smith4
Okay, so a bit more on the engine work. New rear seal, light flywheel fitted, new clutch fitted, SD1 timing cover fitted with new gasket and oil seal, new MGB V8/P6 water pump fitted, with P6 water pump pulley (need to get the correct bolts/screws for this, as the 5/8" ones on the parts diagrams don't fit - possibly M6 size as the water pump is new). When taking out the dizzy from the original timing cover (non SD1), there was no cam drive, so I had to find and purchase one. Some do not have the hole already drilled for the roll pin that holds it to the dizzy drive shaft, so if you need one of these also, make sure you buy one with the hole already in it!
smith4
May 19, 2022 10:41:25 GMT
Found a machinist and took the Offy inlet manifold to be milled down, so that the carb doesn't hit the underside of the bonnet bulge. I have a 6mm pertinax plate between the carb and manifold to prevent heat from the engine causing the petrol to boil when sitting in traffic or on long journeys. Photos below showing the Offy and Carter carb in place, but some more work to clean up/finish the inlet manifold are needed before mounting properly. I also want to clean up the valley area and put the new valley gasket on. Also, engine mounts, gearbox mount, SD1 timing pointer, and the steel alternator bracket are etch primed and being grey primered: Hopefully will get a welding day on finishing the other part of the engine mounts, and bonnet repairs. The rotoflex vertical uprights are now with Mr Speedy for modifying to run the larger MGF wheel bearings, CVs, lobros, as they are a lot stronger than the Triumph rear suspension. This set up with an adjustable lower wishbone will be designed to give me enough adjustability of negative camber, and toe settings, without the 'twist' that the Mk1 setup gives. Keeping the wheel stable at all times is very important for wheel/tyre/arch fitment. Once the rear suspension is made up (a way off yet!), then the body can come off the chassis, and the underside de-rusted and painted, and the chassis can de-rusted, painted up, and new parts fitted.
Last Edit: May 19, 2022 10:52:29 GMT by smith4
smith4
Sept 28, 2022 18:49:21 GMT
Sept 28, 2022 20:45:26 GMT
That’s coming on nicely 🙂
Nick
maf260
Sept 28, 2022 21:57:51 GMT
Is that colour Triumph magenta? A mate had a magenta GT6 many moons ago and I almost bought a magenta Dolomite Sprint, but it wouldn't start the day I went to buy it!
smith4
Sept 29, 2022 8:35:56 GMT
That’s coming on nicely 🙂 Nick Thanks, Nick. And thanks for the drawings too for the roto/MGF conversion. It should, once all done, give a strong and safe rear end for the V8 torque. Centring rings to go, and that should hopefully sort the brake side.
smith4
Sept 29, 2022 8:43:10 GMT
Is that colour Triumph magenta? A mate had a magenta GT6 many moons ago and I almost bought a magenta Dolomite Sprint, but it wouldn't start the day I went to buy it! It looks like magenta in some photos, but it's actually 'Traffic purple'. Quite bright in some lights! The Dolomite Sprint would have been a bit different to a 944 with a V8 Good luck with yours.
smith4
Sept 29, 2022 8:45:43 GMT
The assembly together! Locktabs on the backplate to be folded up.
Last Edit: Sept 29, 2022 8:46:34 GMT by smith4
Sept 29, 2022 11:05:40 GMT
Does look like magenta. I had a magenta Sprint for a while. Originally auto (horrible combination) converted to manual OD. Decent fast car with scarily inadequate brakes…..
The rear end will be somewhat challenged by the V8 torque. I’d suggest not going drag-racing 🙂
You moved the locking tabs then.
Nick
Last Edit: Sept 29, 2022 11:06:39 GMT by vitesseefi
smith4
Sept 29, 2022 13:13:14 GMT
Does look like magenta. I had a magenta Sprint for a while. Originally auto (horrible combination) converted to manual OD. Decent fast car with scarily inadequate brakes….. The rear end will be somewhat challenged by the V8 torque. I’d suggest not going drag-racing 🙂 You moved the locking tabs then. Nick Yes it does. GT6's can look nice in magenta too. The manual conversion for your Sprint was definitely a good move - much more drivability, plus overdrive for cruising Yes, drag racing may be out of the thought process!! Lol. The R160 LSD will do well as the upgrade from the Triumph diff, and the planned custom rear lower wishbones should stop the 'twist' that the Mk1 fixed spring set-up unfortunately has. As far as I have found in researching lower rear wishbones for the CV/roto conversion, if I have two mounting points per wishbone, and as far apart as sensibly possible, this reduces the amount the vertical link can twist at all. The Rotospit (rotary engine) featured in the Grassroots motorsport (magazine?) years ago, and also Ron Harper's Modsport Spitfire (currently raced by his son, Jack,) have 2x mounts per lower wishbone, and far apart. The rotospit has them made up from bar (looks like roll cage bar), and Ron's Spitfire has recently had a newer, lighter design of his wishbones made up. Like Ron's/Jack's Spitfire, I aim to have similar adjustable wishbones made up, giving rigidity, strength, and adjustment for camber and toe. That's the plan!
smith4
Sept 29, 2022 13:23:16 GMT
Next step is to cut this bit of bonnet out - both as a vent to allow some hot air to escape, and also to see how close the carb/air filter is to the top of the bonnet. The bulge just clears the top of the carb now, since the inlet manifold and carb adapter plate have both been milled down, but I can't see how much clearance there is for the filter. The bulge will need raising a little, but hopefully not dramatically - so therefore not really noticeable.
smith4
Sept 29, 2022 13:28:31 GMT
You moved the locking tabs then. Nick Oh, and well spotted - yes I did! I thought it was the last opportunity to do this before having the hub pressed in. I just touched up the paint on the bolt heads afterwards. As you said, it probably wouldn't have made a difference, but at least it's a bit more 'Triumph factory procedure' where I can.
smith4
Nov 30, 2022 19:51:30 GMT
Been working on the roll cage, bonnet, LSD, wheels, gear stick, so coming on. Amending the front cage by slicing, bending, tack-welding it to a better shape, so a roll cage company can use them as templates to make up some out of new tube. Cut the dashboard to get good angles. Also - took some brave pills and sliced the buldge, as it needs to be raised a little to clear the carb/air filter. More brave pills to sort the sill too! None of the sills are perfect, but the front of the pass side sill where it meets the bottom of the front wing/bonnet, was a little too high at the front. So this got sliced a little, hammered down, and re-welded so it was as straight as I could make it. A little bit of filler needed, but okay.
Last Edit: Nov 30, 2022 19:54:26 GMT by smith4
smith4
Nov 30, 2022 20:00:33 GMT
LSD looks like a version 2 R160 VLSD. At first viewing, looks like an open diff, but there is a section on the left where the viscous fluid is. Seems clean inside, needs a bit more de-rusting and painting on the outside. Tried on the backplate which makes the LSD bolt to the Triumph chassis. Needed a tiny amount of material taking off the inside, but fits nicely 👍
Nov 30, 2022 22:46:09 GMT
Nice work on the sill. Good idea cutting the cage to get the shape you need 👍
Great to see another update....but wouldn't it just have been easier to get the roll cage company to make a bespoke cage rather than faffing about yourself? Nickson would have done a great job on it.
Feb 28, 2023 14:22:45 GMT
Looks like a subaru impreza diff
Yep. R160 from a Subaru (ior usually is in the UK, i the States they're common in Datsuns too). Common upgrade on these after a chap down under started producing adapter bits.
smith4
Great to see another update....but wouldn't it just have been easier to get the roll cage company to make a bespoke cage rather than faffing about yourself? Nickson would have done a great job on it. Cheers mate. Yes, Nickson would have done a great job, but the funds didn't stretch to a company fabricating a cage for me. Some more updates coming 👍
