jelmerc31
Ja mar ik bin net benaud!
Last Edit: Jun 27, 2017 12:29:45 GMT by jelmerc31
1983 Datsun Laurel C31 3.0 V6 24v turbo--> 4.5 V8 32v 1986 Nissan Laurel C32 2.8 diesel 1984 Nissan Patrol 160 2.8i L6
1984 BMW E28 3.8 M5 sold 1987 Alfa Romeo 75 T.S sold 1985 Alfa Romeo 90 3.0 V6 sold 1996 Dodge Ram 3500 Cummins turbo diesel sold 1978 Dodge D300 Cummins turbo diesel sold 1985 Nissan Patrol 3.3 TD sold 1988 Alfa Romeo 75 2.5 V6 sold 1993 Alfa Romeo 75 1.8i.e sold 1986 Alfa Romeo 75 1.8 turbo sold 1984 Nissan Patrol 3.3 D sold
berendd
mooi spul man!
gess
Jun 26, 2017 10:06:05 GMT
Nice Retro project! I never really liked these Datsuns when they were around, but now that they are retro I Think the are cool. Strange how ones opinion change over time. A sleeper retro is never wrong, and this really has potential. The box shape, the chrome trim, few will expect it to be a racer. These braided fuel hoses that you connect to the injectors with jubilee clips, are they safe? Will the clip hold against the fuel pressure?
jelmerc31
Jun 26, 2017 10:16:56 GMT
Those clips should be fine, normaly there are not even clamps on there. The clips I used are oem Nissan and used in the fuel system too.
jelmerc31
jelmerc31
Not far from running now! I changed the timing belt, idlers, cam and crank seals and the waterpump 20170705_214142 by Jelmer Eppinga, on Flickr 20170711_210913 by Jelmer Eppinga, on Flickr I trew some paint on the subframe area's which are welded 20170711_210904 by Jelmer Eppinga, on Flickr 20170711_210859 by Jelmer Eppinga, on Flickr After a couple of years I will go over the car. I will get painted and the suspension, axle and subframes wil get powder coated. The tank is fitted. All new stainless hose clamps. I also poured Owatrol oil on top of it. 20170711_210845 by Jelmer Eppinga, on Flickr Filler hose is a temporary solution till I find a suitable hose. Any suggestions? 20170717_152134 by Jelmer Eppinga, on Flickr I made an extra support to the chassis rail to take some load too 20170712_193104 by Jelmer Eppinga, on Flickr Engine back in and bolted down! 20170712_210352 by Jelmer Eppinga, on Flickr Fitting hose clamps was never as exciting as now!! 20170712_210414 by Jelmer Eppinga, on Flickr 20170712_210401 by Jelmer Eppinga, on Flickr Airfilter to turbo setup. I don't like all the shiny stuff onder the hood so these al wil be painted in wrinkle black later on 20170713_220130 by Jelmer Eppinga, on Flickr 20170713_220216 by Jelmer Eppinga, on Flickr We are getting there! The thermostat housing is not on yet because it was hitting the timing belt cover so I made it clear and no it is at the welder again 20170713_220101 by Jelmer Eppinga, on Flickr Overflow bottle fitted. It has a blue silicone hose on it now but this will be a black one offcourse 20170717_154216 by Jelmer Eppinga, on Flickr And latest job is the down pipe. This is temporary again because I want to make a 3" dump pipe out of stainless steel later on. That is way I welded it mayself with regular steel. 20170717_142619 by Jelmer Eppinga, on Flickr 20170717_142626 by Jelmer Eppinga, on Flickr Biggest jobs are now: * Have gearbox rebuilt * Fit new rear crank seal * Fit flywheel and clutch * Have driveshaft welded * Hook up crank angle sensor * fill engine with oil and coolant Can't wait to drive it!!
jelmerc31
Aug 28, 2017 14:25:54 GMT
It is running!!! I fitted the crank seal, flywheel, spigot bush, and clutch 2 weeks ago but I coudn't get the gearbox in. I lined the clutch up with a bolt which I made thicker with tape since I didn't have a clutch line up tool. Than I realized the Patrol 160 has a input shaft which you can take out after removeing 6 bolts so I took that out and fitted it but It woudn't go into the spigot bush. So I took everything off and replaced the spigotbush from on the the engines I have laying around. Good thing Nissan used this bush in all engines from the 60's! Same with the clutch line up, almost every RWD Nissan uses the same spline count! So now the gearbox would go in and I could fit the starter. After that I changed the oil and cranked the engine for oil pressure which was pressent after only 10 seconds! It is not all progress because I bolted down the power steering pump and the tab broke off. Ordered a used pump and bolted that in. 20170727_214742 by Jelmer Eppinga, on Flickr I also had the valve cover welded. 20170726_205831 by Jelmer Eppinga, on Flickr Now almost everything was in and it was time to start the engine! After some trouble with the engine speed signal and fixed timing the engine fired up! 20170827_125224 by Jelmer Eppinga, on Flickr 20170827_125244 by Jelmer Eppinga, on Flickr 20170827_125251 by Jelmer Eppinga, on Flickr 20170827_125659 by Jelmer Eppinga, on Flickr 20170827_125716 by Jelmer Eppinga, on Flickr Now I need to tuck some wiring away, weld the driveshaft and fit tires to the 280zx wheels for the left side and I can drive it!
jelmerc31
Oct 20, 2017 12:51:27 GMT
I haven't updated for a while but it is on the road for a couple of weeks now. Did a lot to it like lower it, replace shot bushings, tune the Microsquirt, fitt bigger sway bar from a S13 and stuff like that but the most fun was when I pulled away from an year old Audi when doing 180km/h!! 20171016_174527 by Jelmer Eppinga, on Flickr 20171016_174428 by Jelmer Eppinga, on Flickr 20171016_165739 by Jelmer Eppinga, on Flickr 20171003_141806 by Jelmer Eppinga, on Flickr Next steps are new bushes in the rear trailing arms, bigger brakes in the front, LSD in the rear end and fit disc brakes on the rear axle. Got all the parts, no I need time to do it!
Oct 20, 2017 17:30:02 GMT
Quality build!. Do you have to to to the RDW (dutch DVLA) for this engine conversion for a test? The number of cylinders stay the same but the increase in power is substantial and more then 15% i guess.
Peter
jelmerc31
Nov 20, 2017 10:42:30 GMT
petervdv: Yes, next year I wil go to the RDW. The car is off the road again for winter hibernation. Good time to do some upgrades! I took the gearbox off that still needs to be rebuild. I also ordered a speedometer gear from a Nissan Pathfinder D21 with V6 so that I can use the stock speedo cable. Only need to fit the Z32 gear on it for the correct reading. The D21 V6 2wd is the only car that has a suitable speedogear. The rest uses a smaller one or a electronic one. 20171113_213221 by Jelmer Eppinga, on Flickr 20171113_213221 by Jelmer Eppinga, on Flickr I also diasambled a spare rear axle. The axle shafts are huge for the stock application. Nissan is known for it its overkill strong rear ends! 20171118_135737 by Jelmer Eppinga, on Flickr Wednesday I will start on the Nissan S14 rear brake swap. I will have the axle housing sandblasted and maybe powdercoated. 20171118_144621 by Jelmer Eppinga, on Flickr I also tested if the LSD had the same spline count. Some H190 diffs have less splines but it fitted! 20171118_135955 by Jelmer Eppinga, on Flickr
Last Edit: Nov 20, 2017 10:44:13 GMT by jelmerc31
jelmerc31
Nov 24, 2017 21:14:10 GMT
the pipes came out well ! just to ease the wifes concerns, i can just clarify that your pizzas will only taste of enamel for a couple of months
jelmerc31
I little prgress. I had the painted parts stripped. 20171130_104319 by Jelmer Eppinga, on Flickr And than painted in wrinkle. I'm getting better with it! 20171203_142542 by Jelmer Eppinga, on Flickr 20171203_142648 by Jelmer Eppinga, on Flickr Next is sand back the ribs and letters and put it back on! 20171203_142720 by Jelmer Eppinga, on Flickr Another job is fitting disc brakes on the rear axle. I'm using 200sx S14 calipers and needed discs to fit the 4 stud patern. So I searched and ordered Primera P11 rear discs. I took them with me to a friend who has a lathe to make the center hole fit but found out that the stock Primera discs fits spot on on the Laurel rear axle! 20171125_154755 by Jelmer Eppinga, on Flickr 20171125_154810 by Jelmer Eppinga, on Flickr I also wanted a sway bar on the rear and looked at other RWD cars and found a Nissan Patrol one at a friends. Should fit pretty good! It is pretty thick at 20mm so I will be pretty tail happy.... 20171125_154431 by Jelmer Eppinga, on Flickr And than it happend! I came across a youtube video of a Nissan V8 powered 200SX. I have looked at these engines before but shipping from the US or Japan is pretty high so I never went ahead but a friend of mine shippes a E28 M5 from the US and offered me to take a engine for so little money I HAD to buy one! So I did.... VH45-1 by Jelmer Eppinga, on Flickr VH45-7 by Jelmer Eppinga, on Flickr VH45-4 by Jelmer Eppinga, on Flickr VH45-3 by Jelmer Eppinga, on Flickr
melle
South West
It'll come out in the wash.
Great attention to detail, wrinkle paint looks good.
Jan 31, 2018 17:25:28 GMT
Got the link from my Gloria thread. Congrats this is a great build, can't wait to see the engine running.
jelmerc31
Thanks!The VG30DET wil go on to the dyno in a couple of weeks to up the boost. The V8 will go in next winter.
jelmerc31
Is that V8 from a US-market Titan pick up? And will it fit in the Laurel? (Go on - make it fit anyway!!)
a v6 is nice but a v8 is nicer! Will You go to the dutch DVLA with the V6 first and another go with the V8 or will you do the v8 conversion first and then to the dutch DVLA? A shame you did a lot of work on the V6 conversion. Like your thorough approach. Keep up the good work! Peter
