Nov 18, 2018 12:38:24 GMT
so , I was bored today....... carb before : i tried nitro dilutent, i tried carb cleaner, brake cleaner, acetone in a spray, nothing, it was even submerged in nitro for two days. it was stuck (choke flap) and dirty as F. But then I used my old cheap chinese utrasonic and.... and voila : even the choke flap is unseazed.
Ford g73aDeleted
@Deleted
Nov 18, 2018 15:48:57 GMT
That take long or use much energy? Did a great job.
Nov 18, 2018 18:49:54 GMT
That take long or use much energy? Did a great job. around 15 min , intervals are 480 sec , and I was rincing it with water after every interval.
Nov 25, 2018 11:45:50 GMT
had some keys made for the ignition lock : removing a bit of rust...... paint : installation: odmah smo sve lagere podmazali itd, da je volan sto mekaniji. i jest carbbbb... found some good material to make a gasket: in the middle of the process : here it is. gasket done glorious rusted carb all done
I am swamped with work in my shop , so I just cant do all the work i would like to , on my Kapitan , lancia and G73a... but I am making it happen... aquired some rubber gromets , for the shifter linkage and hood/body contact... this is how the shifter linkage was connected before installing the rubber gromets : how it should look : it wooorks !!!!
Dec 10, 2018 19:22:28 GMT
i have a lot of work around the house and the shop before christmass, so the progress is slow. crankshaft pulley was rubbing on the chassis. the marks are real old and rusty, so the car had to be driven like that long time ago. coupled with the wire that holded the shifter linkage, and a lot of hack jobs on the car, no wonder it was siting in a barn for30+ years, the car wasnt mantained... old engine mounts new engine mounts we built higher than stock 2 mm, higher than the old ones cca 13 mm : now the pulley is around 15 mm above the chassis : intake and exhaust. i wond sand blast it, i will give it to galvanize shop, even if it doesnt get galvanised , the acid in the dip , cleans iron cast like NEW. arty detail ford i am planing on converting the car to 12v and puting the modern alternator , electric fan ect, a ignition coil must be 12 v, this one isnt. and it is huge. and rusty... i will clean it , and restore it and put it in my storage, but i got a bosch 12v unit with the parts of that car, so i will use that one , and it can be dismantled and cleaned. two ignition coils, right one is 12 v: another piece of the floor. this one was bolt on and was eay to take it off. there is a part that can be removed and galvanized. so, lets take it out a little heat goes a long way. : its going : bits of kapitan and a master cylinder of taunus , to get galvanized. the cylinder ended up looking... awesome. i shall show it in the next post.
Dec 12, 2018 19:14:18 GMT
master brake cylinder : piece of sheet metal that i was heating and removing the screws with the gas welder : intake and exhaust camed from the galvanize shop. they look awesome. intal eis like new. the exhaust is cleeeean...just a bit of thermal paint on it and it will look minty das FORD : intake, exhaust and the carb assembled: when the car camed in my yard, I found something in the debris of dirt and rust...that metal piece i had it galvanized. ANd i found where it goes... broken pieces are off : this pieces should be together <3 : the part that is missing becouse of friction i will weld on : a bit of zink paint and voila : DONE!!!CLUTCH PADEL IS FUNCTIONAL !!!! window trim from inside was painted black. so i decided that I shall paint it black to, when i started cleaning them , i noticed that they were chromed...but somebody just applied some paint on them. removed all the paint and had it galvanized. i was hoping that the crome would be even shinier , and that the rust would have a lovely silver shade of zink. .... cleaning : and galvanized. the camara doesnt know what to do with the shine of chrome, so it looks darker and greyer, but it is in person super shini.. the rust is now gone , and it is all galvanized , and the scars are noticable.but look awesome. :
Dec 16, 2018 18:59:09 GMT
continuation , the gas pedal linkage is broken, need to address that.. welded, time to make it look a bit better: nuts and bolts came of wrong from the block... done right : shiny bits on : coil cleaned, painted, abits camed from galvanizing : video :
had a lot of work at hom e, buisness ect. but the car started. there will be pics, but for now. a video.... a first start.
Congratulations on the first start, always a major milestone of any project. Looking forward to more updates.
1951 Ferguson TED 20 / 1988 Ford Sierra Sapphire 2.0 1990 Isuzu Bighorn 2.8 Irmscher R / 1991 Pajero 2.5 SWB 1991 Vauxhall Carlton GSI3000 / 1991 Toyota Corolla van 2.2TD 1992 Toyota Corolla 1.6 GTI / 93 Ford Granada Scorpio Cosworth 1994 Toyota Corolla GXI / 1995 Toyota Corolla 1.6 Si 1995 Nissan Vanette / 1997 Toyota Starlet 1.5td Glanza 1997 Toyota Carina E saloon / 1998 Toyota Carina 2.0 Exeuctive
amazing stuff!!
first.make the cable for the chock... material : i welded a wire to the lever, so I put the plastic part in cold water so it wouldnt melt. done : doing some work around the cooler , the purge valve is all clogged and rusted: debris inside : all well : fan shroud cleaned : to start the engine , the bit that is troubling is the electrics , not the mechanics (Or so I thought) : first, we need to give good power from the battery, this is the material : minus is going there: 50 years makes quite a difference in spark plugs, don't you think? : to be continued tommorow. ...
tried something new today. instead of pics , i made a couple of videos and pic all in one . it is on croatian but fas and self explanitory. i cleaned some rust with.... coca cola
totti
Hi! I hope you changed the engine oil befor the first run....!
Nice project!
Greet
65 'Ford Taunus 17m 66' Ford Taunus 17m Turnier 73' Ford Taunus 63' Ford Taunus Transit 1250 72'Ford Escort 2000cc 71'Ford Escort 1700 4 door 89'Ford Escort Express 87'Ford Fiesta Diesel 64'Ford Cortina 1500 deluxe 57'Volvo PV 444 Califonia 54'Peugeot 203 Commerciale 2004 Harley Davidson Fat Boy 78'Zündapp ZR 20 88'MZ ETZ 250
Hi! I hope you changed the engine oil befor the first run....! Nice project! Greet heck no there was no oil in the engine. none. also , the screw for the oil pan was so seized up it was imposible to take it out. and is it large (Like , 9 cm in diameter, so I think there is a wire mesh that filters the oil in tho bottom i guess). so I put new oil inside (15w40) and some engine cleaner, and turned it until the oil indicator (Which actually works) turned off the test lamp. so I was getting oil pressure. the next thing is to modify a an alternator on the pulley that this engine uses (like, 17 mm V belt) and making the bodywork and electrics work... also , when it`s going on the lift, to heat up the oil pan screw and try to remove it. to clean the oil pan (I aint planning od removing the oil pan)
Last Edit: Feb 3, 2019 10:38:59 GMT by amigaboy
totti
Yep,please clean the oilpan from the inside....and take a picture from,please!
next : first distributer cap. it didnt fit. : found the original bosch service manual , found the codes for the rotor and cap , and then i went to buy them... my distributor: bought those, up is original : had to modify the rotor to get better spark , also fix the condenser.. new super bosna spark plugs.. trim pieces for the headlights from an usa ford 1946... will look good : looking fiiiine
Feb 10, 2019 12:13:01 GMT
next : i decided to repair and modify the dinamo to 12v, couse it will look oldschool and try to get it to work with those chinese voltage regulators, becouse an alternator would be to new for it... so lets begin... : cleaning : removed : a detail of the dinamo and the safety plate for the brushes : safety plate clenaning from rust and paint to leave a smooth finish. in a furnace brushes and the brush holder : bearing on the rotor. a bit wet and moist. : made the bumper braket that was broken and a metal plate that goes on the driver side: can you ges which one are done? some bumper guards that I found on the local trash and the bumper on the car. prefit the bumper looks without shine , that is becouse i hade it galvanized. i plan to polish it , so the chrome will shine, and the rusted parts...well. they will be galvanized
Feb 10, 2019 18:15:34 GMT
it was sitting for a week. showing bits and pieces under the hood. TAKE NOTE: HEAVY RUSSIAN ENGLISH
dikkehemaworst
Club RR Member Number: 16
Ford g73adikkehemaworst
@dikkehemaworst
Club Retro Rides Member 16
And yet again sir , amazing work!!! Of course bookmarked. Thanks for Sharing.
