Mike
Sept 8, 2014 20:35:14 GMT
I have just bought some scimitar wheels for One off the MGB's and I'm strugglign to find any wheel nuts? i know they need to have flat washers on the back and the thread needs to be 7/16" unf. if i get the wrong length shank will this cause me problems?
does anyone have any links to some on ebay they have used?
any help apreciated! pictures soon!!
oakesy
Sept 8, 2014 20:39:41 GMT
Assuming you bought dunlops, won't they use the same nuts as the MG versions?
'66 Scimitar Coupe Straight Six in no Paint '74 Scimitar GTE in Yellow '71 Jaguar XJ6 in Blue '76 Scimitar GTE '87 Scimitar Turbo Previous- '87 Scimitar SS1 Turbo, '75 Triumph Toledo, '86 VW Scirocco, '93 Scimitar Sabre, '85 Scimitar SS1, '76 Scimitar GTE, '71 Scimitar GTE
Mike
Sept 8, 2014 20:43:35 GMT
yeah sorry, they are dunlop composites. the standard wheels are steel and have a tapered face were as the composites have a flat ally face.
adam73bgt
Club RR Member Number: 58
Sept 8, 2014 20:47:37 GMT
sowen
Club RR Member Number: 24
Sept 8, 2014 20:52:56 GMT
Correct me if I'm wrong but don't Scimitar and MGB both have 1/2"unf wheels studs?
Seth
Sept 8, 2014 20:57:02 GMT
Correct me if I'm wrong but don't Scimitar and MGB both have 1/2"unf wheels studs? MGB is definitely 1/2" UNF. Scimitar might be 7/16"
sowen
Sept 8, 2014 21:06:49 GMT
Correct me if I'm wrong but don't Scimitar and MGB both have 1/2"unf wheels studs? MGB is definitely 1/2" UNF. Scimitar might be 7/16" The SE6 me and a mate stripped for the suspension/running gear had 1/2unf studs, I've got them lined up ready to refit in my axle (when I get a few more to make them 5 stud per wheel), and I bought MGB 1/2unf studs to fit the American wheels on my Rover P6 to replace the 7/16unf studs. Just wondered if I was lucky or they are all the same?
oakesy
Sept 9, 2014 17:08:18 GMT
Scims are 1/2" UNF so you can use some of them. You can buy hand made stainless steel ones from a member of the club if you want his details?
