Darkspeed
Club RR Member Number: 39
Our Westfield Seight Darkspeed
@darkspeed
Club Retro Rides Member 39
Dec 12, 2018 14:59:02 GMT
New studs and nuts for the rocker arms are available from John Eales - It's nice to have the adjustablity to correctly set the preload on the lifters.
Why did westfield need to hammer 7 shades out of the sump - what was it clearing?
tuxman
Dec 12, 2018 18:47:26 GMT
tuxman
Thatโs brilliant ๐๐๐ I wonder how you crimp them onto the injectors??
Darkspeed
@darkspeed
Thatโs brilliant ๐๐๐ I wonder how you crimp them onto the injectors?? May be just an assemble and push fit system.
Phil H
Club RR Member Number: 133
Our Westfield Seight Phil H
@philhoward
Club Retro Rides Member 133
I have a feeling itโs a push fit - the rather aggressive barb on the injectors mean the only way itโs coming off again is with a knife.
Darkspeed
@darkspeed
I have a feeling itโs a push fit - the rather aggressive barb on the injectors mean the only way itโs coming off again is with a knife. Agreed - I have some Mocal push fit hydraulic system fittings and I made a rookie mistake of thinking - that can't be right, just a push fit! .... As you say - it was then out with the knife.
Dec 14, 2018 10:03:05 GMT
Are you keeping the flapper system?, its fine when it works but parts are getting difficult to find and expensive now plus it's not really tunable, the hotwire systems use modern injectors and maf and are easy to use with aftermarket pcm's.
tuxman
Dec 14, 2018 18:20:35 GMT
Thanks guys great input !!! I will get the hose pack ordered then cut off whatโs there !! I wonder how tough to push them on ? Injectors are going away to be serviced . No plans to change the current system but who knows ๐๐๐ Trying not to spend too much as Iโm rebuilding the car to sell as I definitely do not need any more toys I am running out of garages ๐๐๐ Gearbox is back all rebuilt , lots of stuff back from being cleaned ready to paint ! Engine bay has all been cleaned and looks mint ๐๐๐
Dec 14, 2018 20:26:02 GMT
Can you change the length of those trumpets? Or have I got the wrong end of the stick and they're just a conduit for air and you can't actually tune the intake as it were? Keep up the good work!
Darkspeed
@darkspeed
Dec 14, 2018 21:09:54 GMT
Trumpets are fixed and are different lengths to balance the overall length of each port.
tuxman
I bet it would sound lovely on a set of throttle bodies ๐๐๐
Darkspeed
@darkspeed
I bet it would sound lovely on a set of throttle bodies ๐๐๐ I will let you know Although to me, the best sound from the RV8, no matter what the spec, is at idle
Dec 15, 2018 22:02:11 GMT
Boobs
Dec 16, 2018 13:27:14 GMT
Not sure how I missed this one. Looks like a cracking little car.
Davey
Resident Tyre Nerd.
Not sure how I missed this one. Looks like a cracking little car. To busy with the boobs.
tuxman
Dec 21, 2018 22:03:01 GMT
Someones going to be a busy boy this Christmas!
