Davey
Resident Tyre Nerd.
Really struggling too find some springs for the rear of my escort estate i need more drop than companies will provide so i'm looking at fiesta rear springs but i could really do with a website that states dimensions incase there is something more suitable lurking. Lowering on a budget is hard.
www.struve.se/OSC/fjadrarbiltema.htmObviously in swedish, and not the best of lists, but it's a start. Varv - number of coils Längd mm - lenght in mm Dia mm - diameter in mm, not sure if outer or inner Gods dia mm - spring thickness in mm Fjäderkonstant, N/mm - spring constant, in newton/mm bak - rear fram - front Here's another one, but as biltema has remade their website it isn't of much use, as the "B" was supposed to link to a "buy it now" page.. But for your application i'd cut normal lowering springs. Obviously springs from something else will most probably also need cutting.
Last Edit: Aug 4, 2012 16:15:34 GMT by dude
