Mar 22, 2013 14:59:50 GMT
well as it says just bought a p reg a4 tdi red I, god it goes not sure if its been chipped or not got a few things wrong with it airbag light stays on but I think theres a bit missing from behind the wheel as a black plastic washer fell into a 6 bits when I took the wheel off but I can look for a new bit got a speed sensor on its way so should sort the abs light out but all in all great car for £500 needs lows and maybe some paint as it got a lot of makes but great daily almost retro lol just put a set of heater plugs in starts so well now filled it up with diesel as last owner was using bio starts like a new car you would never now it had done 150k
Last Edit: Sept 25, 2013 11:58:22 GMT by stretch
Mar 22, 2013 15:05:14 GMT
first bit of paint lol
Mar 22, 2013 15:16:15 GMT
Another A4 to keep my eye on, bookmarked.
xrmike
Mar 22, 2013 15:46:30 GMT
Google every mod. It'll make it even quicker!
Any body now where the chip would be ?
luckygti
I need to try harder!
Nice buy mate, I've got a tdi Mkiv Golf, and I love it 50'ish to the gallon, 150 brake and £135 road tax! Can't go wrong
xrmike
Any body now where the chip would be ? Look by the fuel injection pump there might be a black box there on the wiring to it. If there isnt you can make it even quicker by doing the every mod that costs about 26P
Mar 23, 2013 10:24:06 GMT
ok thanks will have a look just fixed the airbag light it was a plug not in properly love the way it just pulls so well i was going to buy a a4 2 years ago but changed my mind what a fool this seems to be a great motor even in the state it is
Mar 23, 2013 12:36:57 GMT
Look by the fuel injection pump there might be a black box there on the wiring to it. If there isnt you can make it even quicker by doing the every mod that costs about 26P[/quote]
i had a look cant see any thing extra on there just the single wire to the back and there is what looks like a big black lug on the side but there don't seem to much else
qwerty
Club RR Member Number: 52
1996 Audi A4 TDi getting lower qwerty
@qwerty
Club Retro Rides Member 52
Mar 23, 2013 13:09:17 GMT
Your airbag light will more than likely comeback on. Its normally the plug under the front seat. They're notorious for having poor connection Quick pic of my A4 Daily:
Mar 23, 2013 13:17:25 GMT
i hope not lol is this what you ment
marcp
Mar 23, 2013 16:44:16 GMT
Its just to the right of the pump, and down below slightly, its a big block connector with 10-12 wires going into it, pretty big.
Ill find the link in a min, but I did the every mod on my Golf GT TDI, and it makes SOOOO much difference, ive done mine on a switch and a potentiometer, so its adjustable and also can be switched off. Got all the bits from maplins for less than a fiver and it took about a hour to do, worse part was running the switch into the car. But like others have said, it can be done even simpler and for pence.
If you love how it goes now, youll love it even more after!!
marcp
Mar 23, 2013 16:45:13 GMT
Mar 23, 2013 17:26:55 GMT
ok thanxwill have a nother tomorrow
xrmike
Mar 23, 2013 18:10:40 GMT
Yeah if you choose to use just 1 resistor use a 600OHMS one.
marcp
Mar 23, 2013 19:26:00 GMT
Ive never gone down that low.... lowest I got was around 700!!! Even then, 1st 2nd and 3rd would produce scary amounts of wheelspin in damp conditions!
Bet thats a bit lairy!
xrmike
Mar 23, 2013 20:14:05 GMT
I've had my girlfriends down to 500 OHMS! It all depends on the injection pump setup, timing is so critical through VAG COM. The simplest way is to buy a resistor and have it on a switch. On for fast, off for normal.
Mar 23, 2013 21:15:55 GMT
ok well gotta sort the wheel sensors out then i think that will be the next thing to look at
Mar 27, 2013 14:04:05 GMT
abit of a silly one but should this car have a remote to unlock the car i got 2 keys but there not remotes would be nice if it was and could i just buy a second hand one and retune it to the car some way?
Mar 27, 2013 18:51:06 GMT
I questioned this with mine dude, you have to curse word about with changing pumps and having it enabled in the VAGCOM etc. so it's easier to buy a cheap retrofit kit from somewhere like www.rclick.co.uk which is what I'm doing.
