ruffgeezer
Attracts french tat.
I've picked up a full set of 13x5.5" Wolfrace slotmags for the Ax, but they've come with wheel nuts, not bolts, so does anyone in RR land know what sort of taper/washer I'd need on the bolts to fit these? (I am assuming they will go on, I've not tried them yet!) Have a mock up for looking:
I'm guessing they are meant to take flat bolts so you could get a washer to convert from flat to taper making sure your bolts are the correct length or just convert it to studs with correct flat nuts i use www.mistertee.co.uk/2.html which seem really good but have not ordered from him yet
it's not the holes that are rotten it's the metal around them
1975 trabant 601s deluxe
1987 trabant 601 Kombi
1996 fiat cinquecento 1.4 16v
I thought AX wheels had three holes?
1985 Mercedes W123 230E - 5 speed manual & 2011 BMW F11 520d Touring - 8 speed automatic.
ruffgeezer
i had a set of slots a while ago and they had sleeved nuts.. are these the same? are the holes wider than the bolts
I'm not curse word, i just fell off my shoes
VIP
Mister T (above) will sort you out. He did the same for me when I rocked slots on the Laurel.
I also thought these used flat seat bolts? Have you tried a 106/saxo alloy wheel bolt for size? they might need a sleeve machining up, or some spigot rings to center the wheel, though
The Doctor
Club RR Member Number: 48
Talk to me about Slotmags...The Doctor
@thedoctor
Club Retro Rides Member 48
Wolfrace uses a sleeved nut/bolt with a seperate washer with 2 different tapers (if that is the correct way of saying it )
speedshack supplied the sleeved nuts for mine..
purplevanman
Way too orangey for crows
could do with a pic of the holes so it can be checked
ruffgeezer
Here are some pictures of them: The washer is removable on most of the nuts, but not all. The bolts I have on the car currently are these: And I also have a set of Vtr bolts like these: Neither of which are any use as far as I can see.
ruffgeezer
Well I think I'll mock them up for fit on the car before I do anything else, but I'm told these are the RWD offset, so hopefully it shouldn't be far off (I'm running et25 on it at the moment)
Talk to me about Slotmags...stealthstylz
@stealthstylz
Club Retro Rides Member 174
You need to measure the size of the bolt hole, will be 7/16" or whatever (measure from the mounting face side). You'll then need sleeve bolts of that size, with what looks like a 30 degree taper washer. Don't listen to the post above, radius bolts don't work on taper seats.
ruffgeezer
Apr 10, 2012 20:04:01 GMT
It's academic now anyway, there isn't enough back space on them for the front callipers, even with a 10mm spacer so it'll be back to the drawing board. It's a shame because they looked ace: Anyone want some 4x108 slotmags?
