Curtis
Sept 14, 2017 9:26:22 GMT
So I'm getting ready to have a 10x8 shed/workshop fitted in the back garden. One side will be for my old games consoles and other such mancave nonsense, and the other I want a proper workbench for the numerous projects that I do for fun.
I'll definitely be getting a vice, I'll have my soldering iron and dremel stand stationed in there too. What other things would you suggest? I'm thinking grinding stone, mitre saw, maybe a pillar drill?
Lets hear your ideas
Driving: Shitbox Honda S-MX
andy-v
i like cookies :D
Sept 14, 2017 9:27:33 GMT
hammer
Sept 14, 2017 9:33:22 GMT
bench grinder / wire brush, decent pillar drill if you have space. angle grinders, at least 4 of them.
andy-v
i like cookies :D
Sept 14, 2017 9:43:35 GMT
tape measure
Sept 14, 2017 9:44:24 GMT
Angle Grinder, Hammer, Pillar drill, Welder.
with these you can make most things..
Take the Next slot right coming up on the left.
Sept 14, 2017 9:45:10 GMT
a blowtorch for those stubern nuts n bolts
andy-v
i like cookies :D
Sept 14, 2017 10:05:48 GMT
safety glasses/goggles.
Sept 14, 2017 10:49:02 GMT
Beer fridge and a kettle/tea station
fogey
Sept 14, 2017 10:53:22 GMT
Gaffer Tape to stick bits that need sticking. WD40 for bits that are stuck but shouldn't be.
Pillar Drill is a good idea but get a decent one - the cheap ones have too much play for accurate drilling.
adam73bgt
Club RR Member Number: 58
Must have workshop toolsadam73bgt
@adam73bgt
Club Retro Rides Member 58
Sept 14, 2017 10:54:03 GMT
hydraulic press so I can come round and do my suspension arm bushings, please and thanks
Sept 14, 2017 10:55:23 GMT
joddler welder mask , avation tin snips, descenet ball pain hammer. panel hammmers straight edge ,box of beer for EMERGENCEY USE ONLY ,when under pressure ,
Sept 14, 2017 11:23:50 GMT
a sturdy Bench, well bolted down.
fire extinguisher.
extractor fan, for when its too chilly to leave the doors open but its still smokey in there.
oil filled radiator for heat.
Sept 14, 2017 12:33:04 GMT
As boring as it sounds, get the tool you need for the job Most of the tools i have i bought over many years specifically to help with certain tasks Unless you're in a Brewster's Millions situation and you need to spend a certain amount before the time runs out. In that case, something like this
Sept 14, 2017 12:39:43 GMT
A BIG ROLL OF BLUE PAPER keeping hands clean
Must have workshop toolsChasR
@chasr
Club Retro Rides Member 170
Sept 14, 2017 12:46:05 GMT
As boring as it sounds, get the tool you need for the job Most of the tools i have i bought over many years specifically to help with certain tasks This. It really is car specific. Short of your generic tools like sockets, hammers etc. some cars can have certain tools that are a life saver; my Spring clip removal tool for instance has been handy on so many moderns now. But otherwise that is it. I'll assume you have sockets, jacks, axle stands and so on. I have these tools which I tend to use more often or save alot of time with in comparison to the others. - Impact Wrench 1/2" ; it's sped up jobs alot!
- Gear/pulley pullers ; On some bushes these have made the job alot easier like E46 Lollypop bushes and rear ARB joints
- Laptop; saves me chasing things I don't need and seeing what the car thinks is wrong
- Various oil filter removal tools ; easier to remove and saves wrecking a driveway
- Vice on a solidly mounted bench ; I won't say any more here
- 2 types of drain trays ; One of them is a pain to clean up for oil but has a large capacity
If I wanted more it would be the following, but I need the space for it: - A car lift of sorts
- Large air compressor
- Various air tools
- I'm sure I've missed something!
Must have workshop toolsaccord83
@accord83
Club Retro Rides Member 51
Sept 14, 2017 12:57:51 GMT
Car boot sale sound system, cheap and therefore replaceable. (or just blag one off someone upgrading.)
vanpeebles
I am eastbound in pursuit of a white Lamborghini, this is not a recording.
Sept 14, 2017 13:40:13 GMT
Stilsons
fad
Sept 14, 2017 13:56:15 GMT
Eye wash station.
Sept 14, 2017 14:29:31 GMT
Oooh, a Mirror, handy when you get something in your eye! (had many things in mine lol) Bare in mind, that ring is 25mm across!
Last Edit: Sept 14, 2017 14:37:18 GMT by joem83
fad
Sept 14, 2017 18:09:09 GMT
Oooh, a Mirror, handy when you get something in your eye! (had many things in mine lol) Bare in mind, that ring is 25mm across! So THAT'S why you were winking at me!
