Jul 27, 2012 19:27:07 GMT
I'm looking at various engine options for the Cortina, had settled on a mazda dohc from the MX5 but then I've ended up with a 3S-FE engine(complete with Celica attached) so ended up wondering what RWD gearbox options there are for these - assuming petrol hiace is one possible, IS200 manual if you can find one might fit? but what other options are there - and also clutch/flywheel combos are better?
Many thanks to all for any assistance.
2014 - Audi A6 Avant 3.0Tdi Quattro 1958 - Chevrolet Apache Panel Truck 1959 - Plymouth Custom Suburban 1952 - Chevrolet 2dr Hardtop 1985 - Ford Econoline E350 Quadravan 2009 - Ovlov V70 2.5T 1970 - Cortina Mk2 Estate 2007 - Fiat Ducato LWB 120Multijet 2014 - Honda Civic 2.2 CTDi ES
Jul 28, 2012 20:45:10 GMT
You should look at my nissan ca18et turbo full set up box prop pumps cooler the lot full conversion. Look at my previous posts in for sale section. Cheap power
3S-FE Rear Drive Optionsstealthstylz
@stealthstylz
Club Retro Rides Member 174
Jul 28, 2012 21:12:30 GMT
Lol that is the best blagging I've ever seen on an unrelated forum post.
Jul 28, 2012 22:11:15 GMT
MR2 gearbox and put the engine and gearbox in the back
Jul 28, 2012 22:12:30 GMT
Ha ha. Trying to help sell my motor by helping him find a motor. Its all swings and roundabouts!
The Doctor
Club RR Member Number: 48
3S-FE Rear Drive OptionsThe Doctor
@thedoctor
Club Retro Rides Member 48
Jul 28, 2012 22:45:08 GMT
a gearbox from an IS200 won't work, you'd need one from a japanese Altezza RS200, which comes with a fruitier version of the 3S-FE (200 bhp 3S-GE instead of 140ish) and is a 6 speed. There are 2 other options: - gearbox from a Carina/Corolla RWD Diesel (Carina CA70 or Corolla CE70) which aren't available easy - gearbox from a 1S-U'd Carina/Corona from Japan, which also is rare. So for the price of the relatively rare gearbox, i'd say go for an easier engine, or buy an Altezza gearbox with the BEAMS 3S-GE attached to it and ditch the engine you have now
Jul 29, 2012 16:10:46 GMT
As said above go for the Altezza RS box. But ditch the 3SFE, it's built for economy not speed an in my experience isn't very good at either of those things. Not worth it when 3SGE/GTE's are so cheap.
'95 Toyota MR2 Turbo '72 Toyota Celica TA22 '74 Mercedes 350 SL '68 Mercedes W108 280SE '03 Renault Clio 172
Jul 29, 2012 16:15:36 GMT
Hi iv just stumbled across this thread and I think I can help, I have got a bell housing that will fit the 3sgte and 3sge engine straight on to a Lexus ls200 rwd manual 6 speed box if you interested gimme a shout if you want to know more
Jul 30, 2012 20:37:32 GMT
Hi iv just stumbled across this thread and I think I can help, I have got a bell housing that will fit the 3sgte and 3sge engine straight on to a Lexus ls200 rwd manual 6 speed box if you interested gimme a shout if you want to know more Have you got anymore details ? Is it just the front section of a JDM spec altezza box ? Or is it a separate bellhousing conversion like a leet set up ? Cheers Dom
Hello sorry it took so long to answer your question it's the front section of the box
