Nov 18, 2012 11:05:19 GMT
Having a garage clear out and need a bit of help here. It was in a box with other mk2 mini parts, theres no icons on it so i'm not sure if its for the wipers or indicators or even if its a mini item as I didn't remove it. Anyone know? Thanks in advance!
Brian Damaged
West Midlands
Club RR Member Number: 33
Nov 18, 2012 11:22:12 GMT
Well it's not off a Mk2 Mini, as it'd have the iconic, much-loved green flashing light on the end of the stalk if it was.
Could be from a Mk3-onwards Mini, should just have the indicators/horn/headlamp flash/main beam if it is. Wipers on a Mini were always controlled off a switch on the dashboard.
Nov 18, 2012 11:29:40 GMT
looks similar to a mk1 escort one, but the arm looks stubbier and not as long. also the plug at the end doesnt seem right for an escort one.
Ryannn
Nov 18, 2012 11:31:08 GMT
As far as I know it's only mk1s which have the green light.
But yeah, that's a mini stalk, I'd say mk2-3
Edit: it should have spades in the plug!
Last Edit: Nov 18, 2012 11:32:51 GMT by Ryannn
adam73bgt
Club RR Member Number: 58
Nov 18, 2012 11:31:10 GMT
the bit on the end makes it look similar to the one i have in my MGB GT...
yellowmini
Club RR Member Number: 116
Nov 18, 2012 11:49:37 GMT
Ryannnnn's correct, only mark 1's have flashing bulbs in the end. I don't know about the plug on the wiring but that's mark 2 or mark 3 to about '74 (I think!).
Ryannn
Nov 18, 2012 11:52:41 GMT
Nov 18, 2012 12:59:39 GMT
Mk3 Mini is correct
Nov 18, 2012 18:43:30 GMT
Thanks for all the replies, much appreciated!
Wipers on a Mini were always controlled off a switch on the dashboard. Just to clarify... Later ones were controlled via a second steering column stalk.
Nov 19, 2012 14:50:30 GMT
will also fit late imps...
rob963
Club RR Member Number: 97
I seem to remember hearing/reading somewhere that austin and morris used different connectors (spade/bullet) respectively can't remember who used which, but I am pretty sure that it's from a mkII hope that helps (even if it's slightly)
Nov 24, 2012 10:27:42 GMT
Also exactly same as what's on my 91 robin and same plug. A lot of b l and Austin bits used though
Nov 24, 2012 20:27:52 GMT
If you're interested in selling it, PM me.
