Vauxhall viva hc
1975
Approx 70000 miles on engine but 50000 on the clock
Currently on sorn
No mot
spec so far
manta front sub frame steering ect
custom gaz coil overs that sit inside the manta wish bones/front end
Wish bones strength upgraded to take suspension travel off coil overs
Manta 2.0 automatic rear end with custom pan hard rod and three link set up
Corsa 60 mm lowering / stiff springs
New old stock rear shocks
tourqe tube brackets shortened to fit inside viva chassis legs
custom prop shaft / balancing
Manta 1.8 getrag gear box ( very good condition)
C20xe complete with steel head gasket (fully rebuilt and run in /in another car driven by me for 3000 miles)
Ashley competition 2" rear wheel drive four branch with power flow back box and stainless exhaust pipes/ back box
Alloy Manta sump
Manta dizzy drive
recon fuel tank
New high pressure fuel pump / filter and fuel lines
New brake pipes complete
brand new omega clutch
New engine mounts
All oils and fluids brand new including racing gearbox and diff oil
Recently reconditioned rostyle manta steels ( Idea was that she would be sitting lower and wider than another hc but not look out of place
To finish it needs a hand brake cable / front calipers and a sill patched
Car is very solid and has only saw 1 small patch in the boot on one off the shock towers
Interior is first class condition
I can take any amount off pics for genuine interested party's
£1600 no offers it would break in to more
wheels before
wheels after
Car is further on than it is in the pictures
and transport to England Scotland and Wales can be arranged very easily or swap / px for a jaguar xj40 (would love a manual but open to auto)
1975
Currently on sorn
No mot
spec so far
Alloy Manta sump
Manta dizzy drive
recon fuel tank
New engine mounts
wheels before
wheels after
