so i got bored with my Lancia fulvia coupe , i am waiting for my caprenter to do the interior , and then I think I am gonna sell it .. i guess. I have no storage for it, and I like my cars old and rusty. just like my ladies anyhow (After this bad joke), i got myself a real crapola <3 the plan is to make a shop car, a real rusty bucket.... named....RUSTY. With logos of my shop.... (Check rust incorporated on facebook : www.facebook.com/rustincorporated/ or www.rust-incorporated.com ) this is how it looked. after making the deal , we started packing it... drivetrain...engine turns over, has compression.. could be simple.... full name is TAUNUS SPECIAL AND FINALLY HOME:
The car was in a front end colision, and the front was smashed m so this is thepart of the front end...: door glass is crackewd, I removed it and gave it to be be sample made for both doors. : removed the window regulator , but it had weird screws that hold it.: so i used this tool: part of the dirt and rust on the window holder : making the regulator move again after who know how long...: started to repair the nose : fixed the hinges , monts and the trunk lid is on : parts of the bonnet were broken and left on the hinges: that bit should go here.: welded:D the nose piece had a missing part, so a bit of paper, marker and some welding required.. almost there: finish : instead to remove the nuts that hold the fenders, they ripped them off : so I made the pieces that were missing, removed the nuts ... repeated the prossec on both of fenders to get this : edges of the fenders were cracked... somebody tried to weld it, but it cracked...: my welds don't crack .... and the final product. noice RUSTY, GOOD RUSTY : ITS GONNA BE A SWEET RAT ROD.... fuel tank is in great condition, just need some sand blasting and powdercoating: fun fact, fuel sender isnt stuck and gives a reading
Ford g73aDeleted
@Deleted
Please say you are rodding this??
Please say you are rodding this?? yuuuup
Ford g73aDeleted
@Deleted
Please say you are rodding this?? yuuuup Bookmarked!
Wow a "bückel" (hunchback) Taunus. Don´t think i ever saw one in real life.
79cord
Had to go look up how they were supposed to look originally. Look forward to seeing how you choose to change, customize & hot-rod yours. And to seeing how Ford had designed it originally; looks unitary structure with floor underneath frame rails for a smooth underbody?
Last Edit: Nov 5, 2018 2:57:33 GMT by 79cord
went to wash the interior with the power washer. couse you know, it cant get any worse, and i wanted to clean about 2 inches of mud..... well, it got worse.. the driver side footwell was screwed in witha rusty steel panel that was screwed into a rusty and muddy flo.r so basicly when i pulled that out. the car simply folded xD so i had to lift the car, and make the rocker panel and conect the part of the chassis that cracked and went under... lifted the chassis, welded the cracks, and then proceded to weld a l profile to make some rigidity. after that, i removed the whole floor panel went and made the floor panels and some l profils : D just welded it , spot welded so it will hold , so I can put it on the wheels. but it hold so well , I can jump inside and the chassis is rigid. also , the driver side door now close and open...normall< <3 this is simply. left over rust went to check the boxes of parts I got with the car , and clean what could be cleaned... brake cylinder rubber seals. actually , after cleaning..mint condition also , I have a question : What is this rear lamp from? can anybody gues? I only have one complete, and missing one lens, and I WOULD LOVE TO RETURN THEM ON THE CAR. FOR THAT MINTY CRAPPY LOOK.
e brake cable is all messed up. so I decided to remove it before instaling the suspension...so lok what i found... pin is kinda broken...... drum brake is kinda ok, bearing is mint : brake cable is messed up , also , central part of the cable, heated up , freed and will be galvanized : nuts and bolts camed from galvanizing. : and afcorse, lets put the susspension on (friend has photobombed ) : wheels are on the car (last one is from a tranzit, but it holds air, for now, i am good with it . it is a roller!!!!!
window glass made.: panhard bar on the front suspension is missing a rubber .. seazed main brake cylinder.... screw on the brake cylinder on the front wheel is stuck. gotta get him out. ... fuel tank and steel protection of the engine have been sand blasted. look mint and there is no hols in the fuel tank..... bits and pieces galvanized... fixed the codrivers window regulator, spot welded the parts... front hood hinges nice and galvanized. : detail of the instaled hinge.. : the hood is real high when everything is installed. : looks noice...
totti
Wow!Bookmarked!
65 'Ford Taunus 17m 66' Ford Taunus 17m Turnier 73' Ford Taunus 63' Ford Taunus Transit 1250 72'Ford Escort 2000cc 71'Ford Escort 1700 4 door 89'Ford Escort Express 87'Ford Fiesta Diesel 64'Ford Cortina 1500 deluxe 57'Volvo PV 444 Califonia 54'Peugeot 203 Commerciale 2004 Harley Davidson Fat Boy 78'Zündapp ZR 20 88'MZ ETZ 250
Nov 11, 2018 11:35:24 GMT
also , I have a question : What is this rear lamp from? can anybody gues? I only have one complete, and missing one lens, and I WOULD LOVE TO RETURN THEM ON THE CAR. FOR THAT MINTY CRAPPY LOOK. I'm pretty sure they're early Wartburg 311 lamps (the so called 'Schiffchen'). They're rarish and thus not particularly cheap though. Here's a few for example.
Nov 11, 2018 13:12:24 GMT
Well this looks pretty cool. Will be following this for sure.
Nov 11, 2018 17:23:56 GMT
This is really coming together. I didn´t expect it to look like a car quite so soon, judging from the first pictures. What´s the plan for a motor? The original four?
Nov 16, 2018 19:06:09 GMT
the continuation... broken piece on the fender : welded : support for the fender : painting the tank and some bits : brake cylinder : bits that need to be aquired : drivetrain : a mock up : instaling the driveshaft onto the diff : clutch bearing and the fork not sitting as they should, kinda stuck and dirty ... all better now : original for pot is in , the crew who helped: insideeee : choke cable...a bit broken : and it is out : dismantled : arty farty engine pic the ignition barrel, missing a key and a bit broken. needs to go out : but before, I need to remove the steering wheel : karb is pure dirt... : bits and pieces of the carb sent to be zinc plated.:
gess
Nov 16, 2018 19:14:51 GMT
Wow, so this rustbucket is really going to be a car again? Impressed at your effort and skill.
Ford g73aDeleted
@Deleted
Just incredible really. But you have proved us your talent in the past with previous projects. So really looking forward to see this thing run and drive!!!! A video when that moment comes!!!!
Ford g73aDeleted
@Deleted
Great efforts there
Ford g73aDeleted
@Deleted
Great efforts there
Nov 17, 2018 19:15:27 GMT
lazy saturday...made the hand brake cable... some steel rope , zinc plated outer cabling. all bits plated and voila. a cable..
