sonus
Sept 21, 2016 8:31:41 GMT
Nice project! Do you still have the TVR T5 gearbox? If so does it have a mechanical speedo drive and adapter? If it does I'd be VERY interested in it
Last Edit: Sept 21, 2016 8:32:24 GMT by sonus
Sept 21, 2016 8:34:18 GMT
I do for the moment but I'm unsure if it does as tvrs speed sensor pickup is on the prop.
Sept 21, 2016 8:34:51 GMT
Nice to see you on here Foz! Awesome work. Thanks Phil, mg's looking tough 👍🏼
Sept 21, 2016 8:39:46 GMT
This is madder than a stabbed badger!!! I couldn't have put it any better!
sonus
Sept 21, 2016 8:54:10 GMT
I do for the moment but I'm unsure if it does as tvrs speed sensor pickup is on the prop. Very early ones had mechanical speedo drives before they switched to electronic units. The one pictured in my post is from a very early one and would be fitted to the right hand side of the tailhousing. If your car had electronic speedo it will have a blanking plug there instead.
Sept 21, 2016 9:07:22 GMT
I do for the moment but I'm unsure if it does as tvrs speed sensor pickup is on the prop. Very early ones had mechanical speedo drives before they switched to electronic units. The one pictured in my post is from a very early one and would be fitted to the right hand side of the tailhousing. If your car had electronic speedo it will have a blanking plug there instead. I'll have a look next time I'm up my workshop. I think it's a blank though
ton246
Sept 21, 2016 9:08:27 GMT
Yeah, not bad I suppose...............
FFS Wowzer !!!
Current Cars 2005 Jaguar S type R 4.2 V8 Mk1 Transit Campervan
Previous cars 1984 BMW e28 525e 2011 Audi A4 Avant S-line Black Edition 1997 Jeep Cherokee xj off roader 1986 BMW e28 520i 1992 RRC 3.9l V8 1996 Subaru Sti 2001 Saab Aero (HOT) cabrio 2008 Audi S3 2001 Jeep Grand Cherokee LTD 1989 Volvo 740 GL Estate 2001 Subaru legacy 2.5 GX Lux Estate 2002 Citroen Saxo 1.1 desire
Sept 25, 2016 12:31:22 GMT
As cylinders 3 to 8 are inside the car, I had to move the dash back to accomodate the motor. So I took the stock moggy dash and cut it into 3 and removed the speedo, then joined it together to keep the moggy essence I then rolled up and ripped a panel up to take up the gap between the bulkhead and the dash, bloody compound curves!!!! And rolled in the beads I removed the glove boxes and filled them with panels to mount the Tvr gauges. The rational behind it irks that I can use the Tvr instrument loom and warning lights so that all the dials and lights were a straight swap And fitted looks like this The whole thing has to be removable to get to the rear of the engine too
Sept 25, 2016 18:46:53 GMT
Nice work on the dash Foz!
Sept 26, 2016 13:24:41 GMT
I found a pic of my old twin turbod moggy, certainly looks busy in the bay. Note how short exhausts are, hence the reason I'm not worried about noise and temp 👍🏼
Oct 14, 2016 16:39:58 GMT
Oct 14, 2016 19:21:33 GMT
Good going Jeff! Nice update.
