teaboy
Make tea, not war.
Mar 20, 2019 18:16:35 GMT
Looking at the tyres before fitting, the beads look closed in. This is usually caused by the tyres being stored stacked on top of each other. They don’t look too small for the rims. That tyre machine he has is available with a built in cheetah type system as an optional extra. I do like an old Mercedes.
Mar 25, 2019 23:49:27 GMT
Many thanks folks! However, I would still have some work to do! The first was to get a working washer pump. While I ordered the parts, they would take some time to arrive! So in the meantime I threw in a switch under the pedal, in addition to an electric pump. This would work for as long as I needed it to. Secondly, I had to change the severely knackered track rod end. It had a mile of play in it pretty much! Working in logistics, I ordered the right part days before hand. However, it was the wrong thread; I need a right hand thread to work with mine. Balls! However, it was no great loss as the boot was cracked anyway on the correct balljoint on the same rod. So that was changed. While ECP couldn't provide with a TRE, a local motor factor would save the day . I'd have taken pictures, but I did have a few mates around to assist, so I didn't really want to seem anti-social. And they'd help me remove the very stuck caliper on the car!. Even with alot of hammering, the offside caliper really didn't want to come off. Eventually, it did thankfully. As said before, the calipers from the SL shop and other sources are £250 each! Bigg Red wanted £130 to refurb both calipers, which didn't seem like a bad deal. However, I decided to get the piston and seal kit prior to calling Bigg Red. A mistake, but OTOH, it would cost me £60 per axle, and I've fancied rebuilding calipers for some time. It's fair to say that the pistons came out with a fight! However, they cleaned up well, and the bores weren't too bad either. During the cleaning process. Then it was time to look at the old pistons. They're not great, but not that bad at all. The car clearly had been sitting for quite some time! But why use old pistons when you can go new? Before I knew it, the caliper was assembled and ready: After having a friend around to help me bleed the system, I now had a car with a good pedal and a permanent handbrake removed. I also had a link pipe to one caliper remade for me due to us breaking it, but it was fixed! All I had to do now was to fit the caliper to the car and bend the pipe to suit. The next thing? Get the horn working. After finding a horn from an MG Midget, that was working once more. Sure, the car had a bit of BL on it now, but at least it would get an MOT. Finally? The exhaust rubbers. With that done, it was time to get the wheels on. Except I hit a problem. The nuts I bought (the ones on the right) wouldn't fit. They were catching the rear drums badly. I'd have to wind them out around 6-7 turns for them to clear the drum. But would the new bolts in the middle fit and do the job?
MiataMark
Club RR Member Number: 29
Could not agree more on the tyre issues - the amount of classics / retros that I see with aged tyres but decent tread depth - why owners think that it's just the tread depth that matters is pure foolish - 20 year old tyres with cracked sidewalls & splits in the tread are not going to be of any help just when you need them to act has the primary purpose of having tyres on a vehicle in the first place 'To keep you safe' There's recently been an inquest in Bristol about a fatal crash on the M5 where a transit had a blow out with a tyre that was 20 years old (some of these facts may be a bit wrong, going by memory). The van had passed a MOT just before the crash. www.bbc.co.uk/news/uk-england-bristol-47387676OK I was a bit out...
Mar 26, 2019 13:58:56 GMT
Those wheels and tyres look great.
I couldn’t agree more about your (and others) concerns on old tyres. Like you, I’ve taken some chances in my time, but there’s a huge difference between a calculated gamble to get a vehicle moved a short distance at low speed and wilfully driving a car “normally” on knackered tyres.
Keep up the good work. 👍
Mar 26, 2019 15:12:15 GMT
Could not agree more on the tyre issues - the amount of classics / retros that I see with aged tyres but decent tread depth - why owners think that it's just the tread depth that matters is pure foolish - 20 year old tyres with cracked sidewalls & splits in the tread are not going to be of any help just when you need them to act has the primary purpose of having tyres on a vehicle in the first place 'To keep you safe' There's recently been an inquest in Bristol about a fatal crash on the M5 where a transit had a blow out with a tyre that was 20 years old (some of these facts may be a bit wrong, going by memory). The van had passed a MOT just before the crash. www.bbc.co.uk/news/uk-england-bristol-47387676OK I was a bit out... The like is for the fact that you have taken the time to hunt the information out and post it to the thread and not that I like to read of any accident that leads to injury yet alone fatalities - non the less a minority of vehicle owners continue to run their vehicles on dead tyres that the rest of us would not dream of fitting to our motors - Apologies 'ChasR' - back to getting your lovely Merc on the road
Mar 26, 2019 22:34:52 GMT
No worries, it's good to see that people aren't shunning a potentially increasing issue now that a lack of MOTs aren't required or simply the fact that the MOT can't cover it. So, it seems I had wheels fitted again now I had the correct nuts but it would take time for them to settle down! But at least I had the wheels on. After attending to the issues of the exhaust hanger, and zip tieing the battery in for security, until I find a W108 battery holder, it was ready for its MOT. This would be the first time I drove the car for any real distance on the road. Was I full of trepidition? You bet! I came to drive it away. The first thing I noticed was that the car now didn't seem to drag, it just rolled; before it felt like the handbrake was always on! Compared to when I drove the car at the bloke's farm on private roads, it seemed alot quieter and nicer on the new wheels; to all of our surprise, the ATS Bundts are significantly lighter than the steels, with both having tyres on! Take the Merc up to 60 or 70? It just wafted up there and held it lovely! Driving a car on the wrong side of the road is interesting to say for sure! I've driven a couple of wrong hand sided cars previously, but never owned one! Sure enough, I was slowly getting used to it and lapping up the experience and then some! Finally, the car was home. But how would it fare on the MOT?
Mar 27, 2019 12:19:29 GMT
Those wheels just do it.
Mar 27, 2019 13:43:10 GMT
Those wheels just do it. They do look right don't they. It's always surprising just how much difference new tyres can make to how a car feels and rides.
Mar 27, 2019 19:58:44 GMT
It might be worth checking the seat on the Bundt wheels a lot of Mercedes use a ball seat on the wheel bolts not a taper I would hate a wheel to come lose on you Graeme Johnson
keyring
Club RR Member Number: 47
Mar 27, 2019 20:32:35 GMT
Those wheels love great on the car! You’ve made some great progress and not wasted any time on it either! I’m sure it’ll all go fine for the MOT!
Cheers all! It might be worth checking the seat on the Bundt wheels a lot of Mercedes use a ball seat on the wheel bolts not a taper I would hate a wheel to come lose on you Graeme Johnson A good point well made! I did check the seats of the wheels first. Being ATS Bundt wheels, it seems these have taper bolts fitted. Annoyingly, I bought a set of taper seat bolts for the similar reasons you mentioned, until I inspected the wheels further. The seat was confirmed as being a taper by my tyre fitter as well as Midland Wheels in the end . To my knowledge, I don't think Mercedes made a 15" Mexican Hat. ATS and a couple of other German manufacturers did make them, and apparently, there are Chinese 15" Bundts out there too, but they look different to the German items. Those wheels love great on the car! You’ve made some great progress and not wasted any time on it either! I’m sure it’ll all go fine for the MOT! Many thanks! Sometimes, you forget what you have done on the car. But about the car, it passed! Was I pleased? You bet! With that, I didn't hesitate with sending away the paperwork to register it! However, I still have one issue that would rear its head again. The washer pump. Sure, it was electric and the car passed the MOT with but, it seemed quite temporary, even with the installation of it! It even stopped working. The motor was working but the jets weren't really squirting anything! But, at the least engine looked a little beasty right? With a parcel arriving, I went to the back of the car, and opened up the boot. Oh, and figured I'd grab a shot : So, despite the electric option showing promise, I ordered the correct kit. What does a pricey washer pump repair kit look like I hear you ask. No? Alright, well, this is what it looks like: As said, I did still have alot the bits that I could savage from my setup, including the reservoir, the pickup pipe, the curse word, and the pedal assembly as well. It's just as well as my bill would have been much much higher otherwise: Ooooh! Shiny! The bellow on mine could have been repaired, but that check valve assembly will not work unless it is intact. It has a combination of a check valve and a ball bearing that acts as a shuttle in the second chamber to pump the system up. But let's spare me boring you folks to death with the archaic operation of the W108 washer pump system. So what better thing was there to do? Assemble it! Y'no how you see certain peeps advising that you get certain tools? Well, I do! I debated about getting an impact spanner for a while. To me, with their low torque rating they seemed like a waste of money, no matter how much Marty & Moog pimped them on Mighty Car Mods! But some things they stated did make sense! So when this Draper item came up for sale at the right price at the NEC Restoration Show, I had to buy it. At sub £100, I had to question if it was worth it. I'd soon find out just how worth it the wrench was! Even my local garage loves these! With that in mind, I assembled up the washer system! After tackling a couple of blockages with an airline, the manual pump system works very well! It's also nice to not have a car which is permanently broken in key areas! All I had to do was to take a few shots of the car on the new wheels with the fancy camera! Better shors will arrive, but of course, I am now waiting on a final roadblock; the registration of the car! It's been over a week and the DVLA haven't touched my application. We shall see how that goes Still, at least it looks alright eh?
keyring
Woooooo!!! Congratulations! I had a feeling it would all be good plenty time before the weekender too for your application, is there an estimated time it takes for the DVLA to complete the process? Despite the high cost, at least the washer pump won’t be in your mind and you know it’s as it should be
Woooooo!!! Congratulations! I had a feeling it would all be good plenty time before the weekender too for your application, is there an estimated time it takes for the DVLA to complete the process? Despite the high cost, at least the washer pump won’t be in your mind and you know it’s as it should be Cheers! I was a little anxious as I had been slaving away on this! As for the time frame to register it, the DVLA says 10 working days. So, firstly, the car got an MOT! In Late March, I sent off the application to get it registered! After calling them once a week my response was getting nowhere. However, this week, I got a response from a lady who seemed a little more switched on! From previous operatives telling me that the application had not been started, I was greeted with being told that the car was now registered! Result! However, they wouldn't give me the plate details. Not that it mattered, as they arrived yesterday! Great! I can now drive the car! But I needed some number plates making up. Black and silver items, especially with an import insignia on the back would take time to make up. Thankfully, a friend of mine came to the rescue, with a kit he had. The downside? Well, it's an upside to some on here is all I shall say. So, the plate up front was a Nigel Farage edition, and the rear was the right shape. For super cheap/free plates, beggars cannot be choosers! And at least I could drive the car about eh? Even with it doing a guestimated 15MPG it still didn't stop me clocking up 100 miles without thinking about it! Surprising I know! Besides going for a waft around town I ended up taking it to Caffeine & the Machine! If that wasn't enough, I also did the Butty Run in Long Itchington. It's fair to say the car got a warmer reception than I anticipated! Is there still a way to go with this car? Yes, but I'll get there slowly but surely! At least a slumbered beast has been awoken again for the first time in a while .
Last Edit: Feb 11, 2020 17:26:38 GMT by ChasR
So, the plate up front was a Nigel Farage edition Ah, yes, PUKI.
keyring
Apr 12, 2019 21:06:38 GMT
God to hear it all came through what’s it like driving on the road?
Clement
ambitious but rubbish
Apr 13, 2019 11:18:38 GMT
That’s a stately barge if there ever was one! I’m loving the English flag plate on a German car coming from the US, quite a few people would be puzzled I suspect
Apr 13, 2019 12:47:54 GMT
Lovely, but have I missed something? What is the connection to Carlisle?
Apr 14, 2019 11:16:12 GMT
Wow 15mpg....think the falcon is better than that.
Apr 24, 2019 18:57:37 GMT
So, it's been a while since I've been on here! But they have been car related! While work has been busy I've also been: -Trying to sell an old man's Audi A3 PD TDI DSG with limited success ; he bought it as a trial to see what diesel power was like. -He ended up buying a BMW E61 535d Touring! I turned the car down from a good RR friend of mine, so he's taken it. While he's been away, I've fitted two new tyres to it, and changed the warped discs up front. I'll get the cash back, but it's cheaper than the Merc to drive! It's a lovely thing! I almost wish I told Rich that I'd buy it! But despite its cheapness, it was more than I was willing to spend. -Acquiring a Mondeo 2.5t! That's in Heathrow at the moment as it's my dad's, but with two cars (M3 and 280SE) that will almost always require something doing to them under me, the Mondeo will make a great daily. Not boring enough to send you to sleep, but just about modern enough to be reliable. The latter was partly another reason I turned down the 535d; E61s aren't exactly known for reliability, as nice as they are! That isn't to say I've been quiet! That Merc has had a couple of things done to it lately, but all shall be revealed soon! God to hear it all came through what’s it like driving on the road? It's an interesting one! Great overall! Before another update comes it had a slight wallow on the back, in a very slow manner. It kind of suited the car but I wanted an improvement, mainly for cornering safety. The steering isn't the tightest thing but it feels great! It's not as quick as you'd expect for 211BHP, but then 1600kg with a 3 speed auto and a tallish diff won't make for that! It is swift however and builds up the speed quicker than you think! It's a lovely cruiser! I've ended up driving it around the countryside and through town for the hell of it! The Mondeo and 535d can cruise as well, moreso the 535d, but this 280SE just has a magic about it. More than my W124s did, but they still had a whiff of it . That’s a stately barge if there ever was one! I’m loving the English flag plate on a German car coming from the US, quite a few people would be puzzled I suspect Indeed! It's a US only model as well is the 4.5. No one else in the world would be daft enough to have a big-block M117 under the bonnet of a 280SE. Oh hang on, what did I just say? Lovely, but have I missed something? What is the connection to Carlisle? Cheers, but you have lost me on the Carlisle bit! Wow 15mpg....think the falcon is better than that. That's done a 'where the gauge is measurement' and not a tank to tank. I will probably do a tank-to-tank with later plans . But, a big-block V8 with a 3 speed auto, in a car weighing 1600kg with the aerodynamics of a brick won't really help its cause, especially on D-Jetronic EFI. IIRC, the XJS with Lucas' licenced 'D-Jetronic' did around 8-12MPG average, even with a manual 'box. It was only the Hotwire/HE cars that got better here . There's been changes with it as Matt is aware, but I'll come to that later .
brc76
Apr 24, 2019 23:13:15 GMT
I'd be suprised if it was much more than 15 mpg.
Last Edit: Apr 24, 2019 23:13:30 GMT by brc76
