Dez
Club RR Member Number: 34
Dec 20, 2016 17:46:51 GMT
Had exactly the same with that Audi 100 I had. Went to Northampton to pick up a 'great daily driver' Within two weeks of having it home head gasket had gone, bad luck or done over? It's another cool motor for you tho Mate The guy i bought it for claimed he'd been to Kent from Manchester in it more than once, but I think that's bull. It has all the signs of a car that has had very little use, and often putting them back into service throws up problems Like this.
Dez
Dec 20, 2016 17:53:24 GMT
I actually quite like the L series, I'd possibly put another big 6 in if it wasn't too expensive. But they all seem to be. Finding a gearbag at OK money is proving difficult though. I have an S14 SR20DE and manual box (complete setup) coming my way... Not enuf cyls doe M9. Needs to be a 6 minimum. Apparently RBs drop in, they came with them in some markets. Expensive for what you get though, and I'm not overly concerned about turbos with the build style I'm going for. Would rather triple carbs or itbs. A Lexus v8 would also be cool, but all the gearbox expense outweighs the motor being cheap.
Dec 20, 2016 18:02:37 GMT
Jag or bmw straight six and Manuel?
*n
quackshot
...friggin' cars...
Dec 20, 2016 22:45:52 GMT
I have an S14 SR20DE and manual box (complete setup) coming my way... Not enuf cyls doe M9. Needs to be a 6 minimum. Apparently RBs drop in, they came with them in some markets. Expensive for what you get though, and I'm not overly concerned about turbos with the build style I'm going for. Would rather triple carbs or itbs. A Lexus v8 would also be cool, but all the gearbox expense outweighs the motor being cheap. Do you want an LS400 then? Got one of those too.
Dez
Dec 20, 2016 22:50:54 GMT
Only if it's got the appropriate supra box in the boot. Is w154 still the done thing?
Quite a few people over here are using bmw boxes or w series toyota boxes.
qwerty
Club RR Member Number: 52
BMW getrag boxes seem to be popular and also seen a couple of mentions of RX8 boxes on the Lexus V8's.
Tom
Surely at this stage it would be entirely logical to get the wheels and stance sorted ?
Dez
Dec 22, 2016 12:12:33 GMT
Surely at this stage it would be entirely logical to get the wheels and stance sorted ? Already a few steps ahead on that one
Dec 22, 2016 15:53:06 GMT
Surely at this stage it would be entirely logical to get the wheels and stance sorted ? Already a few steps ahead on that one You don't surprise me in the slightest. :-D Well I don't think there's any need to stand on ceremony mate !?
Dez
Dec 26, 2016 20:07:17 GMT
Well, me gran had a word with sandy claws, and I was provided with a box full of rusty old sh1t- And a box full of shiny new bits too, at no outlay to myself, which is nice. The coilovers are from Max speeding rods via eBay, and for the price really cannot be faulted. Camber adjust top Mounts, platform adjust, short stroke dampers, platform adjustable, specified Spring rates and 24 point damping adjustable, for £275 for the set. After sales service gets surprisingly good reviews too. More importantly, they go bloody low! These are s13 fitment, as are the new (old) hubs. with a few tweaks they fit the c32 platform.
Last Edit: Dec 26, 2016 20:08:59 GMT by Dez
dazcapri
North East
Enter your message here...
Dec 26, 2016 20:19:37 GMT
I got socks not quite as good as yours
Mk3 Capri LS
Dez
Dec 26, 2016 20:22:13 GMT
My family don't even try anymore, my mums phrase was "we'll just give you some money so you can buy some random bits of metal "
Dez
I'd best keep updating this since the photos are racking up. I dived straight in and tore the front end apart. Found a properly knackered lower ball joint, only £11 for a new one though. One the front the top mounts bolt straight in, you have to swap to s13 hubs and 'knuckles' as the c32 struts are one piece. This means you also have to swap the brakes, as they're not compatable. There is also a steering issue, the taper for the track rod end is a different size (smaller on the s13) so something needs to be done there. I could bore the taper larger, but there is also an issue with the shape of the track rod ends, the c32 one has a kink to kick it level again where it meets the hub, which it needs to not have to work with the s13 steering arms, they need a 'straight' end. There's a couple of options using s13 or skyline parts, I need to sit down and measure up and price out which one is best. But what you want to see is it assembled, right? A bit shorter than stock- Coilies and hubs in- And a tasty wheel thrown on for mockup. This is full droop- There's room for adapters on the front so I won't need to redrill. I chucked the stock wheels back on and let it off the jack. Front crossmember us about 1/2" off the floor with massive 185/70r14 tyres, plus it's not been driven on yet. All the tuck. This is with the camber plates set to 0 as well! Makes the back end look very high now-
79cord
Wow drastic drop. And as usual those alloys look sooo much better without the original ctr caps!
Paul Y
I chucked the stock wheels back on and let it off the jack. Front crossmember us about 1/2" off the floor with massive 185/70r14 tyres, plus it's not been driven on yet. 1/2"? Can come down another 1/4" at least then... This is all sorts of awesome Dez. Makes me think I need some Velour in my life.... P.
adam73bgt
Club RR Member Number: 58
Looking good already, especially with that gold wheel on I've been semi tempted by some of those max speeding rods coilovers for the RX7 as the ones on the back of my car just aren't right but I'm loathe to fork out a shedload of money for 'proper' stuff!
Dez
I chucked the stock wheels back on and let it off the jack. Front crossmember us about 1/2" off the floor with massive 185/70r14 tyres, plus it's not been driven on yet. 1/2"? Can come down another 1/4" at least then... This is all sorts of awesome Dez. Makes me think I need some Velour in my life.... P. The tyre size I'm going for on the new wheels will be 1.25" shorter
Last Edit: Jan 5, 2017 22:25:28 GMT by Dez
Dez
Looking good already, especially with that gold wheel on I've been semi tempted by some of those max speeding rods coilovers for the RX7 as the ones on the back of my car just aren't right but I'm loathe to fork out a shedload of money for 'proper' stuff! Tbh, they really couldn't be faulted at twice the price. I've ascertained with the next round of stuff I've done that they seem to be made of pretty good quality materials. Tbh the only thing that really lets them down is the cheap looking yellow powdercoat. If I'm being super critical, The C spanners are also a bit cheap but tbh no worse than most other free ones, and the shipping in plain packaging looses you the 'branding' that most people would get excited about. Not that that matters once fitted anyway. If had a lot of coilovers over the years, of varying quality and pricing, and if these were powdercoated black, had some fancy foil stickers on them and some extra ones in the box, and the box was branded up, they'd easily sell for a lot more, as the product itself is great.
Paul Y
1/2"? Can come down another 1/4" at least then... This is all sorts of awesome Dez. Makes me think I need some Velour in my life.... P. The tyre size I'm going for on the new wheels will be 1.25" shorter Why did I ever doubt you..... P.
