Having collected my mates CX, I had to have one. ebay was scoured, and a LHD 2.4i Prestige (lwb) was found in Brighton. A flight down to collect, and it was picked up with steam pouring out and a non charging alternator. the steam was solved by tightening the coolant tank cap, as it was loose. The alternator proved more troublesome and led to a breakdown on the m25. It arrived home on the back of a truck whilst we flew up. the doors and wings are rotton but I have a full set of spares in the car Anyway here are some pics!
Lovely old ships! Would like to see it restored to its former prestigious appearance!
1986 Mercedes 200 (W124) (Standard and daily) 1976 Peugeot 404 1800 Stickshift (Standard - awaiting complete resto, engine done) 1984 Ford Cortina (P100) LDV - Cab and chassis restored, interior and glass not fitted, brand new 3 liter engine (last 110kw Sierra XR6 engine fitted and married to 5 speed Toyota Gearbox), load body needed.
Lovely old ships! Would like to see it restored to its former prestigious appearance! Cheers chap-will be seeing what I can do!
Love these old things...bookmarked
simes
Fantastic. Prestige too, based on the longer safari! The rear legroom in my dads 22trs is very generous but the prestige is huge!
Simes
205Mi16 - 262 cams, Jenvey Throttle Bodies, Emerald managment blah blah...... E91 320D MSport Honda NC30 Vespa 300GTS
teaboy
Make tea, not war.
Pure style!
Fantastic. Prestige too, based on the longer safari! The rear legroom in my dads 22trs is very generous but the prestige is huge! Thanks- yep it took 4 doors and 2 wings no bother! mental..
eternaloptimist
Nice work.
Back in the 80s I had to run an errand in my bosses cx... To cut a long story short I got nicked for speeding on the m20 in Kent ....those cars just waft along , I've never had the balls to buy one, just fantastic nice buy fella
thanks- impulse buy! we'll see how I fare.. Back in the 80s I had to run an errand in my bosses cx... To cut a long story short I got nicked for speeding on the m20 in Kent ....those cars just waft along , I've never had the balls to buy one, just fantastic nice buy fella I tried to stick to 60mph on the dual carriageways but as you say wafty wafty..
eternaloptimist
Worth making a note of where not to lift them using a trolley jack..,,
Worth making a note of where not to lift them using a trolley jack..,, Any and all advice much appreciated!
düdo
wide as house
Great car. Brave man. The early ones are definately the most stylish. Not far from here are CXBasis who know their way around these cars. If you look at their for sale section you can see what a sorted one sells for. That's what always scared me off buying a cheap one.. escalating costs! Looks like the wig of 2CV Ian fiddling in the back of that XM?
Last Edit: Oct 6, 2015 18:58:15 GMT by düdo
Oct 12, 2015 19:50:03 GMT
Got a bit more looked at on this at the weekend - key thing is solving the charging issue. Battery light comes on when you key on and goes off once started Spare Alternator Plenty of stuff in the way Inlet off, still can't really see it Got 1 pulley off, and could get to the 21mm back bolt. Unfortunatly I didnt have a 21mm spanner, and a socket and ratchet would not fit.. at this point I put it back together and will take it to a local alternator place tomorrow -they are apparently able to supply and fit for a reasonable price.
eternaloptimist
Oct 12, 2015 21:52:00 GMT
Is it on TRX's?
Oh, and don't jack it up on the longerons. I knew a guy who had one new in 1982. It was written off at three years old when a tyre place jacked it up in the wrong place. It went back on the road - I saw it a couple of years later - but twisted.
simes
Oct 12, 2015 21:59:27 GMT
Have you tried changing the oil filter yet?
Simes
Oct 12, 2015 23:08:25 GMT
Is it on TRX's? Oh, and don't jack it up on the longerons. I knew a guy who had one new in 1982. It was written off at three years old when a tyre place jacked it up in the wrong place. It went back on the road - I saw it a couple of years later - but twisted. yep its on trxs- gti rims I believe. on the look out for 14" rims as would have been stock. Re jacking points, I'll only let them put it on a ramp it can drive onto!
neil79
Oct 13, 2015 10:02:46 GMT
Really enjoyed reading pt1 & 2 of your blog. I love these old french barges!
