Jul 15, 2016 16:50:20 GMT
Not alot happening with this really. I got it MOT'd yesterday. No dramas. It still pulls a crwod up at the mini industrial estate where i take it for MOT's. Ive booked a drifting track day at Rockingham next month, so hopefully ill have a whole day of fun without breaking the new gearbox!
gazz81
Jul 15, 2016 17:26:15 GMT
Car looks great, what arches have you fitted?
Jul 15, 2016 17:31:40 GMT
They were on the car when i bought it. I think they are made by Rovertech back in the 80's
A few months ago, i was a bit down about how little i use this car. So while sitting in my flat, drinking Strongbow (other ciders are available, and probably better) i decided to book a driftday. Lydden Hill and Snetterton don't run drift days any more, and Santa Pod is good, but i wanted a proper track. The only realistic option was Rockingham. I took last Friday off work and got ready preparing the car.... ...all i did was wash and refuel it. I actually spent more time adjusting the brakes on my trailer than on the Rover. Washing the Rover presents an interesting challenge. I quite like the dirt, coolant spills, and rubber marks so i decided to wash just the windows. This is where it gets problematic. None of the windows seal! So i washed it with a hose and the doors open, so the water would drain straight onto the floor and not inside the cabin. On Saturday I loaded up and headed up to a Premier Inn at Corby ready for drifting on Sunday. Sunday morning came and i was pretty excited. It had been a year since my last outing and when i broke the gearbox. The Rockingham track is excellent with a fast flowing infield and some even faster stuff on the oval banking. My first run was utter wibblepoo, as i had no idea where i was going. I got a bit better and really enjoyed the infield. The big track and that imposing wall on the outside were pretty harrowing, so i stuck mainly on the infield. Sadly the day didnt last long. First i realised my feet were slipping on the cabin floor. A quick check revealed that the clutch master cylinder had gone again. Yes this is a new one!!!! Its new old stock so I'm guessing the seals were really old and just not up to it. Anyway it meant i lost started to lose the clutch and couldn't get second on downshifts. I topped up the clutch fluid and taped some blue rag around the pedal area to soak up any more escaping fluid, but it still kept leaking. Then a second problem developed at the steering column. The plastic bush at the bulkhead broke. I'm not sure if it was related to the escaping and corrosive clutch fluid, but there was now a lot of slack in the steering. Not good. So unfortunately i packed up early. Partly due to paranoia that i would munch a second gearbox in 2 drift days, and also random locking up of the steering. This marks the end of this foray into drifting in the Rover. Ive had great fun in the car, but there are quite a few parts on this that i borrowed out of another SD1 I'm rebuilding and ill need those parts back soon. don't worry though, I'm not scrapping the shell. I'm going to keep it with a view to fitting either a Toyota 1uz-fe V8 or an LS series V8 engine, budget depending. In the meantime ill keep it running as a fun road car for as long as the MOT is valid.
Can't say I blame your choice to shelve the rover drive line and go something a bit more modern.
On a totally unrelated note, I will be at the proper Drift Matsuri at Ebisu this weekend. I want to see what different things people are running, though S-chassis and R-chassis will always hold my heart.
Can't say I blame your choice to shelve the rover drive line and go something a bit more modern. On a totally unrelated note, I will be at the proper Drift Matsuri at Ebisu this weekend. I want to see what different things people are running, though S-chassis and R-chassis will always hold my heart. Lucky you. I'd love to go. I'm a fan of s14's. I have a kuro black navan s14 Silvia. I'm never selling it!
qwerty
Club RR Member Number: 52
For a while one of my fantasy builds has been an SD1 with a BMW straight 6. Base it on a 2300 and use an M52 with M50 manifold and it would be more powerful than a RV8 and the smooth straight 6 power would suit it really well.
Saying that a 1UFZE would be a fantastic choice, and fairly inexpensive for a donor.
Tom
Aug 10, 2016 21:34:47 GMT
There is a chap on the sd1 forum who fitted a supra 3mgte with manual box, but not sure he ever got it running. There is another one with a 1uz-fe, but it still has the auto box on it.
Heres a video from Sunday
Aug 11, 2016 10:18:38 GMT
For a while one of my fantasy builds has been an SD1 with a BMW straight 6. Base it on a 2300 and use an M52 with M50 manifold and it would be more powerful than a RV8 and the smooth straight 6 power would suit it really well. Saying that a 1UFZE would be a fantastic choice, and fairly inexpensive for a donor. Tom Thats what I keep toying with for mine. Do I rover v8 it. Or do i go bmw v8/6 pot or lexus v8. Or even if money allowed 2jz. Trouble is other than the bmw route is the manual boxes. although there are plenty of kits about now and what is more common is to go the bmw box onto the J lump.
If you ever take it to Lydden Hill, let me know I'll come and watch !! I've met some interesting people there in the past, including a young Jenson Button !!
adrian.
Feb 18, 2018 17:38:29 GMT
Wow, ages since i updated this thread. Yesterday i decided to waken the beast. It has been sitting outside under two car covers since August 2016!!!! Fitted a new battery, turned the isolater on, ignition on, and could hear fuel pump. Cranked it, turned over nicely but didn't fire. So pulled an ht lead and held a spark plug against the block. No spark. Pulled dizzy cap off and unsurprisingly there was corrosion to the terminals, so i cleaned that up and tried again... still no worky. So checked all the wires to the coil. By check, i mean pulled them off and put them back on again. Cranked it again and guess what... It fired up!!! Major result. Even settled to a nice healthy idle. Love this car. I took loads of Photos and a couple of videos, just because. Will put videos up later.
ET
Feb 18, 2018 18:34:44 GMT
Can't say I blame your choice to shelve the rover drive line and go something a bit more modern. On a totally unrelated note, I will be at the proper Drift Matsuri at Ebisu this weekend. I want to see what different things people are running, though S-chassis and R-chassis will always hold my heart. Lucky you. I'd love to go. I'm a fan of s14's. I have a kuro black navan s14 Silvia. I'm never selling it! Would love to see a picture of the s14! really like the look of the SD1, awesome car!
Last Edit: Feb 18, 2018 18:37:08 GMT by ET
Feb 18, 2018 19:26:27 GMT
Sept 16, 2018 12:42:15 GMT
Had to move the driftcar, so I started it up and took it for a quick run up and down the lane to clear the cobwebs. Got a surprise when a mouse ran out of the bonnet air vent and started eye balling me through the windscreen!
Marc
Can't wait to see more on this, what an awesome car!
I love the way that looks. Last year I went and picked up some 218 VVC wheels, the guy had a Tuscan challenge engined SD1, similar arches and I think they where 305 P Zero's from a Countach!!! Had a very similar stance. He also had a Lancia 037 Stradale!
I love the way that looks. Last year I went and picked up some 218 VVC wheels, the guy had a Tuscan challenge engined SD1, similar arches and I think they where 305 P Zero's from a Countach!!! Had a very similar stance. He also had a Lancia 037 Stradale! Sounds like quite a lad. What were the vcc wheels for? A car I would like to buy again today is a bubble 200 218is. I want another one.
I bought them as a 5th set for my rallyrover. But I have also a 218 VVC coupe.
I love the way that looks. Last year I went and picked up some 218 VVC wheels, the guy had a Tuscan challenge engined SD1, similar arches and I think they where 305 P Zero's from a Countach!!! Had a very similar stance. He also had a Lancia 037 Stradale! Sounds like quite a lad. What were the vcc wheels for? A car I would like to buy again today is a bubble 200 218is. I want another one. Quite a rare model. I’ve got one which you can have for free if you want it, it’s not in bad shape at all, but the only catch is it’s currently without an engine!
Specialist Bodyshop & Fabrication Classic, Retro, Prestige & Custom Small Repairs to Concours Restorations Mechanical Work Vintage to Modern
Sounds like quite a lad. What were the vcc wheels for? A car I would like to buy again today is a bubble 200 218is. I want another one. Quite a rare model. I’ve got one which you can have for free if you want it, it’s not in bad shape at all, but the only catch is it’s currently without an engine! WHat colour is it, and what interior does it have, i could be very tempted as i have a vitesse turbo engine in the garage!
