Sept 15, 2016 10:36:58 GMT
I've been a lurker for a while so thought I'd better post a few pics up of my build. I've taken a Tvr chassis, had it shortened, added a chopped and channelled moggy body, 4.0L Tvr motor with twin turbos, 200 shot of NoS, custom injection system, Motec ecu with sequential fuel and spark (no batch firing here!!) t5 box soon robe changed for a zf4 auto with paddle shifters and programmable controller. The car has been widened 4", door shuts re-worked, bumper, wings, bonnet, roof all been reworked, only boot kid hasn't. All internal panels hand made. Hopefully have it OTR before next year Rear side view shows the width Front side view shows reshaping of wings and doors Bitchin' stance Motor Roll cage Hope you like it 👍🏼
Sept 15, 2016 10:43:39 GMT
Wowzers 😱😱😱😱😱
Sept 15, 2016 10:54:06 GMT
Fark me. That'll be a quicker way for nurse Gladys to get about in, or escape Arthur..
sb
Sept 15, 2016 10:58:27 GMT
F*** me! That's about all I can say...
andy-v
i like cookies :D
Sept 15, 2016 11:26:57 GMT
looks a right mean machine
fer4l
Testing
Club RR Member Number: 73
Twin turbo moggyfer4l
@fer4l
Club Retro Rides Member 73
Sept 15, 2016 12:25:51 GMT
Awesome! Look forward to seeing this build progress
Cheers
Matt
thebaron
Over the river, heading out of town
Sept 15, 2016 12:36:37 GMT
This is awesome!!! Many expletives of delight
Sept 15, 2016 14:58:35 GMT
oh yeah ... full on bookmarked!
Sept 15, 2016 15:37:43 GMT
I seem to be sporting some movement in the trouser department !!! Hubba Hubba..........
shin2chin
Sept 15, 2016 16:00:35 GMT
That looks awesome
Sept 15, 2016 16:26:48 GMT
Here's some of the fab work of the underside and rear tub Floor pans You can see some damage where it fell off the jack ☹️ Transmission tunnel
Sept 15, 2016 18:20:36 GMT
Looks badass mate.
Sept 15, 2016 18:40:38 GMT
My favourite thing of beauty is the inlet manifold. It's an edelbrock manifold with supercharged mustang injectors, block fuel rails, all map, temp sensors and fixings hidden in the inlet plenum which sits on hidden screws through the nitrous plate, which again is hidden. An extreme velocity carb hat has been modified to accept the race spec S2000 throttle body to allow for full butterfly opening for minimum resistance at what. The look is also as important as the flow characteristics of the inlet as I wanted it to be symmetrical and had a particular look that I wanted. Also hate wasted spark coil packs so stripped the guts out of the dizzy, sorted out the 8 deg advancing mechanism for full boost application and had all the timing electronics hidden inside (no ugly trigger wheels here!!) so that it uses stock leads and firing pattern and a accel hipo coil, so the whole ignition looks stock too 👍🏼
Sept 15, 2016 18:43:22 GMT
Boost pipes are loose but I had the inter poker modified to a 2 in 1 out for a straight path into throttle body, this should give a flatter velocity profile and better bulk flow. I think you get the idea 👍🏼
Sept 15, 2016 18:43:57 GMT
pork
Sept 15, 2016 18:46:38 GMT
TITS !!!!!
Sept 15, 2016 19:08:08 GMT
Geordie
North East
Course I'm out of my mind...........it's dark and scary in there!!
Sept 15, 2016 19:08:20 GMT
F*** me! That's about all I can say... What he said ^^ !!
CURRENT FLEET '91 Nissan Primera (41k miles, an early one and immaculate) '99 Ford Mondeo Ghia X (60k miles) '01 Mini (#869) '06 Audi A6 (18 year old 'modern' daily)
Sept 15, 2016 19:10:10 GMT
Is tits an acronym?
Sept 15, 2016 19:11:00 GMT
F*** me! That's about all I can say... What he said ^^ !! Cheers. Loads done (about 3000 hrs) loads to do 👍🏼
