. A lot of work to do in the mean time though. Maybe I should throw the 9000 and MX5 down there with it???
Aug 20, 2021 22:01:36 GMT
Got a little bit more done to the 9000. Made up 7 cardboard templates for the offside wheel arch patches when I had some time to kill, too windy to weld nicely today so left it there. Wire wheeled the nearside arch and thankfully no nasty surprises there, only what was expected. All other patches found were only light surface rust so with little or no pitting so cleaned back, Deox-Gel where necessary and Hydrate 80. They'll be overcoated with epoxy primer tomorrow. And finished wire wheeling all patches of rust on the spare wheel well panel. Again, no holes and while there was some medium pitting I'm going to take my chances to treat it rather than a full scale cut out and replace. As before Deox-Gel, Hydrate 80 and epoxy promer tomorrow. Now looks like a patchwork quilt but will be worth it when done I do need to expand my tool collection to get into the rust in the tight corners, so if anyone has any suggestions please say. The new TPS arrived for the MX5. It fixed that issue and was giving the correct readings to the ECU but the car was still spluttering and dying. Decided to take it back to basics and go through all the settings on the map I was given, turns out my brother in law had missed out a zero and set launch control to trigger at 400rpm Turned all the extra stuff off for now until the map is better sorted and it's back to being quite a nice drive. Even took it down to the bodyshop to get a quote for a respray which was reasonable so that might be coming up in the close future. Also fixed an exhaust leak, although I suspect the manifold is blowing slightly again, and taped up two new cracks in the plastic window. Finally, mrs8925 got involved and helped me to tidy up the parts garage so that we could empty the contents of the van. This culminated in finishing off stripping it out of all the trim and carpet so that we can further plan, start buying parts and start the wiring for the leisure battery/hook up side. This unfortunately did reveal a couple of areas in the front needing attention, but common areas so to be expected.
Aug 23, 2021 21:08:35 GMT
Bit more progress on the van over the weekend. Dash came out to reveal the rats nest of wiring. Main purposes of this were it needs to come out for the welding anyway, I wanted to check and unbodge the wiring, and the heater motor needs replacing. Thankfully it wasn't too messed with anyway, I've removed the old defunct alarm system (looked like it might have been a fancy VAG endorsed product back in its day) and reversed some bodgery caused by the tow bar install. A few more bits of plastic broken but Plastex on its way to hopefully rescue the day. The dash clocks are pretty shot though. Over the coming weeks I'll be wiring in a Toad Ai606 I've had lying around. Mrs8925 is itching to get cleaning in there, then I'll do my bits and run part of the leisure system wiring that needs to extend this far forward. New rock n roll bed is about to be ordered as well as a few other bits that will require holes to be drilled before the bodyshop in February.
