Oh, if it helps with shaft lengths the Rover Metro short shafts (the splined section) are 404mm long. MGF short shafts are 380mm long, but I don't have the length of the long shafts written down.
Where did you find those threaded bush ends? I like them!
smith4
Nov 27, 2023 20:36:28 GMT
smith4
Nov 27, 2023 20:42:04 GMT
The leafspring is off for some work, so the LSD is getting some paint.
When the longer bolts arrive, I can mount the spring perch to the LSD.
Then when the spring is back, these can be installed and wishbone lengths determined.
smith4
Nov 27, 2023 20:42:46 GMT
smith4
Nov 27, 2023 20:43:55 GMT
