Dang, son!
brilliant work....a real nice "sleeper" if the body is left alone....what are your plans for bodywork if any? (I like it the way it is too...)
JP
jelmerc31
Ja mar ik bin net benaud!
Mar 10, 2017 15:43:17 GMT
Body will be stock. It will get 14" 280ZX wheels and lowering springs with Koni shocks.
Last Edit: Mar 10, 2017 15:44:21 GMT by jelmerc31
1983 Datsun Laurel C31 3.0 V6 24v turbo--> 4.5 V8 32v 1986 Nissan Laurel C32 2.8 diesel 1984 Nissan Patrol 160 2.8i L6
1984 BMW E28 3.8 M5 sold 1987 Alfa Romeo 75 T.S sold 1985 Alfa Romeo 90 3.0 V6 sold 1996 Dodge Ram 3500 Cummins turbo diesel sold 1978 Dodge D300 Cummins turbo diesel sold 1985 Nissan Patrol 3.3 TD sold 1988 Alfa Romeo 75 2.5 V6 sold 1993 Alfa Romeo 75 1.8i.e sold 1986 Alfa Romeo 75 1.8 turbo sold 1984 Nissan Patrol 3.3 D sold
jelmerc31
I had to take of the intake manifold to get to the injectors which had to go because they are low impendance ones. But to take of the manifold you have to take of the timing belt! I wanted to wait with this untill I take the engine out for the final welding of the brackets on the subframe but I'll replace the timing belt, seals and idler pulleys now. One intake bolt was stuck and I coudn't get to it with heat so it snapped: IMG_20170321_200559206 by Jelmer Eppinga, on Flickr I had to drill it out but it is a 10.9 one so the drill woudn't center really good. No I just put a treaded sleeve in there. IMG_20170325_113900332 by Jelmer Eppinga, on Flickr Another job I did was making a bracket for the Patrol Y60 steering fluid resevoir. It only needs a lick of paint, the hose from the resevoir to the pump and the steering is done! IMG_20170325_113915045 by Jelmer Eppinga, on Flickr IMG_20170325_114012820 by Jelmer Eppinga, on Flickr IMG_20170325_114019249 by Jelmer Eppinga, on Flickr IMG_20170325_114404390 by Jelmer Eppinga, on Flickr I also got 4 VAG coils in. I needed really short ones, the 1.8T ones that most use are to tall but I took the coils out of my daily Bora 1.6 16v to see if they would fit and they did. Even the cover don't hit them: IMG_20170325_134106240 by Jelmer Eppinga, on Flickr IMG_20170325_134115209 by Jelmer Eppinga, on Flickr
Mar 27, 2017 10:39:48 GMT
Hope you clamped that hose! Looking good, though.
jelmerc31
Mar 27, 2017 11:35:25 GMT
Not yet! I plan to replace/fitt all clamps with stainless ones.
Davey
Resident Tyre Nerd.
Looks great. Real nice work. Are you replacing the rocker cover as well? Or just gonna keep the engine nicely bathed in oil to prevent rust.
jelmerc31
Last week I fitted the C31 sending unit to the C32 tank. I used a S13 craddle but coudn't use the S13 sending unit so I went with the oe C31 sending unit and placed it next to the fuel pump craddle. I simply made a 50mm hole, put in 4 blind rivet nuts and use a gasket to prevent leaks. IMG_20170331_160129653_HDR by Jelmer Eppinga, on Flickr Next job was to fit the tank. One side bolted up but the the other side didn't, so I made an adapter. I also fitted the braided fuel hoses. IMG_20170331_163840260 by Jelmer Eppinga, on Flickr IMG_20170331_144017000 by Jelmer Eppinga, on Flickr IMG_20170331_163850672 by Jelmer Eppinga, on Flickr I also played with the radiator hoses. The top one fits but there is quite some tension on it so I will have the alu tube extended. Otherwise the hose will fail at some point. IMG_20170327_193533109 by Jelmer Eppinga, on Flickr IMG_20170327_193541587 by Jelmer Eppinga, on Flickr The fuel injectors are a strange setup and are to small for future upgrades. IMG_20170329_195803979 by Jelmer Eppinga, on Flickr I bought Bosch EV1 440cc injectors which have the same outer dimensions as the stock ones so they will fit. I tested if the fit by using an old Bosch/Denso injector IMG_20170329_195747138 by Jelmer Eppinga, on Flickr The new injectors will be machined so that they can take a hose on the top and I will be using the top fuel rail only. There is no room for an universal fuel rail.
jelmerc31
Apr 12, 2017 11:38:15 GMT
jelmerc31
Apr 18, 2017 10:46:11 GMT
i've been using riv-nuts quite a bit recently. i do like them but the way it makes the item "stand-off" the panel annoys me a bit. do you know what i mean ? it puts all the leverage/weight of mounting flanges on the edge of the riv-nut itself, rather than larger area which used to contact the cross member/panel/outrigger whatever it is.
jelmerc31
Apr 18, 2017 11:11:26 GMT
jelmerc31
Apr 26, 2017 16:29:34 GMT
Looking awesome
melle
South West
It'll come out in the wash.
Apr 26, 2017 19:29:34 GMT
Great project!
jelmerc31
Glad I only have to worry about a measly 140km/h...
jelmerc31
I got the fuel rail fitted with braided hoses and stainless hose clamps. Works perfect this way. IMG_20170514_114038075 by Jelmer Eppinga, on Flickr IMG_20170514_114056993 by Jelmer Eppinga, on Flickr Than I finaly could install the lower manifold again and start working on the Microsquirt install. A big mess with all the new connectors, wires, solder gun, paper work, cutters, crimp pliers and heatshrink! IMG_20170517_172651835 by Jelmer Eppinga, on Flickr IMG_20170517_172609438 by Jelmer Eppinga, on Flickr IMG_20170517_165742230 by Jelmer Eppinga, on Flickr IMG_20170517_165723438 by Jelmer Eppinga, on Flickr IMG_20170517_165734424 by Jelmer Eppinga, on Flickr I also got my chinese blow off valve in. IMG_20170517_191456405 by Jelmer Eppinga, on Flickr
Davey
Resident Tyre Nerd.
Love the valve, would you like your blow off to be soft or hard.
jelmerc31
I like it the hard way...
May 18, 2017 10:11:54 GMT
Goe gedaan jochie
