adam73bgt
Club RR Member Number: 58
Nov 22, 2017 19:32:07 GMT
Wasn't sure whether to put this in Technical or Questions but I think this is probably the right place.. I am a total novice when it comes to engine building/rebuilding. I've got an idea of what steps need to happen but I've never done one myself or paid for someone else to build one for me, so I'm looking for a bit of general advice of how to go about it The objective:I have an M50b25 engine from a BMW 525i, which I plan to turn into a 3.0 using the crank, rods and pistons from an M54b30 engine (think 330i, 530i etc.) I'll also be wanting to change the intake cam for the M54b30 version as well. This is something that has been done before, with varying degrees of expense, some videos out there show people reusing crank bearings etc... I've not got the M50 engine out of the 525i yet, and I've not yet sourced the 3.0 bits but I'm trying to get together an idea of what I should be taking to an engine machine shop as a list of things I need doing? Essentially something more detailed than "This crank in this engine pls" Or is it something I could consider doing myself? Measure the bearing clearances etc.? Also does anyone on here have recommendations for companies in the Midlands that would take on this sort of job? Apologies for a bit of a rambling and vague post but theres a lot of conflicting information on the 'net and as I plan to use the resulting engine in a daily driver, I want to make sure its done right and will be long lasting! The type of engine I'm talking about The eventual recipient of said engine
Nov 22, 2017 19:37:18 GMT
Dynotorque in tyseley or autobahn in Halesowen might be able to help out. I used to have a Boston green e34 saloon, lovely motors.
Nov 22, 2017 20:09:53 GMT
Bookmarked Positive thoughts : I had good results many years ago when I gave 2 dead engines to a machine shop, and asked them to pick the best bits - fix anything else - to get me 1 decent engine. The place is a local 1-man engineering place, not sure a bigger outfit would be interested. Strip what you can yourself so it's easier for them / cheaper for you (I removed and kept the heads so the shop only had to fix the crank/bottom end ) Negative thoughts : it sounds like a great idea but look at the prices of spares before you make a descision. BMW parts aren't cheap, some bits are dealer only £££. Add lots of labor £££ and you might be cheaper getting a good used engine or a complete car (MOT-failure?) as a donor.
Nov 22, 2017 20:43:59 GMT
can you not just put the 3.0 straight in?
anything is possible as a diy, minimal special tools needed really if you already have a decent collection, ring compressor and a good selection of torque wrenches ia about all you'd need on top of say a 200pc halfords toolkit.
plus some red plastigauge, finding a manual for it would be an idea to find torque settings and timing chain details.
adam73bgt
Nov 22, 2017 23:56:09 GMT
Cheers for the replies guys nomad Aye I would look to split the engine if its easier for them, could just get them to build the bottom end and I could fit the head at home or something. Parts cost wise, I'd be using used 3.0 parts, can usually get the bits for around £300 or so, so it would be the cost of labour on top of that and consumables like bearings, seals etc. welshpug In theory yes, but in practice there are a lot of hurdles to overcome with putting the M54 in an E34. Since I already have an M50, it would be easier to keep this and stroke it, mainly because of management and wiring simplicities. I was originally thinking of DIY'ing it, but read a couple of articles online about plastigauge perhaps not being so accurate? Which has made me re-think
One problem i see is actually getting a crank , rods and pistons on there own ? Will you actually be able to source buy that on its own rather than a full [ expensive ] engine ?
And if someone has removed said assembly is it going to be kippered ? Crank regrind ,new bearings , new pistons rings etc will all cost a lot .
wont the m50 map be totally unsuitable for a 50% increase in capacity?!
much cheaper to make a loom and ecu from the m54 work than building a whole engine.
can you not just put the 3.0 straight in? anything is possible as a diy, minimal special tools needed really if you already have a decent collection, ring compressor and a good selection of torque wrenches ia about all you'd need on top of say a 200pc halfords toolkit. plus some red plastigauge, finding a manual for it would be an idea to find torque settings and timing chain details. TBH I'm with welshpug on this one. Just what complicates putting in an M54 into your car? I'm sure you could pick up an entire E46 330i with tinworm etc. etc. for semi sensible money and then break the rest of the car for spares. You'd also be sticking with a fully OE setup which would bring about reliability benefits. I say this as my ZVH (CVH head onto a Zetec block) always had issues including : -Breathing ; most ZVHs out there are compromised here due to many people overlooking this part. With a bigger capacity this could be a problem for you ; more bore space ; more potential for blowby and oil leaks. -Parts ; I required a different tensioner for the cambelt. Ordering the bits was a nightmare at times -Other bits ; Where pipes and wires previously went they didn't. I did sort these out but the car rarely left me alone here or a 'get me by' fix. jimbo200sx has had similar issues with the D16 turbo build in his Rover and that's not even a 'bitzer' engine like mine. wont the m50 map be totally unsuitable for a 50% increase in capacity?! much cheaper to make a loom and ecu from the m54 work than building a whole engine. That's assuming it can't be unpicked. Regarding the EWS you could always tape the key up somewhere for it to work or pay someone to code it out. To be fair you may have been aware of the above. All I can say is if you do proceed keep everything clean and be methodical. Take loads of photos and have figures for the torque settings etc. I am watching this with interest as I am debating changing the big end bearings on my M3 as opposed to giving the work to a specialist. I am worried but OTOH "how hard can it be". On a £300 engine I would be a little apprehensive but with S54s costing £3k... Like you I've not done much engine work. I've changed heads in the past and have changed the odd camshaft along the way.
Last Edit: Nov 23, 2017 9:21:10 GMT by ChasR
Nov 23, 2017 10:52:12 GMT
just a note I have a complete m54b30 sitting on a pallet beside me (in Belfast) I removed it from my e39 530i sport due to head gasket failure, was quicker and easier for me to buy a complete running engine and throw it back in, I recall the head gasket kit alone was a couple of hundred quid hope this helps
Nov 23, 2017 11:10:40 GMT
Suggest you cost everything carefully before you deciding which route to follow. I changed a starter motor on a 2007 325i (? N52 B25, 3 litre) earlier this month, unexpected bills include replacing the "one-time-use-only" *alloy* starter motor bolts £10, and a new inlet manifold (you need to remove that to see the starter) £40. That's £50 in extra parts just for a simple bolt-on job Time : many days looking around the forums for advice, then several hours to do the actual job. A failing pressure sensor was replaced at the same time, another £100 part ^ Like others, I'm familar with pre-2000 engines and have done plently of cylinder heads etc, but I'm now looking into doing my first crank refresh (on a Retro). The cost and complexity of working on a modern'ish BMW has been a shock to me
adam73bgt
Nov 23, 2017 11:31:13 GMT
Cheers guys skkylinedave the parts are pretty readily available as 'stoker kits', its a fairly common mod to do to M50's, an alternative is to use the same rotating assembly from an M52b28 to make a 2.8 stroker. so I'm not too concerned about finding the right parts, the bit about crank regrinding is good though, something to take into consideration, new rings and bearings I would be assuming anyway so I'm not too bothered about the cost of those. welshpug 20% increase in capacity by my maths? going from a 2.5 to a 3.0? (I'm selling/throwing away the 2.0 engine currently sat in my 5) ChasR Both please trust me when I say the M50 stroker is the preferred route to trying to put an M54 in an E34 Its a mod that has been done before so I'm not going off the beaten track here. Issues with an M54 would be trying to make all the OBD2 level sensors etc. work with the OBD1 E34 body loom, also M54 is aluminium block, which while not an issue in itself, does limit future mods in comparison to the M50 iron block. nomad Aye I've done a bit of costing work so far on parts and they're not too bad in my opinion for the M5x-era stuff. The machining costs is something I would try to get a ballpark figure on when I find a suitable place to do the work Overall I'm set on doing the stroker mod, so while putting an M54 in is 'a way' of doing things, its not what I want to do. The point of the thread was more to understand exactly what would be involved so I'm armed with a bit more knowledge when it comes to talking to an engine rebuilders. So far I'm thinking the following: Hone of the bores ahead of fitting the replacement pistons New piston rings, gaps checked Measurement of big end bearing caps and buying new bearings to suit? Measurement of crank, polishing/regrinding if required? I could just go into a machine shop and say 'whats it gonna take to mate these parts' but thought it would be good to go in armed with some info. Also wanted to get recommendations for places as I've had issues with garages/bodyshops/wheel refurbers doing curse word work before and I really don't want to be dealing with a place that mess up my engine! Cost wise, I'm not trying to do this on the super cheap, I appreciate it will cost a bit of money (within reason) but I will have a freshly rebuilt engine as a result, which to me isn't such a bad investment
Nov 23, 2017 11:44:18 GMT
It sounds like it is a keeper . Still think M54 but I can see the reasons (cough, Emerald or MS). One thing I will say is from the circles I've previously been in I'd personally get a polished or unground crank preferably speaking if yours needs a regrind. It was the difference in the RST world between a stock CVH making 300BHP on a stock forged crank or failing miserably. I think even the Stag world it was fine. For an occasional use car it would probably be OK but it sounds like this will become your daily again... Tufriding can get around this potentially.
Nov 23, 2017 12:43:10 GMT
does the OBD2 thing just mean a single 4 pin sensor for engine and dashboard rather than the separate pair of two pins for the older vehicles?
still 20% difference in capacity is enough for the maps to be wrong, it may well run but nowhere near ideal.
I'd have thought an alloy block was a plus point, stiffer and lighter?
Nov 23, 2017 13:24:18 GMT
The bottom end swap can be done without having to change the existing engine sensors and ECU. Changing to another engine, especially an OBD2 M54 is a LOT more work overall for less power (standard the M54b30 is ~230?). Reported figures of stroked M50s put them at 240-260 depending on supporting mods like intake and cams etc. From my overall understanding the current MAF sensor will see additional air flow and additional fuel will be added, with the lambda sensor helping trim it. Off the top of my head I think you can basically drop the stroked bottom end in and the ECU will just work. EDIT: apologies, a quick bit of reading says you will eventually need to update the calibration, but the car will run on the base ECU, map and injectors. So running and debugging can be done on the engine without having to do ECU/mapping work in tandem. The M50 has an iron block versus the M54s aluminium - the M54 engines are known to not like overheating and can be prone to some lasting damage if that ever happens. As a base engine for further modding it M50 is largely seen as more robust. The weight difference in a steering-box driven 5 series wagon isn't exactly going to matter much I don't think
Last Edit: Nov 23, 2017 13:27:38 GMT by Rafftank
1995 BMW E34 525i Sport - Avus Blue on the outside, brown and crusty on the inside! 1998 BMW E36 328i Sport - Daily Commuter
Nov 23, 2017 13:24:44 GMT
does the OBD2 thing just mean a single 4 pin sensor for engine and dashboard rather than the separate pair of two pins for the older vehicles? still 20% difference in capacity is enough for the maps to be wrong, it may well run but nowhere near ideal. I'd have thought an alloy block was a plus point, stiffer and lighter? I think Adam is referring to them overheating. Certainly with the M52 it suffered from a few issues including: -Sulphur killing the bores ; this admittedly is now a historical issue and oddly Nikasil is meant to be harder than cast iron in terms of a surface for that application. -Blocks becoming brittle after sustained overheating, meaning you are banking on helicoils/timeserts of keeping the head on the block correctly, assuming the block's not too brittle. Not an idea scenario for a brand known for not having the best cooling systems. -I'm guessing there are tuning benefits too like going Turbo etc. The M50 bottom end is known for being tough. I *think* he could get lucky on the maps. I think BMW may have made an M50B30 but for other markets like Japan. I know a racer was on about "slipping" in a 3.0 into an E36. With that being the case he could always acquire the ECU as well.
Last Edit: Nov 23, 2017 13:25:27 GMT by ChasR
adam73bgt
Nov 23, 2017 13:46:58 GMT
Yeah M54s are a bit prone to overheating, also the M50 iron block is very well known for taking Booost (Not that I'm thinking that now, but its always good to have up my sleeve in the future) Maps wise, as has been covered, it will likely run on the b25 map, but the ECUs are readily mappable for the slight extra capacity. In the US, the E36 M3 got the S50b30US engine which is essentially very similar to what I'm planning to build as it had more in common with the M50 than the 'proper' S50 we got over here with its itb's etc. So theres a bit of something to copy there in terms of injector sizing, mapping etc. In terms of the machining work, I think I've got the gist of what I'll need, I'll have to talk to a few places directly to see what they can offer. Any more recommendations at all? Particularly around the Coventry area would be handy but will travel for places known for good work!
Nov 23, 2017 14:19:21 GMT
I think my Porsche specialist used to use someone in Coventry. If you wish you can contact him, but he is grumpy and not always helpful! Kevin/Ben or Alex Eacock at EMC Motorsport will know where to go. I know Ben and can ask him if you wish. AFAIK they are the only outfit to have a 968 finish the Britcar 24Hour, so they know what they are doing .
Last Edit: Nov 23, 2017 14:19:48 GMT by ChasR
Nov 23, 2017 14:58:27 GMT
Nov 23, 2017 16:00:37 GMT
Get the engine shop to measure up the journals and buy the appropriate bearings or regrind oversize etc.Id always get a crank polish when swapping the bearings even for std size.
I prefer it when customers just bring and engine or bits in and say can you make that work. Not sure on the specifics but if the crank journals are the same size between 2.5 and 3.0 it'll be exactly the same procedure as a normal rebuild. If the bores are good get them flexy honed and then block skimmed, pistons cleaned and new rings fitted, crank measured and polished/ground and then all put together with new bearings. Won't be mega expensive, though it's always nice getting the parts through whoever you use unless they're very expensive or can't get them.
