May 12, 2016 11:29:29 GMT
Our last delivery "tour" this side of September. Monday 23rd May - Thursday 26th May Travelling from Holyhead through Chester, Stoke, Birmingham across to Northampton (with the possibility of going down to Bristol, Reading or Slough that evening if orders come in) Over the next couple of days there will be sorties to Rayleigh/Chelmsford area via Cambridge area, probably also a skip across the north section of the M25 encompassing MK and St. Albans, and also northwards to the general Leeds area. Base point is just off the M1 near Northampton again as its a very central point. We've dismantled the thick end of a thousand BMWs over recent years including many M cars and unusual variants/spec, and have stacks of stock for anything '73-'03. Usual terms apply, will meet you at a services along the pre-planned route, usually on time but allow an hours scope for traffic delays, items must have a 25% deposit put down, and service is for big, fragile, rare items that are best not couriered.
adam73bgt
Club RR Member Number: 58
May 12, 2016 17:14:21 GMT
Do you have any E34 Sport front and rear bumpers at all?
May 12, 2016 17:30:50 GMT
Interested to know what interior E34 bits you have? And if you have any air con components that would suit a '95 525i
1995 BMW E34 525i Sport - Avus Blue on the outside, brown and crusty on the inside! 1998 BMW E36 328i Sport - Daily Commuter
benjy_b
Yorkshire and The Humber
May 12, 2016 19:34:32 GMT
Would you have a cruise control set for a 4 cylinder E36?
Stalk Column cover Wiring Solenoid Bowden cable Ecu
Last Edit: May 12, 2016 19:34:56 GMT by benjy_b
2005 Subaru Forester 2.5XT 1999 BMW E36 318i Touring with OM605 Mercedes Engine 1996 Lada Riva with Honda S2000 Engine
May 13, 2016 10:03:18 GMT
Do you have any E34 Sport front and rear bumpers at all? Yes bud, one set left, in white, although very definitely need a repaint, usual story of the front grille vanes cracked, £250. Interested to know what interior E34 bits you have? And if you have any air con components that would suit a '95 525i Pretty much everything for an E34. Got air-con pipes and compressor for that exact model, can gather up the rest if you're thinking about retro-fitting? No E36 CC
May 13, 2016 10:03:52 GMT
May 13, 2016 11:08:12 GMT
surprisingskoda I currently have AC fitted but I'm dubious that it actually works 100% ("needs a regas" is what I was told when I picked it up). I'll get the system checked and potentially gassed tonight/this weekend and get back to you
adam73bgt
May 13, 2016 17:28:45 GMT
Do you have any E34 Sport front and rear bumpers at all? Yes bud, one set left, in white, although very definitely need a repaint, usual story of the front grille vanes cracked, £250. Ooh cool, I'll send you a PM cheers
May 14, 2016 18:06:37 GMT
surprisingskoda what's the latest I can let you know for AC components? Mine is leaking, I just need to trace the leak before I can decide what needs fixing!
May 14, 2016 21:51:05 GMT
surprisingskoda what's the latest I can let you know for AC components? Mine is leaking, I just need to trace the leak before I can decide what needs fixing! If you can tell me BEFORE Friday I think it'll be OK.
May 14, 2016 22:07:32 GMT
surprisingskoda what's the latest I can let you know for AC components? Mine is leaking, I just need to trace the leak before I can decide what needs fixing! If you can tell me BEFORE Friday I think it'll be OK. Okay I'll get the car to another garage and do my best to get back to you before then thank you!
May 19, 2016 20:50:11 GMT
Last call. Current stock
1974 E8 Neue Klasse manual
1977 E21 316 manual 1983 E21 316 manual
1983 E24 635csi manual 1989 E24 635csi auto
1985 E28 M535i manual 1986 E28 528i manual 1987 E28 528i auto
1989 E30 325i Sport manual x3 1990 E30 325i SE manual 1990 E30 316i manual 1990 E30 318is manual 1990 E30 320i manual x2 1990 E30 320i Cabrio manual 1990 E30 316i Touring manual 1991 E30 318i Touring manual x2
1989 E32 735i manual 1990 E32 750iL auto
1991 E34 520i manual 1991 E34 525i Sport manual x2 1991 E34 518i manual 1994 E34 540i auto 1995 E34 520i Touring manual 1995 E34 530i manual
1994 E36 318i manual 1994 E36 325i Cabrio manual 1994 E36 M3 manual 1994 E36 M3 Cabrio manual 1995 E36 M3 manual 1995 E36 318is manual 1995 E36 328i manual 1996 E36 320i auto 1997 E36 318ti manual 1997 E36 323i Touring auto 1997 E36 318ti manual 1999 E36 318ti manual 1999 E36 M3 Evo Cabrio manual
1995 E38 750iL auto 1997 E38 728i auto x2
1996 E39 520i Touring manual 1997 E39 535i manual 1997 E39 525tds Touring manual 1999 E39 530d auto 2000 E39 528i Sport manual 2000 E39 530d auto 2000 E39 530d manual 2000 E39 535i Sport manual 2000 E39 530d Touring manual 2002 E39 525i Sport auto x2 2003 E39 525i manual x2
2000 E46 320d manual 2001 E46 330d Sport auto 2001 E46 316i manual 2001 E46 320d manual 2002 E46 318ci manual x2 2002 E46 318i Touring x2 2002 E46 318i x2 2002 E46 320d manual 2002 E46 330ci MSport Cabrio auto 2002 E46 330d MSport auto 2002 E46 330ci MSport auto 2002 E46 330ci manual 2002 E46 330i MSport auto 2003 E46 325i auto 2003 E46 320d ES manual 2004 E46 330i manual
2002 E53 X5 3.0d auto x2
2003 R50 Mini Cooper S manual
I'm going to have to wait for now for the AC parts, not had time to diagnose which parts are at fault
