ERL MF2 Mappable injector driver setup
Bought this sometime ago for another failed Sierra turbo project, the car is gone and I no longer need this. It's basically a mappable injector controller, that allows for additional fuelling for engines with forced induction or nitrous oxide conversions.
What you get:
ERL MF2 injector driver
ERL Multiple injector driver (allows setup to run, an extra 4 injectors, god only knows why you'd want to do this)
A 90% complete loom for the MF2 red plug (just needs injector and map sensor plugs soldering on)
A yellow plug for the Multiple injector drive
Various connects for map sensor and injectors
4xStandard Sierra Cosworth injectors 255cc/min flow rate
2D adjustable pressure switch (although it's best to ditch this for a 2 or 3 bar map sensor for the 3D mapping feature)
According to the eBay advert it was all fitted to a Mitsubishi GTO and was working, however I've not tested it myself.
SOLD
Any questions please ask. Thanks Robin
What you get:
SOLD
