qwerty
Club RR Member Number: 52
Small diesel Hatchbacksqwerty
@qwerty
Club Retro Rides Member 52
Looking to buy a cheap to run daily that me and the wife can share, means I will focus more funds on the cortina hopefully
Always bought VAG diesels in the past so need people's opinions on non VAG stuff.
Clio dci's, citroen/pug 1.4 and 1.6hdi's, corsa cdti's, fiesta tdci's. Which are good which are bad or should I just play it safe with a Fabia or Lupo sdi?
1.5D AX, light enough to still be fun
I'm bias - got a 54 reg 1.4TDi Fabia and rate it very highly. Nippy and amazing economy.
Paul H
mdw
Don't go anywhere a dci clio!
I'd vote for a pug 106, I drive one every day great little car!h
1989 VW Caddy 1993 BMW 316/2.5 Touring 1985 BMW 316 (e30) 1984 BMW 316 (e21) 1992 VW Passat 1984 Porsche 924 - SOLD 1985 Volvo 340 GL - disfigured Now cubed 1990 BMW 318i - Sold 1989 BMW 535i SE - executive express SOLD
1.6 HDi - run away. They kill turbos for a hobby. Engine is in some Fords as a TDCi IIRC as well. 1.4HDi - think they're ok, if they have been serviced religiously.
Regardless, all of those are modern(-ish) engines so subject to all the normal modern diesel stuff: don't bother if you're doing short trips, as they'll block the DPF and need regular regenerating. Watch out for DMFs and injectors.
I had a 97 Clio diesel for a while; old tech 1.9 NA mechanical pump engine; tough as old boots, and still resonable economy (didn't see less than 45mpg, might dip a little if you only drive in town). Bit more agricultural than the modern common-rail stuff, but still fun to chuck down the twisties.
Small diesel Hatchbacksstealthstylz
@stealthstylz
Club Retro Rides Member 174
306 D Turbo or HDi every time. Cheap to run, reliable and parts are ridiculously cheap if needed. Just make sure the auxillary belt has been changed regularly.
Agree with above the 306 is much better compromise over the 106. You can actually enjoy travelling around and still feels fairly modern in the 306, where as the 106 feels very very basic but will do 65mpg with ease.
qwerty
@qwerty
Thanks for the suggestions guys
Wife has discounted them all for being too old. Found and immaculate Citroen ZX diesel 55k for 495 her reply "its old"
Argh buying a car with the other half is a right pita.
Xsara 110 hdi, same floorpan, made till about 04, intercooled 2.0 where the 306 only got the non ic 90.
I've just sold my 03 Peugeot Expert 2.0HDi. The clutch failed and parts alone were nearly £600 (flywheel £450 & clutch kit £150 as it was suggested on various forums that the dual mass flywheel will need replacing at same time if still the original (150,000 miles). Didn't get quotes to have a garage change as the book time is 6-8 hours which wouldn't mean a hefty labour bill on top. In the end "cut my losses" and sold it for £350 as simply not worth spending that sort of money on something which with other cars is a simple sub £100 clutch kit. With that in mind I wouldn't touch another car fitted with a PSA HDi lump !
Paul h
xsara did not have a DM flywheel.
gotta love basing an experience of believing what forums suggest as being gospel as to what is wrong with a flywheel without inspecting it, and disregarding half the worlds passenger car diesel engines :lol:
djoptix
Citroen BX 16 valve
The 1.6 HDi is incredibly sensitive to people putting the wrong oil in it (so I'm told).
I had a 1.5 AX and it was brilliant. If that's too old I'd look for the newest Saxo you can find with the 1.5D lump.
OMG i totally would have that car if a) you lived closer b) i had the dosh c) i could sell this rusting mk1 Civic d) my benefits come through e) my wife would let me f) my mum would let me g) you'll MOT it
I know you said none vag but I'm using a polo 6n2 1.9sdi and as a cheap daily and can't fault it one bit, egr blank, inlet de-coked and a decat, I'm getting between 90-100 miles to a tenner. Unbelievable on juice. Not the fastest thing in the world but with mpgs like that who cares haha
Hi there mate theres a wee peugeot 205 1. for sale on gumtree with 31,000 miles on it ? Not mine but it might be genuine looks clean enough. I have a peugeot 1989 309 gld with 47,000 on it from new its got full history but my young cousin has his eye on it for his 1st car .
lilbob
May 10, 2014 15:01:00 GMT
corsa cdti
qwerty
@qwerty
May 12, 2014 12:44:29 GMT
What are the 1.3cdti engines like in the Corsa's? I quite fancy a 206 2.0HDI I can imagine they would be quite entertaining to drive.
THE_Liam
Yorkshire and The Humber
If at first you don't succeed... HAMMERS.
May 12, 2014 13:01:36 GMT
306 D Turbo or HDi every time. Cheap to run, reliable and parts are ridiculously cheap if needed. Just make sure the auxillary belt has been changed regularly. This. They aren't amazing on fuel because they're such old-tech, but if they've got a Bosch VE pump you can run them on 74p a litre veg oil. I've run them on it pure, all through winters, no issues at all. I've had 4 of them now.
taurus
May 12, 2014 17:44:35 GMT
What are the 1.3cdti engines like in the Corsa's? I quite fancy a 206 2.0HDI I can imagine they would be quite entertaining to drive. The FIAT 1.3 cdti engine in the Corsa (and Astra) is curse word. Not nice to drive and beset with many many problems. All the usual DPF issues, heads crack, leaks, chocolate timing chain. A mate started work at a Vx dealership last year, it takes a couple of pints before he stops ranting about what he's had to do to the endless stream of those things they get in.
qwerty
@qwerty
May 12, 2014 19:16:39 GMT
What are the 1.3cdti engines like in the Corsa's? I quite fancy a 206 2.0HDI I can imagine they would be quite entertaining to drive. The FIAT 1.3 cdti engine in the Corsa (and Astra) is curse word. Not nice to drive and beset with many many problems. All the usual DPF issues, heads crack, leaks, chocolate timing chain. A mate started work at a Vx dealership last year, it takes a couple of pints before he stops ranting about what he's had to do to the endless stream of those things they get in. Ah its the same thats in Fiats? My dad had a Panda Multijet Diesel and it was totally reliable. Quite peppy in a Panda as well.
taurus
May 12, 2014 22:04:05 GMT
The FIAT 1.3 cdti engine in the Corsa (and Astra) is curse word. Not nice to drive and beset with many many problems. All the usual DPF issues, heads crack, leaks, chocolate timing chain. A mate started work at a Vx dealership last year, it takes a couple of pints before he stops ranting about what he's had to do to the endless stream of those things they get in. Ah its the same thats in Fiats? My dad had a Panda Multijet Diesel and it was totally reliable. Quite peppy in a Panda as well. Depends on the year. FIAT had so many problems with the 1.3 diesel that they withdrew it for a while. They tend to be fine up to about 65k if used on motorways regularly and given regular services. After that the failure rate really kicks in. The GPO (or whatever they're called these days) used to run their diesel vans way over 100k, but they got rid of most of their 1.3cdti Combos once problems started to show up. My brother had one and loved it - for about 6 months. Then he was sad. On the Corsa, which is heavier, they have a big flat spot just at the point where you need to pull out from junctions briskly. The Corsa D is even heavier, and they've retuned the engine to meet emissions which has made it even worse. FIAT of course have dropped it and gone over to their Multiair engine.
