Mar 15, 2021 20:35:22 GMT
Of course, it does help if you put the headlight pivot bolts the right way around Right hand unit installed, only remembered after that I should have left it off until I'd replaced the sidelight loom but nevermind. I've still not worked out how you're supposed to tighten the rear outside lid retaining screw without scratching the wing. Decided to leave it there and wait until daylight to do the final adjustments.
Project Diary1975 Viva / 1988 T25 Camper / 1989 Mini / 1991 MX5 / 1992 Mini / 1994 Saab 9000 / 1997 Saab 9000 / 2008 Saab 9-5
Mar 17, 2021 21:28:18 GMT
Found a spare hour or so today to tick a few items off the list. Started off undoing the progress I'd previously made by separating the front bumper from the body again. A bit of a silly reason, the ends of the bumper have an 'ear' moulded into them, a metal plate with two captive studs sit against the front side of the ear with the stud protuding through it rearwards. The studs pass through a return on the front of the wings, an opposite return on the inner wing, and are secured with a pair of nuts to bring it all together. The plates are loosely held to the ears using three small plastic clips, in my rush to get the bumper on in Sunday's fading light I thought I'd lost the clips so used so trim tape to hold them in place (didn't work but not really needed anyway). In order to continue with the other remaining jobs I needed some other fasteners that I couldn't find but knew weren't lost, a quick rummage in the garage found them in a separate box for some reason along with the clips - so for no practical reason I loosened everything off again to put these little clips in that aren't really needed. Sometimes I dislike myself Following this, and with my newly found fasteners, I installed the clips securing the front bumper air guide to the front panel. I didn't really pay these enough attention on removal to notice most of them are completely stuffed, so will look at getting some more in the near future. The air damn itself was cracked, missing retaining tabs and the remaining fixings were seized, so this was replaced with a new Mazda part with stainless fixings. Front tow hook reinstalled with 2 out of 3 bolts, the third appears to be crossthreading so I've left that until I can pay it some more attention. That'll be a fun job considering there is barely the space to swing a short spanner in this area. Next were the arch liners and mud flaps - not much to say here except I soon realised I was missing a few fasteners and retaining clips so new items have been ordered to arrive on Saturday. Just annoying I can't stick it back together completely now to be honest. Still, nice that it's looking cleaner and more complete. (Sorry, camera exposure settings seemed to go haywire in the rain) Had a bit of a head scratch about the mud flaps, not too happy with the fit at the top, wondered if they should go behind the liner and up tight against the wing but it wouldn't fit that way. Don't remember having the same issue previously but they were genuine flaps torn to shreds, these are IL Motorsport reproductions so maybe that's the issue. Later in the day, thanks entirely to the sunshine, I came back out to try to do a bit more. I was feeling very concious that a headlight was still missing, exposing one corner to water ingress (stupid as it's exposed anyway being that the headlight lids don't seal against the body work, so all in my head). First job was to replace the sidelight looms while I still had one accessible. The connectors include a push clip that attaches to the inner wing, unfortunately that hole is over the chassis rail so you can't get to the underneath to press the tangs in and release it cleanly. What ensued was a considerable fight to get them out but evenutally I won, the new clips are included with the new loom so I could be a bit violent. Thankfully the driver's side I'd already covered up with the headlight didn't put up as much of a fight. Next the passenger headlight was fitted which went largely without issue althought it needed a bit of persuasive force. On removal the pivot bolt had seized so I had to bend the tang of the headlight out of shape to remove the unit from the car. I'd bent it 95% back into shape when I refurbished them but it obviously wasn't quite right so needed a bit of extra gentle persuasion. With the lids on it's still not quite right but close enough for now. Both still need some final adjustment, although I think the bonnet also needs some adjustment which doesn't help with trying to line everything up by eye. Very glad that it's looking like a car again...I guess the neighbours probably are too! Still remaining: New brake discs to go on Front arch liners/mud flaps to sort Undertray back on Final bleed of the brakes & set handbrake MOT Alignment Few final cosmetic bits
Last Edit: Mar 17, 2021 23:43:16 GMT by oli8925
gryphon
Club RR Member Number: 157
Nice work! Looking at that last front picture, to my eyes de-tangoing the indicators would look good - especially on the wite car. (Pop them in the oven to soften the adhesive, pry the lens off, remove the orange lens and then replace the bulb with a chromed orange one) I do like the projector headlamps too
Mar 18, 2021 14:34:59 GMT
I have thought about it but feel the orange a) helps to break up the monotony of white a little, and b) keeps it looking a little more retro. I may pick up a second set to play around with.
Or I keep thinking about vented TSIs, but can't find any I'm 100% set on aesthetically.
MOT booked for Wednesday morning!
Mar 21, 2021 23:30:29 GMT
Started Saturday morning with a bit of deja vu when Faceache told me it was 6 years ago that I took the MX5 for its first MOT under my ownership It was almost perfect but I'd decided to push the MOT back a few days to Wednesday. Probably just as well I did. Nothing major, just the little bits not going to plan. The new clips I'd bought for the front arch liners looked good quality and were a very close match to the original, but the hole for the screw was one size too large meaning the no10 ACME screws I'd bought didn't 'grab' enough, and the no12 ACME screws I had weren't long enough. In the end after some messing about I decided to use M5 stainless dome-head bolts instead - these grabbed nicely, won't rust and are a little lower profile too incase a tyre gets too close on track (shouldn't do on these wheels to be honest) Unfortunately these seem to be too short or weren't grabbing in the bottom mudflap mount, and the replacement screws for the mid mounts (different to the rest, goes into a rectangular stand-off block that locates into a square hole in the arch return and expands as the screw goes through thus securing it) were 10mm too short, so not expanding the fixing which kept falling out. So I've had to order some long stainless hex-head screws which should do the job. Not the end of the world, just frustrating that things don't fit properly. Remaining air guide bolts and the troublesome tow hook bolt sorted. Undertray back on and looking decent. For some reason I had a random undertray bolt left over, not idea where it's come from! Moving on I changed all brake discs; nothing fancy, only standard Blueprint discs but they seem to have a good reputation in MX5 circles for providing good performance and taking track abuse. The set coming off are the same and have done well (barely used actually just a lot of surface rust from standing outside). The other advantage is they're pretty cheap. Adjusted the handbrake and re-bled the brakes with Mrs8925 on the pedal just to be sure, and I'm pleased to say the car is now back down on all four wheels for the first time in a year. Oddly it came as a shock to see how small it was, for the whole year it's been on axle stands at full extension and now looks so small and low, especially next to the van. Tried to set the headlight level using a big sheet of MDF. Not really sure if it's where it should be or not. The adjusters weren't noticably moving the beam much and because all the plastic retaining clips are chinese repros, as that's all I could find, they don't fit into the housing brilliantly and pop out when pressing a screwdriver in to them. I'll have to see how well they do on the road and try to find the proper parts. Not sure if Moss would be able to supply them, assume they just buy in and resell the kit complete, or whether Hella would be able to provide new ones. I think they're some form of BMW clip, pretty sure I managed to find new genuine ones at one point but wasn't sure of the source and they were something like £4 each, and I'd need 12, then I lost the tab and couldn't find them again. All other parts tested and I think I'm ready for Wednesday Finished off but clearing the garage again as I hadn't put it back together since the painting, and it was making me itch. I'll start painting up the badges this week and will see if I can do a refurb on these PIAA fog lights that came with the car. Probably quite marmite and I'm a bit indifferent to them, would just be nice to make them useable again. I last secured them with stainless bolts but didn't realise they fix to the aluminium inner units rather than the external plastic housings so they've all seized and are properly refusing to budge. I might also see if I can revive this Dcuatro headlight cover which has been a pain in my for years. I'll probably try to strip it right back using fibreglass friendly marine paint stripper and do a bit of research into the best products to use to prep and paint it.
Last Edit: Mar 21, 2021 23:36:01 GMT by oli8925
Mar 22, 2021 18:13:44 GMT
The underside of your car looks so fresh. Really liking the button Allen key bolts. I might have to follow suit.
The loneliness of the MOT waiting room when you know your car's about to fail because it started running on 3 on the way in
Mar 24, 2021 10:40:31 GMT
In the words (sort of) of Blackadder " Today's entry in my diary consists of one word.... bu66er!"
censored me! read 6 as G for those that look at this and think 'old sod has lost it'
Last Edit: Mar 24, 2021 10:41:59 GMT by duggers
Mar 24, 2021 11:20:13 GMT
Bu66er indeed!
A difficult pill to swallow, this one. It failed, not on emissions surprisingly (have narrowed the misfire down to water ingress into no2 sprak plug recess) but on: Front number plate not reflective - I'll begrudgingly accept this one, it does look noticeable flat this year so I'll replace it, but it certainly was reflective. Has been on there for 6 years. Both front seat belts not of correct type - they're harnesses. I know this is probably correct use of the regs but ffs, I have a cage, bucket seats and it's a track car. They are in great condition and not freyed, fixed in with all the right hardware. Brake pedal missing its anti-slip coating - it has some kind of JDM studded metal pedal covers that it's had since coming into the country 15 years ago. Again I know it's probably technically correct by the regs but f sake. It's not like the pedal rubber has disintegrated leaving a shiny metal surface.
The guy's attitude was pretty awful too, "well I could have failed it for X, Y, Z too but I didn't". Examples being the harnesses being able to freely slide across the harness bar, he's already failed the harnesses so not sure what relevance that has. Something about it having a roll cage. He tried to fail it for having the wrong nuts on the front coilover bottom mountings, but when I protested that it was the standard Mazda hardware he conceded. The guy was a tool.
Anyway. I'll order a new front plate, new plugs while I'm sorting that out anyway, a couple of pedal rubbers and I'll stick the driver's side seat and seat belt back in and take out the passenger side altogether. I'm not even sure I'll be able to put the factory seat belts back in without removing the cage. I'll probably check that out first to be honest and if not find a different MOT tester and take my chances.
Mar 24, 2021 13:47:00 GMT
Maybe he'd had a row with his partner the night before & was being a d#ck to everyone. That does seem pretty anal to me.
MiataMark
Club RR Member Number: 29
Mar 24, 2021 15:24:05 GMT
I think you need a different MOT station. Mine's got a roll cage and no pedal rubbers, I've got a drivers harness in but still got the standard seat belt fitted.
Mar 24, 2021 17:14:02 GMT
I won't be using this lot again. They used to be pretty good, the kind of garage you could have a chat with and would use the rules sensibly. They were bought out a year or two ago and I think the old staff have slowly moved on. Funnily enough this has coincided with a heap of negative reviews (I now know) so it's probably not just me nor an isolated occasion. Pedal rubbers ordered for £5 a pair, should arrive Saturday. In the mean time I'll clean my nice ones up (seem to remember they're something fairly sought after and worth a fair bit). New number plate ordered from Halfords I'll pick up tomorrow. They only seem to do the standard oblong size so I'll stick that on temporarily and buy a more suitable size online, but still confirming to UK font and sizes etc. Online suppliers don't seem to be able to supply and deliver within a week. Finally, I dug out the standard seat belts (because 30 year old inertia belts are far safer to use with a cage and bucket seat than 5 point harnesses!). It shouldn't take long to swap them over, just a bit fiddly with the cage in the way and having to remove the harness bar. I'll take the passenger seat out altogether rather than mess around swapping that side over. On this subject, new harnesses were on the list just not a priority. There's nothing wrong or unsafe with mine, they're just a bit stiff and a real pain to adjust. So I got looking for some road legal 5 or 6 point harnesses, and to my surprise there is one that fits the bill. Schroth make a 4 point harness with individual shoulder and lap belts, and with the latch functioning in almost the 'normal' way, but operated by a red push button to keep the MOT man happy (and they're ECE type approved), then you can buy crotch straps to convert them to 6 point. The only problem with these is a pair is going to cost in excess of £760 all in. That's more than I paid for the car! Still, do it right do it once I guess.
mk2cossie
Club RR Member Number: 77
Mar 25, 2021 21:24:09 GMT
Luke do road legal harnesses should you want something less costly than the really posh ones
Mar 25, 2021 21:45:33 GMT
I think Luke only make 4 point road legal harnesses, with each side's shoulder and lap belt sewn together. I wouldn't feel comfortable using this on track or with my set up due to a lack of anti-submarine mechanism, and apparently the combined belts make releasing the buckle really difficult of you end up on your roof.
mk2cossie
Mar 25, 2021 22:08:56 GMT
My 4 point Luke harness has the 4 straps seperate, and I think provision for the crutch strap too. And is just a twist to release and unlock the lot
Mar 25, 2021 22:46:25 GMT
But I think it's that twist buckle that isn't type approved for the road. All road legal harnesses I can find have factory belt style buckle with a big red button to release, other than the Schroth. If I'm wrong would you be able to give the same as you have for sale and post a link, as I'd be interested.
mk2cossie
Mar 25, 2021 22:59:34 GMT
Mar 25, 2021 23:21:55 GMT
FIA approved but not BS or E approved for road use unfortunately. Thanks for finding the link anyhow
mk2cossie
FIA approved but not BS or E approved for road use unfortunately. Thanks for finding the link anyhow Wheres the reasoning for this BS or E approved? Surely the FIA approval over rules that? Other wise there would be many rally and WRC cars that aren't road legal
Apparently the DVSA, or someone ( in getting a bit confused by it all now) looked at the FIA standards and rules that it didn't necessarily meet all the same criteria for a road belt that BS and E approval meets...
Why I don't know. In the other thread blackpop mentions it being the buckle type that doesn't meet BS/E approval and I'm sure I've read something that BS/E approval stipulates a red push button release (not twist). You would have thought, as you say, that in terms of the outright safety of the device FIA approval far outweighs BS/E approval. Hence my question to the tester, having come out with the plop that it's his job to keep me safe, that if he'd rather I wear a 3 point inertia reel belt in a car with a roll cage (which is definitely road legal) it's got nothing to do with keeping me safe.
Seems a considerable short coming in the MOT regs. Surprise.
I think registered rally cars are given a bye on this section but must meet other requirements; no ABS, no power steering, cage and fixed seat or something. To be honest I only need to ditch the PS.
