lukas
Feb 11, 2015 11:38:29 GMT
Hi!
I recently discovered that the winter-tyres (Falken Eurowinter) on the front wheels have less tyre pattern then the ones on the rear. No wonder, my Mazda6 is FWD.
Should I change the tyres and put the ones with less tyre pattern on the rear and the ones with more on the front?
Some say, it´s better to have the better ones in front because more grip and better for steering. Others say it is better to have the better tyres on the rear because the rear axle makes the stability when driving, no matter if FWD or RWD or AWD.
What do you think? Put the better tires on the front or leave them on the rear?
Tahnks a lot!
Lukas
87 Mitsubishi Pajero 2,5 TD Wagon 89 Mitsubishi Pajero V6 3000 Metal Top 96 Daewoo Espero 1.5 16V
adam73bgt
Club RR Member Number: 58
Change tires front/rear?adam73bgt
@adam73bgt
Club Retro Rides Member 58
Feb 11, 2015 14:09:25 GMT
On a FWD car, your front tyres are doing the steering, dealing with the engine drive and doing most of the braking so I would have the better tyres up front if it was me
MiataMark
Club RR Member Number: 29
Change tires front/rear?MiataMark
@garra
Club Retro Rides Member 29
Feb 11, 2015 14:23:54 GMT
Personally I'd always put the best tyres on the front (whether FWD, RWD or AWD) as adam73bgt says they're doing the steering and most of the braking.
taurus
Feb 11, 2015 19:05:26 GMT
I have always put the better tyres on the front - but I've heard tyre fitters saying this is wrong. Personally I've never had a problem with the best on the front approach.
The only times I've put the best on the back has been when I have a small car where the tyres last for years. Eventually the fronts wear out and you replace them - but if you leave the old ones on the back they'll just get too old before they run out of tread, so I swap front and rears.
v8ian
Feb 11, 2015 19:33:49 GMT
More On FWD cars, Under braking, inertia (polar?) moves forward unloading the rear wheels. go into a corner and touch the brakes the rear unloads and can cause the car to spin, its an inherent design fault with FWD, This is the reason why its been suggested that you fit the better tires in the rear, counter intuitive I know. The problem is much better with modern suspension design........
Feb 11, 2015 19:47:01 GMT
I always advise putting the best tyres to the rear, as an oversteer situation is more difficult to recover from than understeer, hence putting the tyres with the best grip/traction on the back. Some customers agree, some don't so I personally just do what they want in the end.
Al.
Stu
Feb 20, 2015 17:05:18 GMT
As above, I've always gone with the best tyres on the rear approach as understeer is easier to correct / recover from than oversteer generally.
Feb 20, 2015 17:11:42 GMT
If I'm swapping wheels around I always put the better tyres on the driving wheels so they wear out evenly and I end up looking for a full set rather than 2 at a time. I don't drive hard enough for it to make much difference to me anymore....
Last Edit: Feb 20, 2015 17:12:15 GMT by dodgerover
