Sept 28, 2006 16:15:17 GMT
Do any of you know about VW water cooleds?
Ive got a mk1 rocco, the head was shagged. My friend gave me a mk2 head, these have hydraulic lifters. The also have one extra oil return, so we blocked the extra oil return and fitted it to my mk1 engine. The rocker cover is filling with oil, getting pushed up the breather and down the carb. I cant believe its filling the rocker cover, surely mk2 heads cant flow THAT much oil? It still has 3 oil returns, around 15mm in diameter.
Any ideas?
Worst comes to the worst ill run the breather into a catch can, but where to return the oil?
slammed 66
www.gtturbo.org
Sept 28, 2006 21:06:43 GMT
86 Renault 5 GT Turbo 89 Renault extra 91 Skyline GTR 98 Mini 1275 mpi 99 Autech Rider www.gtturbo.org
Sept 28, 2006 21:08:38 GMT
don't worry, its only in ONE of my vw engines ;D
Sept 28, 2006 21:41:00 GMT
I assume it didn't do that with the original head? What was shagged about it anyway?
Sept 29, 2006 7:31:10 GMT
Chronic valve seat regression on number 1 exhaust valve Buy a new rocker cover gasket and bring it down to the workshop on Saturday It might be worth getting a rocker cover off a later car with the mesh under the vent pipe from the scrappy as well.
qwerty
Club RR Member Number: 52
Sept 29, 2006 10:16:25 GMT
My polo Coupe S did this when I first got it. We put a good quailty engine flush through seemed to clear the problem.
Sept 29, 2006 12:01:22 GMT
I'm goint ot bring it down saturday so i can fit the spoiler ;D Will the polo be there? I'm working in the morning now, but should be down by lunch. Ill try flushing it, i don't think it did this with the origional head, although it did burn oil and was worse at high speeds. I'm also on the case for a mk2 cam cover, hopefully with a flush and a late cover it should be cool.
Sept 29, 2006 12:10:53 GMT
It should be - the plan is to get the Porsche taken home, take it off the lorry and swap it with the Polo, then Polo down to workshop Have you got the plastic thing that's on the head in the foreground of this picture?
Sept 29, 2006 12:14:52 GMT
Yeah, i fitted that. Its better, but not solved. I just text andy as he's breaking a mk2 but he don't want to split the motor up. I might hit a breakers this afternoon and see what i can find When i fitted the baffle i forgot to check the main oil return hadnt got blocked That could still be the cause i guess.
Sept 29, 2006 12:18:44 GMT
That last pic is just too cool!!
Sept 29, 2006 13:15:22 GMT
That's the back of my garage at home If you do go down the scrappy, will you see if they've got any unscratched Mk2 Polo windscreens?
qwerty
Sept 29, 2006 13:18:26 GMT
Thats one beautifully chopped beetle!
Sept 29, 2006 13:28:42 GMT
Thanks! It'll be nice when it's chuffing finished! Greame (67) is going to help get it ready for primer. As soon as it is it's going down to my new workshop to be painted, then it'll have to wait for money to pay for its roll cage.
Sept 29, 2006 14:30:35 GMT
well, i checked the oil ways, replaced the gasket again and all is good. I flushed the oil system but havent changed the oil yet as the sump plug is stuck. Ill sort it though. After checking everything over i really do think the cam cover is the culpret. Just need to find one now. Shouldnt be too hard i guess.
Sept 29, 2006 15:52:02 GMT
Any "big block" non GTi should willingly donate one
Sept 29, 2006 17:51:46 GMT
Yeah, problem is the only breakers willing to take one of an engine is in chesterfield. Ill see if i get time after work before coming to the workshop.
Sept 29, 2006 20:27:42 GMT
I'd just go and pov one and tell them it was in a back seat or something. You have far too many morals!! My usual tactic is to go and say "I need some bits of trim" then they let you into the yard on your own...
mk2 cam cover fitted, along with the proper mk2 cam baffle and after a quick 85 mph blast (on my own personal stretch of A road ;D) i can confidently say the problem is solved ;D ;D
