Jul 15, 2016 12:05:44 GMT
Hello, i have a quick question 8) will all sierra sapphire interiors fit in all model years? ive found a 88 with nice brown interior which i love, but i have a 89/90 spec and I'm worried i cant swap dashboard and such over? have a picture so you have an idea of what i mean 8) Mmmmm... :oops: This is my current interior: a bit boring...
vanpeebles
I am eastbound in pursuit of a white Lamborghini, this is not a recording.
Jul 15, 2016 12:27:38 GMT
How about two tone, panda trueno style? Top half brown, bottom grey or vice versa!
Jul 15, 2016 12:37:59 GMT
mixing it up does look great !
vanpeebles
Jul 15, 2016 12:55:42 GMT
There you go You can swap bits over from the door cars too Mix and match!
bortaf
Jul 15, 2016 16:19:44 GMT
Short answer yes but adjustable steering modles have differant supports behind the dash. My p100 is a mix of base/L and GL/ghia, when i got it it had the small glovebox and speakers in the dash) there are issues where the top and bottom meet but it's mm of differance (i had to trim a lip off the lower dash to match the top), the ghia has a deeper center consol for the 2 piece sterio, then you have the 90 spec which is the later hooded dash, again fittable but fittings/mounts needs altering AFAIK. If you swapping the whole lot it's easyer than mixing and matching but it's not impossable, i managed it with my ham fisted oafish approach LOL
R.I.P photobucket
Jul 17, 2016 10:46:49 GMT
Short answer yes but adjustable steering modles have differant supports behind the dash. My p100 is a mix of base/L and GL/ghia, when i got it it had the small glovebox and speakers in the dash) there are issues where the top and bottom meet but it's mm of differance (i had to trim a lip off the lower dash to match the top), the ghia has a deeper center consol for the 2 piece sterio, then you have the 90 spec which is the later hooded dash, again fittable but fittings/mounts needs altering AFAIK. If you swapping the whole lot it's easyer than mixing and matching but it's not impossable, i managed it with my ham fisted oafish approach LOL Thanks for the reply well plan was to swap as much as possible, hopefully it wont be too hard. and mounting points and such better be there lols... I'm going to end up with 2 cars for a period until i can scrap whatever remains of the ghia so with a bit of luck i have all i need to swap it in the doner. i wonder if i have to swap the loom to in order to get all the delecius gadgets working, i was hopin to get quite a bit of extra buttons and such to play with ^^ but surely there must be sensors and conectors missing in my base spec... GRRR !
Last Edit: Jul 17, 2016 10:47:25 GMT by HmmDK
bortaf
Jul 17, 2016 15:44:04 GMT
My P100 had a bare loom no extras to plug in, (even the sterio loom was added after it was built! ) you may need to change the whole loom to get the extras to wire in, it depends on what loom was fitted to start with a base or L usually wont have the exras already wired in but a GL/Ghia may have, you will have to check when the 2 dahses are off TBH. As for buttons, my P100 has every button ford made, only 50% actually work but they are there LOL
R.I.P photobucket
