tuxman
Ian
I very much like this.
Looks great on the late 90's OZ Volcano wheels too.
benhar
I find it hard to believe that that engine has only done 6,000 miles!
Looks more like 106,000.
Ben
Last Edit: Dec 4, 2018 15:38:57 GMT by benhar
Darkspeed
Club RR Member Number: 39
Our Westfield Seight Darkspeed
@darkspeed
Club Retro Rides Member 39
I find it hard to believe that that engine has only done 6,000 miles! Looks more like 106,000. Ben States that the engine had done 6000 in the Westfield - Ex Cop Vitesse engine did he say ? - will have been half way to the moon - an RV8 with low mileage looks like this inside.
At least it should have been well maintained if it was an ex-cop engine? I do like a V8 so am watching with interest for the outcome!
Darkspeed
@darkspeed
The engine looks like a well maintained high miler although high miles is a relative term with an engine so lightly stressed as the RV8 even 120K is not much and will only reveal itself as a slightly worn camshaft. A poorly maintained one will still keep ticking on but the inside of it will be a sight to behold.
tuxman
So just to confirm guys the engine did 6000 miles in the westy , no idea on the mileage when I bought it ! Sorry for the confusion . Tonite we finished stripping the crank out and the main shells were pretty knackered too , Crank looks great though and the general condition in the engine is very clean so as suggested the maintenance has been good . Heads stripped as well , the valves are pretty carboned up but do not look like they have been blowing . Valve seats all look good . The head ports are poor , I wonder how well the engine reacts with a bit of porting ? Exhaust port is tiny !! Also started cleaning up the engine bay as well .
Ahh now I am getting it you are not as silly as some of us thought....it could be many many etc more miles on that V8. Your threads are always good reading. I really enjoy this one too. Good luck with this awesome car.
tuxman
Thanks for the comments guys , flywheel in massive so will be lightened a bit . Was looking at the cam and there is some signs of wear !! Donβt want to change the rocker arms and rods ect so I wonder what cam would be best ?
Watching this with interest!
Like an engine with wheels, I love it! Looking forward to seeing how this develops.
no car, no garage, but the garage is coming oh yes!
tuxman
So a visit to Knight Engine services yesterday was very successful, Dave is a top bloke and after a inspection a plan of action has been decided : Hone the boor and new rings New cam bearings Polish the crank and new shells Completely rebuild the heads with new guides and springs Lighten the flywheel a bit . Everything to be given a good clean ect . Full gasket set sorted Rebuild oil pump New timing chain and sprockets . Gearbox has been sorted , turned out to be a broken C clip !!!! Being refreshed while itβs out . Hopefully everything will be back for Christmas ππ www.knightengineservices.co.uk/
tuxman
Dec 10, 2018 19:33:16 GMT
Oooo I love painting bits πππππ
Last Edit: Dec 10, 2018 20:28:39 GMT by tuxman
Our Westfield Seight johnthesparky
@johnthesparky
Club Retro Rides Member 6
Dec 10, 2018 21:51:10 GMT
So a visit to Knight Engine services yesterday was very successful, Dave is a top bloke and after a inspection a plan of action has been decided : Hone the boor and new rings New cam bearings Polish the crank and new shells Completely rebuild the heads with new guides and springs Lighten the flywheel a bit . Everything to be given a good clean ect . Full gasket set sorted Rebuild oil pump New timing chain and sprockets . Gearbox has been sorted , turned out to be a broken C clip !!!! Being refreshed while itβs out . Hopefully everything will be back for Christmas ππ www.knightengineservices.co.uk/Is that the place just outside Nether Heyford? Go past there quite often, and they always seem busy, good to know of a local-ish good place
Dec 11, 2018 16:43:28 GMT
You guys are a bad influence πππ To be honest the car does not need any more power !!! Itβs such fun and sounds so different with the under car exhaust It may not NEED any more power......
Dec 11, 2018 16:49:05 GMT
Great fix on the gearbox, must be some money left in the pot now for more BHP!! Not being picky but the sump pan isn't exactly a work of art or is that Westfield adapted?!
Dec 11, 2018 17:54:34 GMT
Great fix on the gearbox, must be some money left in the pot now for more BHP!! Not being picky but the sump pan isn't exactly a work of art or is that Westfield adapted?! I would always be worried that the sump would crack at those sharp creases
Dec 11, 2018 19:45:24 GMT
Great update. Are you having the heads done?
tuxman
Dec 12, 2018 14:46:11 GMT
Hi Guys , thanks for the input , yes itβs the place near Nether Hayford , yes sump hasxbeen tweakedfrom westfield , it does not leak thatβs the main thing !! Heads are being fully rebuilt and tweaked , Inlet plenum has all been stripped , injectors are being serviced and rebuilt , there is some talk of a can upgrade but the welded rocker arm adjusters will need to be modified !!! Engine bal has all been cleaned ect . Lots of photoβs to follow !
We want it to look the part too πππ
