Apr 13, 2012 13:18:41 GMT
Apr 13, 2012 13:20:33 GMT
BMW e21 Shot of the engine would help with model Id, it's probably a 316/318 though.
Last Edit: Apr 13, 2012 13:27:39 GMT by joem83
Apr 13, 2012 13:31:14 GMT
BMW e21 Shot of the engine would help with model Id, it's probably a 316/318 though. Is there anything specific or will a general shot do?
Apr 13, 2012 13:39:48 GMT
I'm not sure to be honest, general pic will confirm if its a 4cly or 6cyl if you can get the last 7 digits of the vin number a guy on here can give you the full spec list.
Apr 13, 2012 13:48:54 GMT
if you can get the last 7 digits of the vin number a guy on here can give you the full spec list. Wheres this located?
Apr 13, 2012 14:14:04 GMT
Not sure, maybe on the bulkhead, one of the wheel turrets or on b pillar/door jamn
Apr 13, 2012 14:21:15 GMT
Thanks for your help dude ;D
Apr 13, 2012 14:46:39 GMT
Do these cars have metric or imperial stuff?
tigran
In rust we trust. Amen.
Club RR Member Number: 142
What BMW is this?tigran
@tigran
Club Retro Rides Member 142
Apr 13, 2012 14:50:04 GMT
It'll be all metric on this.
Apr 13, 2012 15:08:40 GMT
There was also a 315 these days. IIRC the six cylinders (320&323) all had the exhaust pipe almost in the middle, not to the left. thought that was just e28's? had a few of these 4 and 6 cyls and apart from the 323i the pipe exited from the left?
Apr 13, 2012 15:14:03 GMT
I spy rear drums, does that signify anything?
Apr 13, 2012 15:19:40 GMT
I spy rear drums, does that signify anything? Means its not a 323 from my research, pretty sure this is a 320 as I remember it having a carb
Last Edit: Apr 13, 2012 15:24:53 GMT by mgbizzle
Apr 13, 2012 17:33:59 GMT
Well if it's got 4 cylinders it's an m10, if it's got 6 it's got an m20, why make it harder than it is?
Lovely bimmer btw, just needs to be a tad lower ;D
Last Edit: Apr 13, 2012 18:06:30 GMT by dude
rob0r
East of England
Club RR Member Number: 104
What BMW is this?rob0r
@rob0r
Club Retro Rides Member 104
Apr 13, 2012 23:41:43 GMT
I'll bet it's a 320 6 cyl carb. Rear drums and one exhaust tip, not a 323i. Dual lights, not singles, means it should be a 6 cyl, or the lights have been swapped.
E30 320i 3.5 - E23 730 - E3 3.0si - E21 316 M42 - E32 750i ETC
Apr 15, 2012 19:13:37 GMT
Pretty sure its a 320 from the numbers given to me stamped on a plate in the engine bay. Whos the guy that can get the spec from the last 7 digits of the vin (are they safe to post up here?)
Last Edit: Apr 15, 2012 19:17:06 GMT by mgbizzle
Apr 15, 2012 19:26:26 GMT
I found this for the vin: www.bmw-z1.com/VIN/VINdecode-e.cgiGave me the spec: Chassis number 6*****4 Vehicle code 1812 Series E21 Model 320 ( 320 M20 ) Body type saloon Catalog model ECE Production date 1979 / 10 Engine M20 Transmission Manual Steering Right Catalyzer NONE Can i buy a carb rebuild kit from somewhere? I've seen one on ebay but £60 plus postage seems like a lot?
Last Edit: Apr 15, 2012 19:35:35 GMT by mgbizzle
Took it for an "MOT" yesterday, only failed on not having a third brake light. Carb defo needs a tune/rebuild and the drivebelt broke on the way the back so I hope the HG hasn't gone. Here it is outside the MOT station:
Last Edit: Jul 14, 2012 5:00:43 GMT by mgbizzle
